To install right bluetooth device in my sony lap top
By mistake I deleted my blue tooth now I install tosiba blue tooth device but is not working
  • Exidous
    Exidous May 11, 2010
    Did you install both the driver and the software? what is the model of the laptop and the os?
I hv brought a bluetooth device for my pc but i don't know 2 instal it. PLEASE HELP.
Posted on Oct 13, 2008
How to enable bluetooth in sony laptop model: VGN-FZ430E
Posted on Oct 08, 2008
  • sanjith1234 Oct 08, 2008
    sony manufacturer
    Model: VGN-FZ430E
How do I pair my ;Jabra A335W Blue Tooth,to my;Windows 8.1 ASUS 2014 Lap-Top?
http://www.youtube.com/watch?v=C5koqNKSjB8
I could try and explain it but this video link below explains it reaaly well
http://www.youtube.com/watch?v=qUtvbRSx00A
laptop has to have bluetooth ability if it doesn't get an usb bluetooth adapter
Nov 02, 2014 | Jabra BT350 Bluetooth Headset Headset
Code for sony dr-bt100cx bluetooth
Hi, when you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope that helps...
Thanks for using fixya.
Nov 25, 2010 | Sony DRBT100CX Bluetooth Headset
Bluetooth not working in sony W580i phone
HOW TOCONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
After attempting on this process, if doesn't work,that means thee blue tooth is corrupted and to restore bluetooth, you will to flash the phone. Flashing the phone will restore back blue tooth.
You can use this links to see how to flash your phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
Take care.
Jul 03, 2010 | Sony Ericsson w580i Cellular Phone
Bluetooth is not found in the control panel of my laptop
goto start and type bluetooth in search...if bluetooth drivers are installed ull get some icons like bluetooth, bluetooth devices etc.....try clickin bluetooth devices.....n u can try to connect with ur mobile.....if it doesnt show anythin u may have to install bluetooth drivers....hope this helps...
Mar 07, 2010 | Lenovo ThinkPad R61i 14 inch widescreen...
I have enstalled a blue tooth on my acer aspire
Uninstall the software and remove the bluetooth dongle. Reinstall the software and DO NOT connect the hardware until the software asks for it.
Aug 01, 2009 | Acer Aspire 5535-5050 Notebook
How do i turn the bluetooth on in my computer acer aspire 5520
Does it have blue tooth? Click "Start", "Connect to", "Blue Tooth", If that does not work, go to "Control Panel", then it should be there somewhere...
Jan 18, 2009 | Acer Aspire 5520-5908 Notebook
How do I turn bluetooth on and connect a Mobile phone to a Acer Aspire 5710G
Windows Mobility Center includes Acer-specific settings like Bluetooth Add
Device (if applicable), sharing folders overview/sharing service on or off, and a
shortcut to the Acer user guide, drivers and utilities.
To launch Windows Mobility Center:
Start Windows Mobility Center from the Control panel
Start Windows Mobility Center from the Accessories program group in the
Start menu
You should be able to turn on blutooth from there.
Please let me know if this helps.
Mar 17, 2008 | Computers & Internet
Blue tooth device is not working
hi,
check if your device is enabled, you can do this by ---
right click my computer..-> properties--> hardware tab--> device manager --> right click on the blue tooth icon and clcik properties. --> check if enabled..
if it is enabled check if bluetooth is enabled at startup { type msconfig in RUN in start menu, click startup tab..check if it is enbaled in startup}... or else you have to manually switch on bluetooth each time u intend to use... hope it helps.
hope to get rated as helpful...
regards
bzoy
Dec 31, 2007 | Computers & Internet
Photosmart 3310 is on network but not recognized wirelessly
Sounds like another Vista Bug, i would check the HP site for this issue and if its under warranty, contact HP. If you have alot of Blue tooth devices hooked up, it may be that its trying to use another device in its place or the signals are getting crossed, im not positive.
Its like when you have to many network drives all hooked up and you plug in a USB device, Windows pops up those anoying bubles saying its detected, but in My computer it doesnt show.
So bassically you have to right click my computer, manage, disk management listed uder storage, right click on the device or drive and change the drive letter to something like " W" or " Z" or anything not in use.
It may be a siomilar case with your bluetooth, youo may have to much stuff connected. Try redoing everything like you have so many other times before, and then limiting how many bluetooth devices you have connected at the same time. see if theres a difference.
Hope this helps.
Dec 25, 2007 | HP Photosmart 3310 Printer
Bluetooth broken
dear,maybe its because of bluetooth recieving list saturation. so delete all previously detected bluetooth devices
regards
dont forget to rate it
Nov 07, 2007 | Sony Ericsson Z530i Cellular Phone
Computers & Internet Logo
320 people viewed this question
David Payne
David Payne
