Question about Toastmaster 3302 Iron
Just stopped heating
Light doesnt' turn on ; tried several outlets;nothing is loose, excpt the cord holder that goes into the handle has slipped out..but it goes backc in easily
  • 1 more comment
  • carlac Oct 04, 2008
    forgot the main issue: it doesn't HEAT!
  • carlac Oct 08, 2008
    just thought i'd ask before spending another dime in this economy!!!!
  • Anonymous Mar 28, 2009
    cord is frayed repair is needed
    Scholar:
  • 62 Answers
Unless you have a 5 or 6 hundred dollar iron, there is an excellent rule of thumb when an iron quits working. Buy a new one. These days, irons can be purchased cheaply enough that it is WELL worth the money. Not just for the convenience, but for the safety issues. This is an appliance that could burn your house down even if it's in PROPER working order. Hope this helps!!
Chad
Posted on Oct 08, 2008
  • Chad Houston
    Chad Houston Oct 08, 2008
    I don't blame you one bit! Things have become very tight at our house as well. Hope all turns out well!
    Chad
Philips GC 2510 won't light up or heat up
If the iron doesn't heat, make sure power is on to the outlet,,test the outlet with desk lamp for to see if working. check the electrical cord, and check the thermostat + fuse inside replace if necessary.
Jan 25, 2013 | Philips GC 2510 Iron
Iron heating sporadically and sensor lights working sporadically
It looks like the cord has a loose connection and will need to be replace.
Mar 29, 2008 | Rowenta DZ9080 Iron with Auto Shut-off
sounds like a loose connection in the power transfer, some piece of metal may be broken or the cord itself may be damaged in some place, you could try replacing the cord. I would just go and buy a new iron. They aren't all that expensive anymore. Good luck with whatever you decide to do. I hope you solve your problem. If you want any further help or have any other questions, please let me know, otherwise have a Good Day.
My Remington Keratin Therapy Flat Iron Doesn't Turn On.
see thi steps and fix it.God bless you
If the iron doesn't heat, make sure 1) power is on to the outlet, 2) check the electrical cord and 3) check the thermostat and replace if necessary. Use the VOM.
Oct 15, 2012 | Remington Style Therapy: Keratin Therapy...
Does not turn on
please see the causes and use the common sense. God bless you
f the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
Sep 19, 2012 | Rival IR600 Iron
Tefal iron stopped working
You better open your tefal iron,so you can fix the problem.When open look for the contact bronze in color must them place in the center,use a sandpaper to clean the contacts,when already clean test it if its okey going to hot again if not turn the udjuster to adjust it is a screw liked.
Hope it nay helps you;
Apr 22, 2009 | Tefal Aquaspeed 155 Iron with Auto...
Turns on, flashes yellow but never heats up
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Jan 12, 2009 | Rowenta Effective DX1900 Iron with Auto...
Sunbeam 4267-000 not turning on just blinking red
"FF" or a blinking light will display meaning “Fault Found”. The “fault” is in the amount of power available to the blanket, mattress pad or throw.
There are several causes to this problem:
1. Bedding product is plugged into an extension cord, surge protector, power strip, or not plugged into a direct wall outlet.
2. Bedding product wasn't plugged in properly.
To FIX this problem, do the following to reset your bedding product:
1. Unplug the power cord from the electrical connection.
2. Unplug the cord from the actual bedding product itself.
3. Re-plug the cord into the bedding product. Make sure the connection is secure and complete.
4. Re-insert power cord back into a wall outlet.
If the 4 steps above are not followed in order, the bedding product will not properly reset.
Dec 08, 2008 | Sunbeam 4237 / 4238 Iron with Auto...
NIA56NR Iron = Panasonic
the filament is gone
u need to replace it from local vendor
Mar 14, 2008 | Panasonic NIA56NR NI-A56NR Iron
Brand new rowenta professional won't heat
The mostly problem in that case is the internal terminal from cord to iron is loose ,open it and fix the the terminal cord to iron,or go to the nearest shop to repair that.
Thanks & good day,
Edgz
Feb 12, 2008 | Rowenta DZ1700 Iron
Toastmaster 3302 Iron Logo
106 people viewed this question
Top Toastmaster Irons Experts
Are you a Toastmaster Iron Expert? Answer questions, earn points and help others
