I cannot connect to the Internet via a wireless connection on a laptop, and am only able to ping in safe mode. A Time-Warner expert believes that it is a virus or Trojan, but I have been able to connect at another location. Weird. Any suggestions would be appreciated.
  • 3 more comments
  • Operadiva Oct 04, 2008
    KI am running Windows XP Home. I have three computers, two notebooks and a desktop. One of the notebooks and the desktop connect perfectly well. The problem only affects one notebook. No, none of the internet options has been changed. Yes, I get a proper IP address, but the system will only ping in safe mode.
    I will try the programmes suggested to check for virus/spyware/malware.
    Thank you.
    But if I cannot connect to the Internet -- the problem with this computer --- I cannot download any virus/malware/spyware programmes!! I have Norton 360, and it indicates no problems.
  • Operadiva Oct 20, 2008
    My apologies for my incivility. I was called away suddenly, and this problem was shoved down the priority list.
    Thank you all for your help. This is a fabulous resource, and I am most grateful for your willingness to come to my aid.
    Time-Warner (reluctantly) discovered that their router and/or modem were at fault, and replaced them both with one nifty new unit. All is now well.
  • Art Grutman May 11, 2010
    Has this always been a problem on this laptop, or did it just begin recently?
    How familiar are you with windows troubleshooting?
    Have you ever, or do you know how to modify the registry?
    This way I'll be able to guide you appropriately.
    I would suggest that you first start by obtaining some utilities from the internet. (use your other computers and put them on a flash drive or cd)
    Go to www.sysinternals.com (now a Microsoft website) This third party company made some really nice utilities that Microsoft ended up buying them out for. Specifically, you want to download ProcessExplorer (A really great process viewer) and AutoRuns (a really great system configuration utility) Both of these can work together to help troubleshoot problems, but you need to have a little experience. If you don't, we can start by at least using AutoRuns and what you would want to do is go through the list it gives you and write down everything that does not say Microsoft in the publisher/author field. Specifically we are looking for processes and programs that either are made by companies we know make spyware/adware, or better yet, publisher fields that are left completely blank. Most virus developers will not go through the trouble to fill those fields out. Be carefull not to delete any entries in that list, nor do you want to uncheck any without first determining whether or not they really are issues.
    If you are familiar with processes, you can open ProcessExplorer first, then AutoRuns. If you find something suspicious in AutoRuns, you can right click on the item, and then click on either properties or info and it will ask ProcessExplorer to determine whether or not the program is currently running. If it is, that process will be shown to you for further investigation. You also might want to check the 'Winlogon' and 'explorer' processes and see what threads are running underneth them. Do this by right clicking on the process from inside ProcessExplorer and clicking properties. Then click on the 'Threads' tab to see all threads running inside that process. Many times, hackers try to hide processes by buring them under parent processes. Right click on each thread and check it's properties. Take note of which ones are not Microsoft programs and especially those that have no identifing information.
    I'll wait for further info before we go any further.
    Also, a really nice utiliy, if you can get a hold of it, is 'Hirens boot CD.' You need to know how to download it and burn the image on CD. This cd has some nifty utilities that you can use to try to restore any settings that may have been damaged by malware.
    When you say 'via a wireless connection,' does this mean that this problem is only limited to the wireless connection? Can you access the internet via a direct cable connection?
    I also need some more info on:
    What OS are you running? Windows XP (home/pro), 2000, Vista, OS X, Linux
    What browser are you testing with?
    Are you connecting directly to the ISP provided equipment, or do you have your own in between?
  • 781 Answers
Post more details
in the mean time try this:
1. if it's a virus or malware clean up your computer (use AVG or avast for virus clean up and Spybot S&D, adware se, and a-squared for other malware.. all of them are free). make sure you update the programs and run them 1 or 2 times depending how contaminated your system is.
2. repair your internet adapter's connection:. in network connections, select right click your network adapter and select repair.. see if you get an valid ip address different from 0.0.0.0
3. Do you have access to your access point / router on the network you have problems with.
you need to have the SSID for your Access point (router) and a key or passphrase (if setup) if you don't have those check with your network administrator
4. did you mess around with the internet options?.. open your browser go into tools, internet options, security tab and reset your internet settings for the internet zone to default.
5. check you are within range and that your wireless adapter is on.
good luck and post more details to be assisted further if needed.
Posted on Oct 04, 2008
  • Francisco Cortes
    Francisco Cortes Oct 04, 2008
    goraventech, testing suggestion is excellent..
    I just wanted to suggest the following
    if the wireless adapter is a pci card test that on the other laptop if possible to rule out the possibility of hardware malfunctioning.
    when you are saying you can ping in safe mode.. what are you pinging? is another computer in your network or is it another computer/server outside your network?... if it's outside your network it resolving ip into name addresses?
    if it is another computer in your network your wireless adapter may be ok.. so check
    a. your access point configuration
    b.your firewall settings on your system and one your router
    c. your antivirus configuration for internet settings.
    is the other laptop using norton 360 as well?
    has it ever work before? if yes try to remember any new installations and use system restore or manually uninstalled to go back to previous configuration.
