I need my pass phrase to connect to my wireless service
    Scholar:
  • 155 Answers
Who manufactured your wireless router? You need to call them. If you have a 2wire router, it's the 10-digit code at the bottom the router/modem.
Posted on Oct 04, 2008
How do I prevent my neighbor from using my wireless router?
If you do not have any wireless network security enabled on the router, your neighbor can see this SSID and connect to the network without authorization. While this is generally frowned upon as being unethical, it is technically not illegal as you have "made the network available" by failing to secure it. The easiest way to secure the network is through the use of a WEP key or a WPA pass-phrase. WEP keys are generally 5, 10, 13 or 26 randomly generated characters long. WPA pass-phrases are just that - a phrase such as "The sun is yellow". Either method will prevent unauthorized users from accessing your network. Only those individuals who possess the key or pass-phrase are granted access.
These options is located under the Wireless > Wireless Security tabs from within the router administration.After login you can change the password.
If you need any kind of technical assistance you can contact support cell at here
Jan 22, 2013 | Belkin Computers & Internet
Setup 64bit pass phrase on Belkin router. All wireless devices say,
Do your other devices support 64bit wep, and are you selecting that as your encryption type on each device. For example I know on my cellphone I have to specify the type of encryption that is used. You might also log into the router, just to double check the encryption type and the pass phrase (even if you are spelling it right).
Jan 31, 2012 | Belkin Computers & Internet
Wpa2 pass phrase
You'll have to connect to the router through a wire, log into ints web-based configuration page (192.168.1.1 by default) and see the wireless security from there in the "Wireless Security" section.
good luck,
Majdi
Dec 28, 2011 | Linksys WRT150N Wireless Router
I need a pass phrase or network key to be able to log on to my wireless internet connection for my laptop.
Good day. If your looking for your looking for the pass phrase or network key for your router. You can try to do the following.
1. Check for a WEP key on the router itself. Usually it is on a sticker located under the router or at the back of it. 2. You can go to the router page using your internet explorer or mozilla > just type in 192.168.1.1 on your browser > it will ask for a username and password > username: leave it blank password: admin > then go to wireless setting > then it will show you your WEP or WPA or Wireless key > Dont be confuse the wep or wpa or pass phrase are all the same > then just type it on the space where its asking you to type in a pass phrase and that should work
3. If still you can locate it you can contact your internet service providers technical support department and they will be able to walk you through it
Hope this information will be helpful in resolving your concern. Have a great day and thanks for using fixya.
Jun 25, 2011 | Linksys Computers & Internet
Cant connect to xbox live because i cant find my WAP2 pass phrase
You need to re-enter your router settings. Somehow or another your Xbox stored the wrong pass phrase to connect to your wireless.
Apr 18, 2011 | Microsoft Xbox 360 Console
How do I lock my router so others cant run off my wireless router?
Connect to the web-server "inside" the router, and run the "Wireless Network Setup Wizard". Create an SSID, enable 'WPA' encryption, and set a password/pass-phrase. Give the password/pass-phrase _ONLY_ to your family members.
Aug 22, 2010 | Computers & Internet
What is wpa pass phrase while setting wireless printer
WPA with a Pre-Shared Key (PSK), also known as personal. PSK is entered as a pass phrase between 8 to 63 alphanumeric characters in the ASCII format at both ends of the wireless connection. Although PSK accepts a minimum of eight characters, for proper security, it is a good idea to use ample length and should not use a commonly known phrase. This phrase is used to generate session keys that are unique for each wireless client.
WPA pass phrase is a password for the wireless network to make it secured. You can obtain the WPA pass phrase when you access your router. Check the manual of your router for the address, username and password of your router. Go to wireless settings, you will see ther the SSID or Network Name, Network Key or the Pass Phrase and Authentication (WPA/WPA2/WEP). You can personalize the SSID,Network Key and Authentication. Remeber that for you to connect wirelessly the Authentication and Network Key on the router should match the Network Key and Authentication of the Printer or Computer.
Thanks for using Fixya,
Aug 06, 2010 | Computers & Internet
I have internet with time warner so have linksys router wireless'but when a try to connect to other computer don,t work
First, check to make sure that you can get Internet through a wired connection, if you can't then wireless won't work either. Second, if you can, then try connecting to the wireless without using WEP or any security. You can turn this off by going to 192.168.1.1 in your web browser while wired to the router from your PC and go under wireless security. If you can connect from an unsecured access point then set up a WEP key with a pass-phrase and when you are asked for the pass-phrase from the PC use the the hex key 1 that is generated by the router instead of the pass-phrase. You should have no problem connecting. Thye wizard that comes on the configuration CD will not set up your wireless correctly, you really have to configure the system using the IP.
Oct 01, 2009 | Linksys Wireless-G Broadband Router
I have a wireless Netgear router. Everyone around
depending on your type of netgear router, the way you enter the setup is different. I use a netgear router and th emeens of access is to type in your web browser http://routerlogin.com/start.htm
Your internet provider does not have anything to do with your local security settings.
you will need to go to the wireless settings link to choose a security type. I recommend you to use at minimum WPA-PSK(TKIP) You will then choose a pass phrase of 8 characters. This will stop the unauthorized access.
You will be asked for the pass phrase when connecting to your network.
If you need any other help, please just reply.
Sep 03, 2009 | Computers & Internet
My neighor stealing my signal
You need to encrypt your wireless signal. Here are some instructions for getting in to your router's control panel.
Once you manage to log in, find the firewall region or wireless security region. Make sure to encrypt your wireless connection with the WPA-PSK authentication method using the TKIP encryption. Make sure to write down your pass-phrase, as you will need it to connect to your wireless connection.
Jan 31, 2009 | NetGear WGR614 Wireless Router
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
