Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
A trying to repair a Bosch AL60 DV2425 Battery Charger. Upon closer inspection there is a device (V5), which looks like a TO-220AB configuration mounted on an upright heatsink. Unfortunately half of the device has broken off (and disappeared), so it's not possible to determine (by what I can make out of the available markings) exactly what it is. The markings that are available are P4N???. Ideally I could do with someone who's got one of these to whip the top of theirs and read the info from device directly - you'll find it adjacent to where the mains power lead connects to the PCB. Failing that a schematic would be very useful. Anyone help please? Regards Chris
BIKER T
  • 909 Answers
SOURCE: Bosch Cooler is broken
im taking it that the cooler you refer to is actually a general fridge. if its not working, it is either your th/stat which has not reset or if not, assuming your fridge is an auto defrost, look behind the freezer and locate the timer. you should see a plastic knob plus/minus in the middle of the timer. turn the knob and listen if refrigerator comes on. if not call a tech.
Posted on Aug 27, 2007
  • 146 Answers
SOURCE: Smelled like burnt board
Just so you know. Bosch has a 5 year warranty on any printed circuit board (excluding labor) so you pay only for labor charges. They have a 2 year warranty (again excluding labor) on the entire dishwasher. I am leaving a copy of my owners manuals warranty information I hope this helps.
Extended Limited Warranty: Bosch also provides these additional
limited warranties:
• 2 Year Limited Warranty: Bosch will repair or replace
any component that proves to be defective in materials or
workmanship (excludes labor charges).
• 5 Year Limited Warranty on Electronics: Bosch will repair or
replace any Bosch microprocessor or printed circuit board if it
proves to be defective in materials or workmanship (excludes
labor charges).
• 5 Year Limited Warranty on Dish Racks: Bosch will replace the
upper or lower dish rack (excluding rack components), if the rack
proves defective in materials or workmanship (excludes labor
charges).
• Lifetime Warranty against Stainless Steel Rust Through:
Bosch will replace your dishwasher with the same model or
a current model that is substantially equivalent or better in
functionality, if the inner liner should rust through (excludes
labor charges). Bosch will replace the stainless steel door if the
door should rust through (excludes labor charges).
The foregoing timeline begins to run upon the date of purchase, and
shall not be stalled, tolled, extended, or suspended, for any reason
whatsoever.
Repair/Replace as Your Exclusive Remedy: During this warranty
Posted on Jan 15, 2008
ginko
  • 19396 Answers
SOURCE: I can't seem to get any power to my Bosch Maxx
If you are in UK, check the fuse inside the power cord.
If the power cord is not fused, then you need to replace the control board, or fix a wiring problem, since this machine does not have any fuse in control board.
If you need to call a technician you can use the phone number listed on the owner manual.
Posted on Feb 24, 2009
  • 16 Answers
SOURCE: bOSCH BC004 BATTERY CHARGER - LOOKS LIKE NOT
are the lights on the unit coming on? if they are, its probably working fine. in that case you have a battery issue.
Posted on Mar 10, 2010
  • 165 Answers
SOURCE: how do you install a custom panel onto a bosch SHV
call bosch. There are specific instructions and a template they supply for measuring and attaching the panel. But that's all I can offer. Understanding the instructions is a whole 'nother' problem.
Posted on Apr 26, 2010
I have a 18 volt nI cad Bosch charger .can I get it repaired and by who
Have you tried a tool repair service? My husband is always seeking advice from the tool professionals. Due to constant use, his chargers stop working often and, although he is a handyman himself, there are times when his own knowledge isn't sufficient. bourgetbros com
Aug 07, 2015 | Bosch Drills
How to repair bosch lithium ion battery charger?
how bad.? there is a power supply tech in outskirts of Temple, TX goes by White Lightning on the cb radio.. may find him and see what he charges to fix.
Jul 14, 2014 | Radio Communications
Acer aspire v5-171 don't charge well
the tip of your charge maybe defective try to move it up and down so that you will the tip of the charger has its problem or the charging port then let the technician repair it
Mar 24, 2014 | Acer Aspire V5-171-6860 - Core
Bosch she43f15uc just stopped pumping water. Any ideas? it is only 18 months old.
My Bosch dishwasher had the same problem. After checking the over flow pan I removed the inlet hose to check water flow. There was none. I checked my cut off valve...open...I had water at the kitchen facet...scratch my head...I looked closer at the Bosch supplied braided water hose. It is directional (label indicating which end to hook to supply)....closer inspection reveals maybe there is a back flow valve in that side of the braided hose. Disconnect, blow air through...air passes freely...reconnect and bingo water flow at the dishwasher. In line back flow valve...can you imagine what a repair man would have charged for that?
Apr 04, 2012 | Dishwashers
Tmobile dash isn't turning on
  1. Verify that the OEM Charger and Battery are being used.
    • Only the AC charger, Car charger, or USB data cable that came with or was created for the device should be used; others can damage the device and/or battery.
