Question about Sennheiser MKH-416T Professional Microphone
My Sennheiser MKH 416 Shorts In and Out
Sennheiser MKH 416 P48 shorts out when moved around quickly or is bumped. Gently tapping the mic brings a strong signal back. Sounds fine when not shorted out. Opened mic up and did not see any obvious damage, broken connections, or loose chips. I'm going to take it to a repair shop, but, was just wondering what I am in for. Thanks. -James
3 Suggested Answers
rockdiarylv
  • 27 Answers
SOURCE: sennheiser e835 wireless mic won't turn on
how long did you hold the on button for? press it longer
Posted on Mar 02, 2009
  • 140 Answers
SOURCE: I have 3 sennheiser ew100 G2 handheld mics which
You can send them to Pro Line Music
490 Lincoln Highway
Fairless Hills PA. 19030
215-736-8055
It will cost $65. for evaluation + parts+ aditional time past 1hr. + return shipping.
Posted on Jan 16, 2010
When i transmit radio will cut off during transmit, after a few seconds of realeasing mic button radio will come back on.
Mic.the in short a be could around? cord Mic the moving witMic the moving you I would need more information about what the radio does. are all the lights working? does it turn off completely? are you moving the Mic cord around? there cold be a short in the Mic wire.please post any details about what it does.
Aug 02, 2011 | Radio Communications
I have an old MKH416T that I would like to get repaired. and I need a new power suppy for it. I have a Sennheiser BP-2 which doesn't seem to work. Are repair cost going exceed purchase of a new mic. Most...
Sony Esupport.com will get you any accessories you may need. they also have a flat rate repair calculator. I sell sennheiser mics and headphones usually dont go bad its probably within your camera. May look into newer cam options.
Mar 24, 2011 | Sony Cameras
How should I connect an ATM73a headset to a sennheiser SK300
Audio Technica and Sennheiser each have proprietary connectors for their mics. A lot of times the mics require Phantom power which is drawn from the battery of the pack.This is important as the mic will need to be wired correctly to function.
The first thing you will need is the correct plug from the company. Check with Sennheiser customer Support for the correct part. If you aren't extremely good at soldering, do not attempt this. You can change the plug but the wires are extremely delicate and can short easily. Moreover because of the phantom power, the plug must be wired correctly for the mic to function, or you may end up damaging the mic by sending phantom power up the wrong line. I would advise having a music store or pro audio service that handles these products do the wiring for you. If you feel you are up to it, you can do it yourself, but be careful.
Feb 19, 2011 | Sennheiser SK 300 G2 Wireless Bodypack...
The 416 is inherently hissy. Does anyone know the rough frequency of this hiss so I can notch it out in post?
you might be better off increasing the pre amp gain before notching out frequencies. The area of hiss will be in the area of 5k to 8k which will harm the sound of your vocal recordings as that is also the area of clarity and intelligibility. Try the Triton Audio FetHead that will fix it for you. linkd is here: http://www.zenproaudio.com/tritonaudiofethead.aspx
May 05, 2010 | Sennheiser MKH-416T Professional...
On/off button fell off Sennheiser wireless mic
This is quite common with G2's, and really annoying!
If you are lucky, 50% of the time the red button is pushed inside the mic.
You need to remove the bottom section:
- open the battery compartment
- there should be 3 star-bit screws around the outside (remove)
- pull the bottom of the mic off
If the red button is not inside, they are available as a spare part from Sennheiser dealers.
Be carefull when putting the mic back together, it needs to line up correctly with the internal guides, forcing the base back on could damage the ribbon cable. when the line-up is correct it slides on very easily.
Best of luck.
PTB
Jul 06, 2009 | Sennheiser 100/500 G2 Series Wireless...
Mic doesn't work.
I am guessing that if you have tried all of that and it is not working then maybe it just shorted out. Try wriggling it around to see if it goes in and out. If so then there is your problem. Shorts in wiring are tricky to fix but i would suggest just getting a new device.
Apr 28, 2009 | Audio Players & Recorders
Mic is popping
It sounds to me like you have a short in the cable. Power up unit like normal and move the wires at each end of the cable, mic end and connector end, being careful not to move the mic. If you hear popping it's a bad cable. If not, now gently shake the mic, does it pop, then it's your mic's capsule and needs replacement.
Apr 03, 2009 | Shure ULX1 Body-Pack Transmitter...
Sennheiser e835 wireless mic won't turn on
Mar 02, 2009 | Sennheiser E835 Professional Microphone
How can I power a Sennheiser MKH 110?
Hi bibiofi
If you havent any experience with build electronic circuits, or soldering and the like, I suggest getting on of these. It runs of 2 9volt batts, or mains supply. Is the easiest way to go, and in reality, by the time you bought a decent case, sockets, and bits and peices to build one, you could get this one for $50. Too easy. I CAN build the stuff, but I would go this way. Plus it allows you to use 2 condensors if you want. And it does have the T-power 12 volt supply that the mic requires for operation. Is you need more info, please just ask. cheers
regards
robotek
Oct 30, 2008 | Audio Players & Recorders
Dropped sennheiser mkh-60 p48 in water
Wow, nice mic, I hope it survived.
If the mic wasn't powered on when dropped into the water, you may have a better chance, but even still, if may have survived. How pure was the water? If normal drinking water, just open it up as much as you safely can, and give it a day or two to dry out THOROUGHLY, inspect for any signs of corrosion, put it back together and try it.
If it was something akin to pond water, or salt water, or a swimming pool, IMMEDIATELY open it up as much as you safely can, and flush it with as pure and as filtered water as you can. Again, give it a day or two to dry thoroughly, inspect for any signs of corrosion, put it back together and try it.
If it doesn't behave normally, contact Sennheiser for advice, and perhaps they can better help with cleaning, or maybe you can just get by with having the element replaced, etc.
good luck!
Sep 25, 2008 | Audio Players & Recorders
Sennheiser MKH-416T Professional Microphone Logo
154 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
