Question about Refrigerators
Have an LG LRSC26941ST side by side refrigerator. The past 3 days it has not been making ice at an acceptable rate. There are no big ice blocks and 3 days have gone by with only 10 cubes in the bucket. What canI do
5 Suggested Answers
SolutionGuy
  • 331 Answers
SOURCE: GE 25 side by side refrigerator ice maker problem
Assuming the temp inside the freezer is at around 0 or -2 degrees, it should dump ice every ~50 minutes or so. Again, depending on temp's, an Ice Bin should fill within 24 to 48 hours. If your freezer temp is running at around 10 degrees, everything will obviously still be frozen (below 32), but the ice maker will take longer to freeze the water than it would if it were at 0 degrees. Open both doors and place the palm of your hand on the partition between the freezer and Fresh Food compartments... (where the door gaskets seat when they're closed). The temp of the partition should be about 5 or 10 degrees warmer than body temp., If it's hotter than that, you found the problem. Either the condenser coils are dirty and need a good cleaning OR your condenser fan motor (the fan in back, near the floor in the compressor area) is failed or about to fail.
Posted on Jul 29, 2007
  • 23 Answers
SOURCE: ice maker not working
check your owners manual for a water filter, make sure trip arm isn't stuck closed and not letting water in to freeze.
Posted on Dec 08, 2007
SOURCE: ice maker broken
Our is broken as well. Water dispenser works.....
Posted on Feb 24, 2008
  • 489 Answers
SOURCE: LG ICE MAKER
Be sure that the fill tube is getting into the ice maker and that the ice maker is not blocked with ice.  If everything seems ok, you may have a leaking water valve which causes it to constantly drip water into the ice maker causing the block of ice.
Posted on Jun 08, 2008
  • 111 Answers
SOURCE: GE GSS25LGM Ice maker not dispensing ice
You have one of three things wrong. The auger motor is frozen up, the ice bucket is broken or you need to dump out any ice, run warm water through the entire ice bucket, dry it out and try again with fresh cubes. My guess is the auger motor is frozen. You can buy a vinyl boot that covers the auger motor to prevent moisture buildup and freezing from GE Parts at 1-800-626-2002
Posted on Dec 16, 2008
Our LG LFC25960ST fridges ice maker jams up. It wont stop making ice then the whole thing freezes up and jams until it is overfull with ice and completely frozen inside.
SOUNDS LIKE UR ICE MAKER HEAT UNIT IS BAD ID THE ICE IN SMALL PC'S OR ONE BIG BLOCK? IF SO CHECK THE WATER INLET VALVE ALSO
May 20, 2015 | LG Refrigerators
Hi have LG fridge, ice maker making ice but freezes into one solid block instead of staying in individual ice cubes making it impossible to dispense do you have any ideas a sto why this is happening and...
Sounds like this is a water level problem. Too much water is being released into ice tray, which raises the water level above the depth of each cube form, causing one big cube. You can adjust the water level.
Check this out:
How to Adjust the Water Level on an Ice Maker eHow
Jul 19, 2014 | LG LSC26905TT Side by Side Refrigerator
WHY IS THERE WATER IN BOTTON OF FREEZER AND ICE MAKER NOT MAKING ANY ICE
You have an iced up evaporator (cooling coil). This coil is usually located in the freezer section. A small fan distributes air across this coil and into the refrigerator. If coil is block with ice, no air can be blown across the coil. Coil is blocked with ice due to failed defrost timer on main circuit board or a failed defrost heater.
Jul 14, 2014 | LG Refrigerators
LG LMX28988ST freezer at 30 degrees
What it the reason that my fridge is freezing my food. The temp. IS set to 37 F. Why
Mar 14, 2012 | LG LMX28988 (27.5 cu. ft.) Bottom Freezer...
Fan makes noise on LG lsc26905tt. defrosted and
Sounds like ice is building up near the fan blades. Try defrosting it longer to melt out all the ice and see if that helps.
Nov 09, 2009 | LG LSC26905TT Side by Side Refrigerator
Ice maker freezes up
It's likely you have your freezer to cold, Try reducing the setting on that. If that doesn't work you might wanna check your freezer and make sure it's not thawing and then freezing again, you might have a problem with your fridges thermostat.
Oct 12, 2009 | LG LSC26905TT Side by Side Refrigerator
Ice maker not making ice
Try changing the filter; our refrigerator did the same thing.
Jul 17, 2009 | Frigidaire FRS6R5EMB Side by Side...
Ice maker stop making ice
I had the exact same problem after looking at the ice maker I saw that there was a test button I pressed the button and it started working again
try that!!
Dec 28, 2008 | LG LRSC-26922 Side by Side Refrigerator
Lg ice maker leaking LRSC26941ST
Icemaker tray needs to be replaced.
Nov 21, 2008 | Refrigerators
It is possible that the water valve behind the refrigerator is either defective or the wire connection is loose.  Also check the fill tube where the water comes in and see if there is ice blocking the fill tube.  Since it's under warranty, have it serviced by the LG warranty to resolve this issue.
May 09, 2008 | LG LRSC-26922 Side by Side Refrigerator
Refrigerators Logo
138 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
