Question about Video Game Consoles & Games
I don't have software for my rumble pad. - Video Game Consoles & Games
Went online with logitech
Posted on Oct 06, 2008
I just purchased dreamgear wireless rumble pad. It tells me to insert a USB into the front of my game set wear I would connect a contoller with a wire attached to it. What is the USB it is refering to and...
IT IS CALLED MINI B USB CABLE
YOU CAN FIND IT AT BEST BUY, RADIOSHACK AND ALMOST EVERY ELECTRONIC SHOP
http://www.sears.com/shc/s/p_10153_12605_SPM498602701P?sid=IDx20101019x00001a&ci_src=14110944&ci_sku=SPM498602701
RATE IF THIS SOLVED YOUR PROBLEM
Apr 11, 2011 | DreamGear DGPS3-1346 Lava Glow Wireless...
My Cyborg Rumble gamepad is always going at the upper left. It is stuck there. What can I do?
technical solution:
try another PC - if this Pad make the same problems this another System -> back to the Store.
Feb 22, 2011 | Saitek Cyborg Rumble Pad Game Pad
I need software & manual for GGE909 rumble pad
Hi.
GGE909 rumble pad software (xp/vista/win7/win8/mac) can be found at driverupdate us
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Mar 25, 2010 | Game Elements GGE900 (51691)
How do i fix a squeeky wheel, possibly bearing?
A bearing typically has more of grinding type of rumble rather than a squeek.
Try checking your brakes...the caliper may not be releasing completely. Cleaning them can solve the problem and prevent premature wear.
Mar 23, 2010 | 2001 Oldsmobile Alero
I went to leave work this evening and my car had a terrible rumble when I applied the brakes. Not a squeak or grind, but a low loud rumble. what could it be? 2003 alero with only 35000 miles
You could have lost a brake pad. You need to take the tires off and look at the brake shoes and pads. Try and determine when you drive if the noise is coming from the front or the back. Will narrow it down some.
Dec 08, 2009 | 2003 Oldsmobile Alero
My Saitek game pad will not work with Call of
the game doesn't supports any controller except xbox 360 controller
Aug 01, 2009 | Techland Call of Juarez for Windows
Setting up rumble pad
Ok well here is what i did for using the direction pad to play flatout, a pc racing game, using the Wireless rumblepad 2 controller. First open up profiler, click on d-pad, select assignment, then click new POV assignment. Put a check on FPS style movement. Then click edit, then click new keystroke. Hit record and then on the keyboard hit the up, down, left and right keys. Then hit stop and click ok. click cancel on the window right behind it. So now you are viewing the POV assignment window that we opened before. Here what you do is, say for instance hit the "N" button and then to the right of it you see "pov north", hit the scroll down menu and hit "keystroke Up" for N. Like wise you click the "E" button and for POV east you assign "Keystroke right". And so like wise "keystroke down" for "S" and "keystroke left" for "W". Once you have all that done. You hit ok and just open up whatever game you want to play and the Direction pad should be able to allow you to steer or go in the up, down, left or right direction. Hope these instructions help solve your problem.
Oct 16, 2008 | Saitek Cyborg Rumble Pad Game Pad
No game connection
What i would suggest for this problem is for you to use add remove programs. Remove the firmware or software for your rumble pad. Then use your favorite search engine and look for a a registry repair program and download it ( this is just incase that during your install it might of changed the registry that it would not reconize your rumble pad) once you have run this program then install the rumble pad according to what the manufacture has printed. Follow each step exactly as they printed. This is critical because each add on to a computer requires a specific order for the install to be complete and for the registry to enable it. After you are done installing it. Go to your system settings and into device manager. There you will find a list of devices avaliable on your computer. look for your product usually listed under USB. Once you find it click on it and go through the menu to see if this hardware has been enabled and there is no problems. If there is a problem you will see "!" next to the problem area.
Sep 23, 2007 | Logitech Rumblepad 2 Vibration Feedback...
Video Game Consoles & Games Logo
14 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
