Question about Troy Bilt 17 Inch 29 Cc Gas Powered Clutched Curve Shaft Trimmer #41ADT52C966
Starter rope on Troybilt TB575SS
My pull rope will not rewind on mt trimmer. Help please.
  • chancechase Nov 29, 2008
    boscia,
    Thanks for your suggestions. Since I first posted this problem I bought a new copy of the trimmer because I have the pole saw attachment. A serviceman I spoke with told me that the entire rope assembly would have to be replaced in the old one and would cost about $45 for the part. I kept the old one and have not yet opened the new one and plan to tinker around with the old one before using the new one. I thing the gears on the rope hub are stripped.
  • 163 Answers
Try removing the starter housing, inside will be a large white or black wheel, visually inspect to make sure the componets are not damaged and that nothing jamming it. try using a lithium spray grease to lubricate the componets. if it still doesn't work the inner coil is probably damaged or came off track. it is very difficult to fix or replace this coil. i suggest taking to your nearest service center but if you would like to try it yourself, let me know and i will give you further instructions.
Posted on Nov 29, 2008
How do I replace the pull starter cord
How do I replace Graeme, Check the attached links,instruction and videos on starter rope replacement. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starter Repair
String Trimmer Recoil Starter Replacement Echo String Trimmer Repair Part...
How to Wind Up or Rewind Starter Pull Rope Recoil Spring on Yard Pro 130A...
Part 1 3 Changing the Recoil Rope on Craftsman Model 358 791030
Apr 01, 2016 | Garden
My wiper sniper pull cord is broken, how do u change the pull cord?
Hi vanzedo, I will try to help you out. Because you don't specify the brand and model I will try to give you the Weed Eater brand that is manufactured by Poulan because it is the best known in my area and I hope it is well known in your area, but it is pretty well the same procedure for other brands.
To disassemble starter, detach starter housing from engine. Remove rope handle and allow rope to wind into starter. Unscrew pulley retainer or pulley retainer screw and remove rope pulley. Wear appropriate safety eye wear and gloves before detaching rewind spring from housing as spring may uncoil uncontrolled. Try to prevent spring from unwinding if possible, I use a flat piece of metal stiff enough not to bend, about 1" wide or less and try to put it between the spring and pulley, if I have the room to do it and prevent spring from uncoiling as it is quite a job to put it back in. (good luck with that one).
To assemble starter, lubricate center post of housing and spring side with light grease. Install rewind spring so coil windings are counterclockwise from outer end. Install proper size and length of rope. Assemble starter while passing rope through housing rope outlet and attach rope handle to rope. To place tension on starter rope, pull rope out of housing. Engage rope in notch on pulley and turn pulley counterclockwise to place tension on rewind spring. Hold pulley and disengage rope from pulley notch. Release pulley and allow rope to wind on pulley. Check starter operation. Rope handle should be held against housing by spring tension, but it must be possible to rotate pulley at least an additional 1/4 turn when rope is pulled out fully.
I hope this is helpful to you even if a little bit. Regards and good luck. Denis.
Apr 02, 2011 | Garden
How to change the pull cord?
Hi b calm,
To disassemble starter, detach starter housing from engine. Remove rope handle and allow rope to wind into starter. Unscrew pulley retainer or pulley retainer screw and remove rope pulley. Wear appropriate safety eyewear and gloves before detaching rewind spring from housing as spring may uncoil uncontrolled. Try to prevent spring from unwinding if possible, I use a flat piece of metal stiff enough not to bend, about 1" wide or less and try to put it between the spring and pulley, if I have the room to do it and prevent spring from uncoiling as it is quite a job to put it back in. (good luck with that one).
To assemble starter, lubricate center post of housing and spring side with light grease. Install rewind spring so coil windings are counterclockwise from outer end. Install proper size and length of rope. Assemble starter while passing rope through housing rope outlet and attach rope handle to rope. To place tension on starter rope, pull rope out of housing. Engage rope in notch on pulley and turn pulley counterclockwise to place tension on rewind spring. Hold pulley and disengage rope from pulley notch. Release pulley and allow rope to wind on pulley. Check starter operation . Rope handle should be held against housing by spring tension, but it must be possible to rotate pulley at least an additional 1/4 turn when rope is pulled out fully.
I hope this is helpful to even if a little bit. Regards and good luck.
Mar 07, 2011 | Ryobi Garden
Have a troy built TB575SS trimer. Pull cord has lost tension and cord is just fully hanging out. How do I I take unit apart to re-adjust cord tension?
The starter recoil spring may have possibly broke or the rope is hung up somewhere on or in the pulley. A lot of these units are assembled using Torx (Star) head screws and disassembly requires a couple different sizes to accomplish. Take your time...you will see the screw heads, but reloading a starter spring for a trimmer is a little tricky and you may need help doing so, but you can fix this yourself.
May 29, 2010 | Troy Garden
Starter rope will not retract
Either you have a broken rewind spring, or the starter mechanism is dirty to the point where the force of the recoil spring is not sufficient to pull the rope back in.
WEAR SAFETY GLASSES while disassembling your starter mechanism to see what the problem is. Upon reassembly, it is a good idea to lube the post in the starter housing (the one the pulley slides over) with some graphite or teflon lube.
Oct 25, 2009 | Troy -Bilt String Trimmer/Blower...
Starter cord will not rewind after being replaced. The string will rewind in the housing before it is attached to the motor but not after being attached. How do you pre wind the springs?
What I do is the following:
Remove the old rope ( what is left of it)
Wind the starter rope pulley about 8 or 9 complete revolutions after I am confident that the spring has engaged the starter pulley
Hold the pulley in place ( align the rope hole in the pulley with hole in the starter housing
Insert the rope and tie a knot, pull the rope back tight against the pulley
Pull the rope all the way out and hold slight tension on the rope and release the tension on the pulley but still holding the starter housing
Starter spring should pull rope into housing... good luck
Sep 08, 2009 | Garden
Pull string for Weed Eater Featherlite Plus came out
If you have the starter spool out (the one the rope goes in)...Here is what to do. Take the starter spool and change the rope out putting it back exactly as it was. Leave the rope hanging. Hold the spool and set it down on the rewind spring. Turn the spool on the rewind spring until you feel it is tight enough. While turning, hold the rope in the little slot in the spool so it can go around without hanging up. Once it is tight, get the rope in line with the spool opening and SLOWLY let the rope rewind. Put on the handle and put the unit back together.Good luck...Lee
Sep 06, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Pull rope does not return
Unless the rope has broken, you dont need to replace it. The problem is probably the rewind spring. It is located under the starter pulley (the one the rope is in). The best thing to do is pull the unit apart and see if you can see if maybe there is something holding the rope up. The spring is a little dangerous to replace. If you go for it, be careful....Lee
Sep 03, 2009 | Garden
Craftsman weedwacker 358.791070 suddenly stopped
could have been caused by any number of thing's,
take the recoil assembly off and try pulling the rope out while holding the center of the rope spool just enuff to prevent it from popping out in case there's nothing holding it there.
rewinding the rope is alot easier than rewinding the recoil spring Trust Me.. lol
Jul 31, 2009 | Garden
How to remove(unscrew?) centrifugal clutch assembly from engine shaft of TB575SS troybilt 4-cycle weed trimmer?
Remove spark plug and insert some cord into the spark plug hole to freeze the crank shaft. This way you can unscrew the clutch from the engine .
Jun 23, 2009 | Garden
Troy Bilt 17 Inch 29 Cc Gas Powered Clutched Curve Shaft Trimmer #41ADT52C966 Logo
1,155 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
