Question about HP Pavilion dv1000 Notebook
Hp 1000 notebook wlan
I installed linux umbutu on my laptop and cannot open WLAN function or make a wireless connection. I think I may need a driver but have not been able to find download. Help, please.
  • 10,594 Answers
Download required drivers from Here.
Posted on Oct 04, 2008
  • HP Master
  • 13,433 Answers
Yes you will need driver / software for it, what wireless adapter you got?
  • HP Master
  • 1,879 Answers
If you're unlucky and your hardware doesn't / refuses to release a Linux driver, you can use a windows driver but you have to wrap it.
Ubuntu supports a system known as NDISWrapper. This allows you to use a Windows wireless device driver under Ubuntu.
  1. Obtain the Windows Driver for your system and locate the file that ends with .inf.
  2. Install ndisgtk (SystemAdministrationSynaptic Package Manager).
  3. Open ndisgtk (SystemAdministrationWindows Wireless Drivers).
  4. Select Install new driver.
  5. Choose the location of your Windows .inf file and click Install.
  6. Click OK.
Helping out!
Open control panel -> network and sharing center (Vista/Win 7) and change adapter settings. See if wireless network card is available. If not, get the driver from manufacturers web site and install it.
If the driver is installed, check that WLAN is not disabled by some mechanical button on laptop. Some models have these.
Nov 25, 2013 | Dell Vostro 1000 Laptop
Wireless adapter not functioning-
Do the following :
  1. Turn Laptop off, then disconnect adapter and remove battery. Re assemble and restart.
  2. Try clicking the button activating the wireless card.
  3. Reinstall wireless card drivers, select drivers from Compaq Presario V6205NR Notebook PC
  4. If all that did not work, then the internal adapter is faulty. Buy an external wlan adapter:WLAN Adapter WL-167G-£12.90 new
Sep 26, 2009 | Compaq Presario Notebook
Toshiba Satellite
Make sure the switch that says "Wireless" on the outside of the laptop is turned on.
Aug 27, 2009 | Toshiba Satellite Pro L300-EZ1501 Notebook
Hp pavilion tx 1000 wireless card not detecting,reinstalled xp ,vista,changed many card.plz help
Try reseating the WLAN card
Check for WLAN driver in device manager, if you have updated driver.
Try swapping with the known WLAN card if you an options, if not change the WLAN card
Jul 06, 2009 | HP Pavilion tx1000z Notebook
My inspiron 1501 informed me that the WLAN IEEE 802.11 WAS MALFUNCTIONING.WHAT TO DO?
The WLAN may be faulty or the driver got corrupted.
Reinstall the WLAN driver and check the Device Manager to see it the WLAN is working and enabled, if it is then configure it to match your wireless router settings.
If this doesn't work the most likely the WLAN card is faulty.
To get a wireless connection again, purchase a PCMCIA wireless card and insert it into the PCMCAI slot, install the driver for this wireless card and configure it to match your wireless router settings.
Jul 04, 2009 | Dell Inspiron 1501 Notebook
WLAN not being detected in HP Pavilion tx1210 laptop
first of all is the wireless adaptor recognized under the device manager?
no, you need a new mini pci wireless lan card
yes, the wrong driver is installed, the windows utility is not enabled
Mar 02, 2009 | HP Pavilion tx1000z Notebook
Notebook won't connect to network
1) Verify if Wi-Fi WLAN interface of your notebook is OK.
1a) Check whether HW switch is ON and the wireless system service is running.
1b) Switch on the WLAN Access Point (router) SSID broadcasting.
1c) Scan WLAN networks by the notebook. Can you see your home WLAN? If not, there is HW or SW problem in your wireless adapter probably. If WLAN is visible, continue by next steps.
2) Remove all WLAN security on both sides (AP and notebook): Authentication = none/open, encrytption = none.
3) Activate DHCP server in the router and set the dynamic IP assigning on WLAN notebook interface.
4) Select your home WLAN SSID in the list and try to connect.
5) Wait and check status. Is WLAN connected? Does obtain the notebook an IP address?
6) In success case set the WLAN security.
Dec 20, 2008 | Computers & Internet
Wlan disabled
If you have vista click the start button and in the start search type "hp wireless assistant". It should show up in your list while you type it. Click on it. Once the assistant box shows up, click on "properties". A "settings" box should show up. The main one you need here is "independant controls for installed wireless device". Check that box. The other ones are icons and indicators that you can check at your discretion. If in doubt, check them all. Hit the "apply" button. Then in the upper right hand side of the box hit the button that says "turn on". This should activate the device and if you have a light up indicator on your computer, it should change color or light up. That should do it. Kind of weird how it gets to that point.
Feb 26, 2008 | HP Compaq Presario V2000 Notebook
Wireless not recognized after windows xp clean installation
I'm seeing two different wlan drivers on the site, Intel WLAN, and Ralink WLAN. I would verify you are trying to use the correct one.
Jan 10, 2008 | Averatec AV1020-ED1 Notebook
HP Pavilion dv1000 Notebook Logo
196 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
