Question about Apex Digital AT2702 27" TV
Adjust screen to fit tv size
I need to adjust the screen size so i can read the edges and top and bottom the the screen display
  • patricia rowland Dec 28, 2011
    the material shown on the screen is to big for the screen and I cannot read the edges particurlarly the left edge and to top and bottom left corners how domi adjust the picture smaller to fit the screen
How do I get my Samsung and Dynex tvs to fit the program to the screen size. 16:9 aspec ratio leaves a black ribbon top and bottom. Zoom cuts off the head on some programs
Some program material in widescreen format (16:9) will be displayed as a "letterbox" with black bands at top and bottom because of the technical difficulty in adjusting to the 4:3 aspect ratio of the TV screen.
Apr 17, 2018 | Samsung Televison & Video
Cannot see score bar at top of screen during NFL games
Try operating on screen adjustment command, if there is no way to adjust screen position , then it may be a faulty component inside the TV.
Is the tv still under guaranty?
Sep 07, 2008 | Sony Grand WEGA KF-50WE620 Television
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
How do I change it from wide screen to regular? I have a black area above and below the picture.
Hello
You can set the picture size by remote control itself.
You can vide 480i format programmes in three picture sizes. 4:3, 16:9, and ZOOM
You can change the picture size by pressing the PICTURE SIZE button on the remote control.
4:3 Picutre size
To fill the screen, the top and bottom edges are extedted more widely, although the center of the picture remains near the former ratio.
If receiving a 4:3 programme, the image size is displayed in its originally formatted proportion.
16:9 picure size
This image displays the size of standard 16:9 with black bars at the top and bottom.
If receiving a 4:3 programme, the image is displayed with black bars at the top and bottom and stretched wider.
NOTE: If a fixed bar remains on the screen for a long period of time, the image can become parmanantly engrained in the screen and cause subtle but permanent ghost images. Never leave your TV for long periods of time while it is displaying these images.
Zoom picture size [for 16:9 formats]
The entire picture is uniformly enlarged --it is stretched the same amount both wider and taller (retains its original proportion). The right and left edges of the picture may be hidden.
OK.
Dec 14, 2010 | Insignia NS- 27" TV27 TV
Zenith 32" TV picture is larger than the TV screen size.
Adjust the Aspect ratio. The manual will tell you how.
Feb 02, 2010 | Zenith A32B84R 32" TV
How can I make the picture size fit the screen? I loose picture around the edges. Seems like it is displaying at a larger size
The issue your having is aspect ratio. Some programs and commercials are broadcasting in a higher resolution so some fill the screen and some have black bars top and bottom. I suggest searching "aspect ratio for video". It would take me all night to type it out. But you need to know how the different resolutions change the size of your image. Also in the TV's menu you should see an aspect ratio option. Try the different settings to see if you can find the best.
Aug 19, 2009 | Zenith A25A23W 25" TV
White dashes across top left of TV screen
That is what I was going yo suggest. You can also adjust the picture size. "Just" will show all of the picture even the distortions on the edges. "Full" will in effect overscan and trim those edges off.
Apr 27, 2009 | Panasonic SC-DT100 System
Samsung DLP HL-P5674W Screen is stretched at the top and bottom...
did you ever find out the problem , mine is doing the same thing,
please email highltv3@aol.com if you can help
thank you so much
debi
Mar 05, 2008 | Samsung DLP HL-P5663W 56" TV
Apex Digital AT2702 27" TV Logo
122 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
