Question about RCA D52W19 52" Rear Projection Television
Stil confused I'am sorry know I don't know if the original question went through. I have a RCA D52W19. I've read your answers about the flyback. My TV is doing the turn off turn back on thing. But when it turns off the green light goes off, then after a second the green light comes on and so does the TV. Don't notice any flashing. Could this stil be the flyback? Maybe at an early stage with no green light flashing? Sorry if this keeps repeat, but don't know if doing it right. Thank you. Shawn
  • RCA Master
  • 5,138 Answers
Check 3 capacitors on deflection board where the flyback is but they are located on front of board cp150 2200uf 16v cp111 330uf 35v cp114 220uf 35v Look at top of capacitor cp150 if it looks like it is bubbled on top it is bad so replace all 3.
Posted on Oct 09, 2008
2 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: RCA = flyback?
I just posted a reply to you. Its most likely not the flyback causing that symptom.
Posted on Oct 05, 2008
I REPLACED RCA D52W19 CAPACITORS ONE TIME 5 YEARS AGO,AND THE TV CAME ON AND WORKED,IT LASTED 5 YEARS,BUT RECENTLY IT JUST WONT POWER ON,I REPLACED THEM AGAIN BUT IT WONT COME ON AND FLASHES THE POWER...
You have a bad flyback transformer. This is a common problem that eventually goes bad in the ITC 222 chassis. You have to get the model number with the code at the end of it after the /. And sometimes you must have the numbers from off the flyback itself. Try to contact MCM electronics for the flyback at 1-800-543-4330. First see if they can match it with the model number with the code after the /.
Jul 15, 2011 | RCA D52W19 52" Rear Projection Television
Need circuit board
You might be able to get some help from the owner of the RCA name;   Thompson Consumer Electronics
Mar 01, 2009 | RCA D52W19 52" Rear Projection Television
Tv turns on then turns off
you need to replace the flyback its the 259296 flyback which is available at the following link and they send free instalation instructions with detailed photos on how to do the replacement of the flyback.
http://servicemanuals.vstore.ca/product_info.php/pName/rca-flyback-259296/cName/flybacks
Feb 27, 2009 | RCA D52W19 52" Rear Projection Television
Tv not turning on
replace the flyback you need flyback # 259296 you can get the flyback at the following link with free installation instructions.
Removing the HV Wires from Flyback on RCA TV D52W19/
You really dont need it its only a wire.sliice and reconnect.
Feb 18, 2009 | RCA D52W19 52" Rear Projection Television
Capacitors
There is 3 capacitors in same circuit 1 will be a 2200uf 16v / (2) of them are 220uf 35v and some sets may have (1) 220uf 35v (1)330uf 35v. replace 3 that are green with gold writing on them. also when reconnecting board make sure you have second ribbon connected good or set wil not come on.
Nov 06, 2008 | RCA D52W19 52" Rear Projection Television
RCA = flyback?
Oct 05, 2008 | RCA D52W19 52" Rear Projection Television
D52W19 Screen Flicker
Go back to FBT check and make sure your high voltage wirer is in good.
Sep 18, 2008 | RCA D52W19 52" Rear Projection Television
Rca d52w19 fix fuse name
thats not a fuse issue, its a defective flyback. You can get a replacement flyback at the following link with free installation instructions so you can easially install it yourself. You need flyback number 259296 here is the link.
Aug 22, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19
There are two flat ribbion cables betwwen the deflection and signal board when you hear that sound the first thing to check is those cables make sure there seated first
Jan 03, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
118 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
