Question about Amana Washing Machines
Amana top loading super capacity LWD35AW leaking
I just found out my machine is leaking underneath somewhere. I haven't taken it apart yet. Any suggestions or ideas?
  • 750 Answers
Hello horshomom
Welcome
You said, You just found out my machine is leaking underneath somewhere and you haven't taken it apart yet. Any suggestions or ideas?
How old is the machine?
How much water leaks and when?
It usually is a leak in or around the drain hose.
I've seen a clamp vibrate loose near the pump.
You should be able to find it!
Let me know. Huuum
Please remember to leave a rating.
Posted on Oct 04, 2008
Hotpoint washing machine wdd960 is leaking from underneath.
either tub has a leak or one of the hoses has a leak somewhere? if u remove the cabinet then run machine u can see and locate ur leak more easily? by the way a tub leak can be repaired some times with some water proof selant
Jan 09, 2015 | Hotpoint Washing Machines
Machine does not power up
The fuse is located in a little black box underneath the base of the machine, but it is not an easy job to take the box out, disassemble it, replace the fuse, and then reassemble the whole machine. I suggest you take it to a service center.
Aug 31, 2008 | Janome Memory Craft 4000 Sewing Machine
Repair service manual for Viking model 610 electronic sewing machine
ask your authorized Viking repair to locate a new or used part
Apr 10, 2014 | Husqvarna Sewing Machines
Gas leak idk where
leaking gas would show up somewhere --sure not being siphoned
Dec 22, 2017 | Chevrolet Beretta Cars & Trucks
Indesit WIL143UK knocking noise
Most likely the suspension gone a bit loose. Try with lesser load
Nov 10, 2013 | Indesit W 123 Front Load Washer
Model wdss4120aww GE Washer is leaking
If it's leaking during the agitation cycle, and only in 'large' and 'super' water levels, then that's just the way the washer is designed. I got rid of that piece of junk.
Mar 03, 2013 | GE WBSR3140D Top Load Washer
Machine leaking, grey tube at bottom of machine has come loose from somewhere causing it to leak. what is this for ?
grey tube is actual 'pipe' that should be attached to the pump which empties the drum.
(a) Lay washing machine on side with a couple of blankets under neath to save damage to the side.
(b) Look underneath the machine and you will see where the grey tube should be affixed. suggest if you cant find the retaining clip, purchase a
1.5" (3cm) jubilee clip and tighten around the grey tube to hold it in place.
May 18, 2012 | Zanussi Washing Machines
I need to know the capacity of this model LWA05AW Amana washer
The LWA50AW washer is a 3.2-cubic-foot super-capacity top-load washing machine
dont forget to rate me it helps! thanks
Jun 07, 2011 | Washing Machines
My Amana Super Capacity Plus washer, model NAV2330AWW is leaking. Any ideas about the problem and/or cost to fix?
The first thing to do is to have the leak investigated by somebody there as we could only offer a list of guesses ;-0)
Once it is empty and carefully lifted onto its side, it should be possible to inspect the hoses and clips and hopefully identify the culprit. In some cases it might even be possible to affect at least a temporary fix whilst obtaining the necessary spare.
Sorry we could be only of limited help in this instance- it's very difficult diagnosing this sort of problem remotely ;-0(
Good luck,
John C
Apr 06, 2011 | Amana ALW480DA Top Load Washer
Ultimate care supreme leaks underneath
First check the hoses to the machine. If they leak the water follows the hoses and drips on floor. Also check the hose connection at the washer. They will leak inside. Next it may well be a water pump going out or the plastic hose that is under pressure when operating. The pump is in the middle of machine underneth - Sorry - Good luck
Oct 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
279 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
