Question about Lite On Televison & Video
I DO NOT KNOW HOW TO FINISH A DVD ONCE I HAVE RECORDED IT please tell me what to do or where to go to finish so the dvd can play on other players. Thank You, Carla Ferrigno
  • 10,594 Answers
You need to Finalize the disc. This option will be available in dvd recorder menu.
If you need further help / info, please post model and brand of dvd recorder to help you out.
Posted on Oct 04, 2008
What is the difference between a DVD+RW and a DVD-RW.
DVD-RW
It is the re-recordable version of the DVD-R. To use this type of media you will need to buy a DVD-RW recorder. The DVD-RW recorders usually record DVD-R, CD-R and CD-RW media, too. Similarly to what happens to DVD-R, DVD-RW disks can be played in newer commercial DVD players without any problems. Older commercial devices cannot recognize the media, refusing to play the disk. To play a DVD-RW disk, commercial players need the disk to be finished. After finishing the disk, you can only record new data in it by reformatting it, which makes you lose all the recorded data.
DVD+RW
It is the re-recordable version of the DVD+R and everything that was said about the DVD+R is valid for the DVD+RW. Only the newest DVD players play movies recorded in disks using this format. There are recorders on the market that can record both DVD-RW disks and DVD+RW ones. These recorders are called DVD?±RW. Similarly to the DVD-RW, the disk needs to be finished to be played in commercial DVD players, and to record new data in the disk after having finished it requires reformatting it, which makes all the data in it to be erased. DVD+RW recorders are usually capable of reading DVD-RW disks (but not of recording them) and vice-versa.
There you are.
Aug 22, 2011 | Acer Computers & Internet
Allthough The DVD's I have were made on the DRVCR900, they now cannot be played on it, I'm thinking that the finishing process never took place in order to code it to play on all devices, is there...
Finishing / finalizing DVD should be on the DVD recorder that you recorded previously..
Put it back in..
go to MENU
and look for FINALIZE title under RECORDING menu..
and select it OK ,let it finalize..then you can play it in any DVD player..
one note ..do you know that this recorder can only record to DVD-R
DVD-RW discs...as Write support..not the ones +R/RW
Hope this helps!..otherwise let me know..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 12, 2011 | Broksonic DRVCR900 DVD Recorder/VCR
I record a program, I can play it & see it on the same recorder, but, If I play the DVD on any other DVD Player, an error message says " Improper Disc" or it won't read the DVD. What...
After you finish recording you have to finalize the disc before you can play it in another DVD player.The owners manual will have a section to tell you how to finalize the disc. WARNING!!! Once you have finalized the disc you will no longer be able to record on it. If this helps please rank me and leave a comment. I do not get paid in any way but I like doing this and want to make sure I am helping. I am adding a link where you can download the manual in case you lost it.
http://www.instructionsmanuals.com/modelo-2819-en-DVD+recorders.htm
Dec 18, 2010 | Sanyo DRW-1000 DVD Recorder/VCR
CAN VIEW THE DVD ON A COMPUTER OR THE DVD RECORDER BUT NOT ON DVDS PLAYERS BOUGHT BEEFORE THE RECORDER
This is quite common of older players. Some only work with DVD+R discs and others with DVD-R discs.
Some player also does not read recordable discs (an early form to try prevent piracy)
Also make sure if recorded on your Recorder, that the disc is finalized before you try to play it on an older player. (See your menu / manual on the recorder for the procedure)
Feb 28, 2010 | Sony RDR-VX515 DVD Recorder/VCR
When i record on go video dvd it only works on go video dvd player,not on other dvd player i recorded on _r and+r dvd
After you finish recording goto setup, DVD menu, and finalize the DVD this will allow it to be played on other players.
Nov 10, 2009 | GoVideo VR3845 DVD Recorder/VCR
Cannot play my recorded DVD video on other dvd players
try using a DVD burning Xpress 3.31.it will give you the desired picture quality and will play on any DVD device
Sep 10, 2009 | Toshiba DVD Player
Recorded discs wont play on an other dvd player
you have to finalise the disc when finished recording then it plays on any dvd player
Feb 15, 2009 | Philips DVDR3380/05 DVD Recorder
After recording the DVD player, wont play on any other player
I have seen this on other players as well. What happens is the media your recording on is either too slow for the player and the player is recording faster than the media is supposed to handle. For some reason it works on the machine it was recorded on but nothing else.
Solution: Get media that matches the speed of the player.
If this is not the solution let me know I will get you one.
Rob
Jan 09, 2009 | Sony RDR-VX525 DVD Recorder/VCR
Recorded dvd
You are probably having an issue with the discs rather then what you are trying to play them on.
The discs need to be finalized before they can be used on another player.
  1. Put the disc in the drive (the ones you have already recorded)
  2. Press SETUP on the remote
  3. Select - Disc Edit Press OK
  4. Select - Finalize Press OK
Wait until it is finished then try to play them on another player.
Apr 04, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Dvd-ram 4.7gb
DVD RAM discs don't need finalised, hence its not an available option.
They will play directly on other players -*** BUT*** ONLY DVD
RAM players.
Don't expect your RAM disc to play on a normal
DVD+/-RW DVD +/-R device. Its not going to happen unless the
device supports DVD RAM also. If it does, it will play your RAM
disc once you've finished recording in your own DVD RAM
recording unit. Pop it out of your unit, straight into the other, and
the jobs done.
Nov 02, 2007 | Panasonic DMR-ES10 DVD Recorder
Televison & Video Logo
50 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
jason
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
