Question about Oreck XL Ultra Bagged Upright Vacuum
Oreck XL9100 Our vac motor was removed to remove a hairpin in the motor.? The tape fell off the wires. Do you have a wiring diagragm?
  • 1 more comment
  • khartsuiker Oct 06, 2008
    If you can't read these, and they are small and not good resolution, email me and I will email you back the diagrams themselves.
    Keith
  • SJCobb Jan 04, 2009
    Need the diagram to wire a new motor in an XL 9100
  • Howard Galaway
    Howard Galaway Jun 17, 2014
    Hey Keith can you send me the same wiring diagrams on the Xl 9100 to hgalaway@gmail.com
Posted on Oct 06, 2008
How do I wire an oreck xl9100 motor
The black wire coming from the power cord will go onto the terminal closest to where the cord goes into the vacuum. Sometimes there is a black dot next to the terminal. The white wire from the cord will attach to a piggy-back terminal on the white wire coming from the lights and will attach to the motor on the other side of the motor from where the black wire attached. There may also be a black dot beside that terminal as well. The black wire from the lights will attach to a terminal on the side where you attach the white wires, either right next to them or above them on the same side of the motor. Hope this helps you.
Sep 06, 2014 | Oreck Lamp Housing with Reflector XL9100...
I need a good wiring diagram for my Oreck xl vac
Chuck,
I do not have a diagram for you but I can tell you how they normally are hooked up. When you have the motor sitting in it's normal position the black wire from the power cord will attach to the terminal closest to where the cord comes in. There should also be a black dot next to the terminal. The two white wires will connect together and they will go on a terminal on the other side of the motor that also has a black dot next to it. The remaining black wire should connect to a terminal next to the white wires or at least on the same side of the motor as the white wires. Hope this helps you.
Apr 12, 2014 | Oreck XL Ultra Bagged Upright Vacuum
My Oreck xl9100 stopped dead while plug still in wall. What now?
No smell or smoke? Then check outlet first (breaker?) Then open up and check for break in wire or loose connection
Aug 30, 2013 | Oreck XL Ultra Bagged Upright Vacuum
Oreck xl9100 runs okay when upright but when the handle is at an angle the motor stops
you must test the power cord for open or break use the VOM
2) Test for main switch some wires loose, or bad solder, or switch defective, and replace.
3) Thermal fuse, loose, or bad contact. tight.
4) See if the belt is sliping or broke or worn and replace.
God bless you
Jul 27, 2012 | Vacuums
My Oreck XL has quit sucking. The brush turns but
Same problem here with XL9100. Bag would not expand implying no suction. Motor ran and brushes turned. Easy disassembly using common tools found that a plastic bag had been sucked up and caused a blockage prior to the impeller. Cleaned up, reassembled, and everything worked fine after that.
Nov 05, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Oreck xl 9100 how to replace the fan
I just replaced the fan (plastic) on an XL9100. I assume you got the bottom plate off (5 screws).
Undo the single screw holding the suction housing in place.
Remove the two screws holding the motor in place and gently lift the assemble up, being careful not to stress the wires. The motor and fan assembly should now be exposed. If the nut holdling fan in place is removed, the whole fan should slide right off. If it does not, try a little WD-40 on the shaft and wiggle and move from side to side. (I slipped a small drill bit between the motor fan (motor cooling fan) to prevent the shaft from turning when you remove the nut.) Be sure you turn the nut counter-clockwise to remove it.
You should now have the fan off. Reverse the procedure to place the new fan - following the directions carefully as some assemblies need a washer and "feathered" washer on the top.
Assuming everything went well, it should work.
My 9100 sucked a magnetic bearing and trashed the metal fan to where suction was weak. The new fan works great.
Cheers
Mar 26, 2009 | Oreck XL Ultra Bagged Upright Vacuum
XL2525 changing motor
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=723450
Posted by geoffjackie on Jun 30, 2008
Please forward the wiring instructions for changing the motor in my Oreck XL 2525
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You can contact the Oreck factory for the wiring instructions but you need to give them the model # and the serial # if needed and I will supply you with the Oreck website and the cust serv phone # listed below. Also, you can check the owner’s manual and sometimes there is a schematic that shows you if information you need for changing the motor. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 30, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Oreck Orbiter
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618779&thid=681757
Oreck Orbiter
Posted by eccott on Jun 18, 2008
Hi could you e-mail me a wiring diagram for the Oreck Orbiter please? I need to replace the mains cable & the cable to the motor. Thank you, Helen Eccott.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck Orbiter Floor Machines ORB-500… you can contact the customer service line / tech support @ the Oreck Factory that I will list below for you and they will be happy to help or assist you in the wiring diagram, please include the model # and serial # with your request. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
Jun 18, 2008 | Oreck Orbiter Floor Machines ORB-500,...
Oreck XL
I would advise you to ALWAYS to FIRST UNPLUG THEIR VACUUM before beginning any service procedure. The motor has 5 wires to the motor as stated in the Oreck owners manual, tow are for the headlights, one is a ground wire, and the other two are for the motor. There are two screws that hold in the Oreck motor and a good suggestion is to use tape the wires leads and mark the wires so that you will not make a mistake as you take it apart and reassemble the motor. That way you will not make any mistakes, whether or not you have wires for a headlight or not, the rules are the same. Also refer to the owner’s manual schematic and the exploded view. Questions? 1-800-989-3535
www.Oreck.com
Mar 31, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Wiring
backwards wiring. The motor will still run but the lights keep going out right?
Oct 23, 2007 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL Ultra Bagged Upright Vacuum Logo
1,799 people viewed this question
Top Oreck Vacuums Experts
Roger Potts
Jim Parker
Jim Parker
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