  • Francisco Cortes
    Francisco Cortes Oct 20, 2008
    that was weird... If the router or the modem were at fault what you would expect is for no internet connection to be avaliable anywhere.. unless is specifically the router.. and the plugged where your computer problem was connected to, or if the computer was connected to the access point wireless probably the antennae on the access point/router was the problem (that if the other 2 computers were wire connected)
    just for feedback sake.. could you note what type of setup you had?? were all the computer wired plugged into the router?, you had a modem/router? or router and modem...?
    also.. that's why the more specifics you give the better the chances to get a more solid solution otherwise we are all just gessing!! and shooting in the dark.
I've connected my Router to switch and through switch i connected two wireless Netgear N150 router where my router is gateway. My Problem is I can ping from Laptop to Router gateway but unable to ping from...
The two wireless routers THINK they are directly connected to the Internet and they prevent the WAN side ports from being pinged so hackers can't find out you have a device on the Internet. The devices will let you to the Internet without any problems, why do you need to ping from the router to the WiFi routers anyway. all of that is your internal network....
One thing that might fix this is if you can put the WiFi routers in BRIDGE mode. Some routers will let you do that, some won't. Don't put the router that is facing the internet into bridge mode. hackers will be able to see your whole network.
Sep 12, 2013 | Linksys EtherFast Cable/DSL Router
Can,t conect to the internet via wifi
When was the last time you could connect to the internet via wifi? You could do a System Restore back to that time.
And/or, connect to the internet via an ethernet cable and update the BIOS on your computer.
And, make sure you can find your current wireless driver on the internet; delete the wireless driver, from your computer (it might be corrupt), while in safe mode. Then restart and download the current wireless driver in normal mode.
May 19, 2011 | Computers & Internet
Can't access internet wirelessly after 360 install
Try this, start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 15, 2010 | Norton Internet Security 2005...
My computer shows connected but I can't get online I have a wireless netgear card in the laptop and a linksys router. I can see the network, and the computer shows connected with the icon at the bottom and...
check that u have properly configured ip address
gateways and dns
try pinging gateway if u get ping then try pinging ur dns servers.
if u get ping from dns server ur brouser might got curropt if not you need to reconfigure ur wireless router.
Feb 06, 2010 | NetGear (IM-WG511T) Wireless Adapter
Able to connect on wireless but cannot ping router
from the comments and posts listed, it does sound like a problem with the wireless on the router. I second Ersatyle's recommendation to reset the router and reconfigure it from scratch, making sure the internet works fine via cable before trying wirelessly, as this will help to eliminate any issues connecting to the internet itself as opposed to the wireless.
May 26, 2009 | Siemens Efficient Networks SpeedStream...
I have Time Warner Cable for internet and Vontage cable for my phone thru my internet. I'm trying to connect a Linksys router for my wireless laptop. I also have a Netgear switch connected to Time Warner...
If you purchased a Linksys wireless roter then you shoul not need the switch anymore-
Try going directly from your time warner modem into the Interner/WAN port on the router and then plug your desktop computer and the vontage phone system into 2 of the ports on the router. After everything is hooked up you will probably need to power cycle for it all to work correctly.
Please power cycle in this order:
Reboot modem - then Router- then Vontage phone system.
Hope this helps
Apr 09, 2009 | Linksys -Cisco Wireless-G VPN Broadband...
Cant connect to the internet.
Click on Start and type CMD. Open CMD and type ipconfig. Check out the IP address V4 for the Local area ethernet adapter or wireless area adpater depending on wireless or wired connection. Any ip address other than of the class 169.254.x.x shoud be considered good. If you have an IP address is any other number other than the above you have a good IP address. to test the internet connectivity type PING www.google.com. If the results are Packets sent 4 Recieved 4 Lost 0 then the issue could be due to Internet Explorer bing corrupt or a firewall blocking the internet access. Power off the computer. Power on the system and as soon as you see the Dell logo please tap the F8 button 3 - 4 times. You'll get to teh Advanced Windows boot option screen. Select safe mode with networking and see if the internet works in the safe mode. If yes then it could be the firewall. Uninstall you antivirus and check.
Apr 02, 2009 | Dell Studio 1537 Laptop
Connetion error
Check for drivers regarding wireless and disconnect the internet and first connect your laptop via wireless and then connect the internet ping your modem and router it should get a reply
Mar 03, 2009 | Computers & Internet
Ping is high at closest server. But low at servers much further
hello there i have built many wifi networks and install networks for server hosts.
I would try setting your port forward to the correct port that xbox live runs on.
also uncheck Qos (quality of service) this will throttle bandwidth, you want this off.
Jan 26, 2009 | Microsoft Xbox 360 Console
No wireless connection
The problem maybe that, you need to set up the router first via an RJ45 cable and enable wireless connections, as you already have said, but probably left the cable connected. You need to then unplug your RJ45 cable from the laptop and router as you cannot connect both wirelessly and wired at the same time, as the router is trying to give the same IP address to two different connections. Your laptop should be wireless enabled(check in the device manager, as it maybe dissabled, as some manufacturers do by default.) Do not have your router WEP or WPA encrypted until you have set it up. Your laptop should also find your connection and probably others in your neighbourhood as it should auto find other connections. Right click on wireless connections in your connections folder and see if it has found your connection then click on connect. Hope this helps
Dec 01, 2006 | NetGear DG834G 54 Mbps 802.11g Wireless...
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
