Question about Rinnai Unvented Gas Zone Heater. 99% fuel efficient: Blower with Thermostat
Rinnai rce606tra unvented heater
Heater is not much over 1 yr old moved to new location for this heating season after hook up will not start combustion erroe code 31
can i fix it or do i have to send it some where
  • 1 more comment
  • jrf1 Oct 04, 2008
    thanks for response, im not sure if im responding the correct way . yes i have manual.
  • jrf1 Oct 04, 2008
    yes have manual
  • jrf1 Oct 05, 2008
    wow thats some solution from a team of elite experts i posted again in the free section and the response i got was to spend another 10 bucks and i can get another comment from a guru
    Scholar:
  • 116 Answers
Check out this link for more detailed help
http://www.foreverhotwater.com/documents/1110116.pdf
Combustion Air
Temperature Sensor
fault:-----------------------
Check for restrictions in air flow around unit and vent terminal.
Check sensor wiring for damage.
Measure resistance of sensor.
Clean sensor of scale build up.
Ensure fan blade is tight on motor shaft and is in good condition
replace sensor
Combustion Fan
Failure:--------------------------
Ensure fan will turn freely.
Check wiring harness to motor for damaged and/or loose connections.
Measure resistance of motor winding.
To display the most recent error codes press and hold the “On/Off” button for 2 seconds. While holding the “On/Off” button press the button. The last 9 error codes will flash one after the other. To exit this mode press the“On/Off” and button as before.
To display the water flow through the water heater press and hold the button for 2 seconds and withoutreleasing the button press the “On/Off” button.
To display the outlet water temperature press and hold the button for 2 seconds and without releasing the
Flushing the Heat Exchange (Error Code: LC or 00)
An “LC” or “00” error code indicates the unit is beginning to lime up and must be flushed. Failure to flush the
appliance will cause damage to the heat exchanger. Damage caused by lime buildup is not covered by the unit’s
warranty. After flushing, reset the LC fault code by turning off the power to the unit and turning the power back on
1. Disconnect electrical power to the water heater.
2. Close the shutoff valves on both the hot water and cold
water lines (V3 and V4).
3. Connect pump outlet hose (H1) to the cold water line at
service valve (V2).
4. Connect drain hose (H3) to service valve (V1).
5. Pour approximately 4 gallons of virgin, food grade, white
vinegar or citric acid into pail.
6. Place the drain hose (H3) and the hose (H2) to the pump
inlet into the cleaning solution.
7. Open both service valves (V1 and V2) on the hot water and
cold water lines.
8. Operate the pump and allow the cleaning solution to
circulate through the water heater for at least 45 minutes.
9. Turn off the pump.
10. Rinse the cleaning solution from the water heater as follows:
a. remove the free end of the drain hose (H3) from the pail
b. close service valve, (V2), and open shutoff valve, (V4).
Do not open shutoff valve, (V3).
c. allow water to flow through the water heater for 5 minutes
d. close service valve, (V1), and open shutoff valve, (V3).
11. Disconnect all hoses.
12. Remove the in-line filter at the cold water inlet and clean out
any residue. Place filter back into unit.
13. Restore electrical power to the water heater.
Posted on Oct 06, 2008
    Genius:
  • 1,011 Answers
Dear,
while placing it to another location. did it get hit by someone... check in this respect by the way
regards,
dont rate it until u satisfy with it or it helps!
    Brigadier General:
  • 3,614 Answers
ERROR 31 MEANS = Thermistor Disconnect
  1. Measure continuity from pin #8 to pin #9 and make sure of connection at PCB.
  2. Measure Ohms on 2K scale from yellow to yellow. If open, replace.
  3. Check connection of flue gas pipe and intake hose behind unit.
Posted on Oct 04, 2008
  • micromaster
    micromaster Oct 04, 2008
    keep us all updated on this.. how things get done..
    President:
  • 2,712 Answers
You will probably need to get it serviced. First check if the wall socket is working properly and the power cord and plug is in good condition.
You can find a repair service near you by entering your zip in the box to the right that says "Repair Service". Just mention that you were referred by Fixya, and you may just get a discount :)
Hope that helps!
Please don’t forget to rate or "Accept" the solution if it helped you in any way, or leads you to a fix.
Thank you for using FixYa!
IrishDruid
    Master:
  • 479 Answers
Do u hve a copy of manual with u
  • tech gurus Oct 04, 2008
    keep me updated for more help and queries
Can unvented gas heaters be converted to vented?
No mate , cannot do it you need to buy them as is .
Apr 06, 2013 | Desa International Unvented Gas Space...
The pilot doesn't stay on. the flame doesn't extend out as far as it normally does. The model number is Reh-30dt-p.
The pilot light will extinguish when you turn the valve to on for main burner... cause is a bad thermocouppler. it's yhe bulb the poilot light heats up.
Oct 09, 2009 | Rinnai Unvented Gas Zone Heater. 99% fuel...
Rinnai Energysaver 1001FT, ignites, blows 5mins then shuts down.
Sounds like it is reaching high limit...either the filters on the back are plugged, or the manifold pressure isn't adjusted properly. IF the exhaust were plugged on the unit, it wouldn't fire at all, since it has a pressure switch to verify vent flow. The slightest blockage, the unit will lock out to prevent damage to the unit.
Jul 07, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Little spark to start my unvented 8 year old Rinnai. Use match.
Yes - most likely thermocouple, or if the pilot has an orange tip, it will not heat the thermocouple enough to keep the valve energised. Try a blast with canned air or contact cleaner down the tube, not 100psi air compressor.
If that doesn't help, time to ring a gasfitter.
Dec 11, 2008 | Rinnai Unvented Gas Zone Heater. 99% fuel...
Converting Rinnai REH-25-N to LP
Typically, an unvented heater or gas log cannot be converted, mostly for safety reasons and it is usually cost prohibitive. Some newer heaters come with both Natural Gas and Propane components and have to be set up one way or the either.
It would be better to sell your old heater and get one with the proper gas type.
Nov 23, 2008 | Rinnai Unvented Gas Zone Heater. 99% fuel...
Rinnai 606tra error code 31
since the e mail you sent to me was do noy reply i will try to get my point across here.
i posted my question on your 10 buck forum the answer i got was read the manual and now after posting on your free forum the reply i get is to try posting in the 10 buck forum. sound like a run around to me
Oct 04, 2008 | Rinnai Unvented Gas Zone Heater. 99% fuel...
Rinnai fan stops turning.
You can reach the fan wheel by using a can of compressed air normally used to clean your compute keyboard. Make sure you hold a vacuum wand close to the heater when doing this to collect the debris. Using a small coffee stir straw, lubricate the end of the fan motor shaft with light motor oil. This will keep the motor alive for a bit longer.
Aug 13, 2007 | Rinnai Unvented Gas Zone Heater. 99% fuel...
Heater goes off
Possibly A bad thermocoupler. It is the part that looks like a stiff solid copper wire with on end sticking in the flame of the pilot light and is a safety feature if the pilot goes out it starts to cool and the resistance changes back you the module and the module shuts the gas off. I have seen these go intermediately faulty in waterheaters and do just what you described.
Jan 08, 2007 | Rinnai Unvented Gas Zone Heater. 99% fuel...
Rinnai Unvented Gas Zone Heater. 99% fuel efficient: Blower with Thermostat Logo
216 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