  2. Is the device warm?
    • When using the device for prolonged periods of time, such as when you're talking on the phone, charging the battery or browsing the web, the device may become warm. In most cases, this condition is normal and therefore should not be interpreted as a problem with the device.The device has a protection feature that if the device becomes too warm (due to use of GPS while charging, BT while charging, using the device as a wireless modem, etc), the auto protection feature will be triggered and the charging process will be stopped. Once the device cools down, the device will then begin charging again.
  3. Check the USB Port on the device for any bent or misshapen PIN's.
    • If some are found, that is the most likely cause and this is considered physical damage not covered under the Warranty.
  4. Remove the battery and inspect the contacts.
    • Remove any debris/residue found on the device or battery contacts with a soft, dry cloth.
  5. Look closely at the battery contacts on the phone to see if they are bent out of shape.
    • If they are bent, the device will need to be exchanged.
  6. Try charging the device (try different power sources as well as chargers):
    • Plug in USB to device and PC; is the LED indicating that the device is charging?
      • Note: If the device isn't charging while connected via USB to a PC, go to Start>Settings>More>Power>Power Management and make sure that "When device is turned on, do not charge the device when connected to the PC" is set to OFF.
    • Plug in AC Charger to device and outlet; is the LED indicating that the device is charging?
      • LED indicators: Charging is indicated by a solid Amber light on the upper Left side of the face of the device.
        • Note: If the battery is completely dead, the light will be a solid RED for a few seconds while it is charging; once the device has enough power to turn on, the light will turn to Amber.
  7. Try another Power Source.
    • Try a different outlet to rule out that as the issue.
  8. Try another battery in the device.
    • If another battery doesn't work, perform a Hard Reset.
      • If the device powers up after Hard Reset, test the unit for a few days. If issue returns, device can be considered for an exchange.
      • If device shows charging with one (AC Charger or USB) and not the other, issue is with the accessory. Replace accessory.
      • If device will only power up when attached to charger (AC or USB) it is likely the battery needs to be replaced.
Device won't hold a Charge
The life of the battery between charging sessions will vary depending on which features of the unit are being used.
  1. Verify the you are using:
    • OEM AC Charger
    • OEM USB Data Cable
    • OEM Battery
  2. Fully charge the battery using the OEM AC Charger
    • USB and car chargers are trickle chargers meant to get the user through until they can get to their AC Charger.
  3. If the device is not lasting the advertised Talk time, with minimal use, try another OEM battery in the device.
  4. If the battery life still is not meeting the advertised Talk time (with minimal use), the device will need to be repair/replacement.
Device won't Power on
  1. Attempt to charge the device.
    • If the battery is dead, the device will need to charge for a few minutes and then should power on once this happens.
  2. Attempt to power the device on by pressing the Power Button for 3-5 seconds.
    • If the device doesn't power in, perform a Soft Reset using the stylus.
  3. If the device still doesn't power on, perform a Hard Reset.
  4. Try another battery.
  5. If the device still will not power on, it can then be considered for repair/replacement.
Handset Powers off
  1. Make sure that the device is actually powering off and not just going into hibernate mode by pressing the power button once.
    • If the screen comes back on, the device is not powering down.
  2. If possible, check the battery level by going to Start>Settings>More>Power>Power Management.
    • The charge should be no lower than 10%; if it is, charge the device and retest.
  3. Try another battery in the device.
    • If the device stays powered on with a different battery, the issue is with the accessory not the unit.
  4. If the device still powers off with another battery, Hard Reset the device and retest.
    • If the issue remains after the Hard Reset, the device it can then be considered for repair/replacement.
Nov 13, 2010 | T-Mobile Dash Smartphone
I notice a few weeks ago my laptop shut down suddenly. Then it became more frequent of late. Today it did it again I tried starting in safe mode; repair mode- everything. Upon closer inspection I realize...
The A/C >> D/C inlet port is a separate component but does require a complete dis-assembly to replace it - the cable is not expensive but take about 50mins to pull down / replace the cable then reassemble - contact your HP service agent.
Jun 26, 2010 | HP Pavilion DV7-1232nr Notebook
Battery charger does not work for my bosch hammer drill sds plus .. my dad is an electronics engineer and he requires the circuit diagram to investigate the problem, where can i get one for this model .....
My charger (24 v) died also and repair shop wanted too many $ for repair. I happened on-to a charger for a printer (24v 1 amp) at the thrift store for $3.00 and fashioned a connector for connecting to the battery. It takes about 3 hrs to charge the battery but you must disconnect manually. It has been working for many months. It will do for me untill i find a bargan on ebay. The repair shop said that the part that failed was not a component that can be changed. (Multyfunction chip) Hope this helps for the short term. Enjoy
Dec 14, 2008 | Bosch SDS-plus BULLDOG Xtreme Rotary...
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
75 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
