Question about Vacuums
Oreck XL3610HH I would like to receive the wiring schematic via email attachement so that i might be able to read it. The one posted is great but i cannot get any detail from it. Thanks so much! 1seaeagle@comcast.net Lee
5 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Wiring Schematic
Should
Posted on Mar 30, 2008
Agent Don
  • 310 Answers
SOURCE: Oreck XL
I would advise you to ALWAYS to FIRST UNPLUG THEIR VACUUM before beginning any service procedure. The motor has 5 wires to the motor as stated in the Oreck owners manual, tow are for the headlights, one is a ground wire, and the other two are for the motor. There are two screws that hold in the Oreck motor and a good suggestion is to use tape the wires leads and mark the wires so that you will not make a mistake as you take it apart and reassemble the motor. That way you will not make any mistakes, whether or not you have wires for a headlight or not, the rules are the same. Also refer to the owner’s manual schematic and the exploded view. Questions? 1-800-989-3535
www.Oreck.com
Posted on Apr 09, 2008
reddevil6
  • 1673 Answers
SOURCE: I Need a Wire Diagram for my Oreck XL3600HH!!!
I emailed that diagram to you, hope it helps.
Posted on Apr 15, 2008
reddevil6
  • 1673 Answers
SOURCE: Please send Oreck schematic to: kevinrntz@aol.com
Do you want me to email you the diagram, if so, I need your email addy.
Posted on Oct 02, 2008
reddevil6
  • 1673 Answers
SOURCE: Oreck XL upright
I just sent you tge diagran to your email, hope this will help.
Posted on Oct 18, 2008
Wiring schematic oreck orbiter
Would you please email me the wire diagram for the Oreck Orbitor xl floor machine? I had to bring it on a plane, which meant that the handle had to be removed. We need to know where the blue wire goes. Thank you!
Apr 28, 2014 | Oreck Orbiter Floor Machines ORB-500,...
Sparks coming from under oreck vacuum. looks like its coming from motor brushes.
Probably need to have that serviced at a repair shop. They can tell you whether or not you need a new motor or a fan blade kit.
Feb 21, 2013 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL upright
Oct 18, 2008 | Oreck UPR014T XL Pro 14 Upright Vaccum...
Oct 02, 2008 | Oreck XL21 Bagged Upright Vacuum
Clear oreck schematic
Here is Oreck's motor wiring diagram, if it isn't big enough to make out, give me your email addy and I will send it to you.
Oct 01, 2008 | Oreck XL21 Bagged Upright Vacuum
Apr 14, 2008 | Vacuums
Wiring Schematices
I had the same problem after not paying attention to the connections when replacing my motor. I spent days searching for information and only found several non-answers with small photos that no one can read.I contacted Oreck for wiring information. They explicitly stated that they can't provide any wiring information for safety and liability reasons.
I found the Ametek schematic which shows the LINE and TAP locations on the motor.
Note: I have a 2600HH XL with 2 headlights.
Connect as follows:
3A, LINE: White lead w/piggy back terminal from light harness #1 & white lead from the power harness to the piggy back terminal
2A, TAP: Black lead from light harness #1
3B, LINE: White lead w/piggy back terminal from light harness #2 & black lead from the power harness
2B, TAP: Black lead from light harness #2
Mar 31, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL
www.Oreck.com
Vacuums Logo
97 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
