Question about Canon BubbleJet i550 InkJet Printer
Aligning Print Head Alignment
When printing a photo using Canon Photo Glossy, my pictures print very faded with a greenish/yellowish tint. Based on Canon troubleshooting, I uninstalled driver card, reinstalled it. No difference. I then uninstalled printer, reinstalled, no difference. When aligning the printer cartridge, I see A,B, C, F, G, H, J AND K. I do not see D, E, or I. Also, they blocks are not solid. They are all have lines in the them. So it is hard to determine which is aligned the best. (i.e., +/- 1 or +/- 2, etc.) Any suggestions? Print Head Alignment check fails to print column E
  • 734 Answers
From the front panel (Macintosh and Windows)Press MENU or SETUP (depending on the model).
Press the right ARROW repeatedly until the display window reads Maintenance.
Press ENTER.
Press the right ARROW repeatedly until the display window reads Align Print Cartridges.
Press ENTER. The unit will begin the alignment process and the display window will read Printing Alignment Page
Verify that the alignment was successful after the page is complete.
Posted on Dec 04, 2008
2 Suggested Answers
  • 624 Answers
SOURCE: Aligning Print Head Alignment
Try printing a diagnostic page without the PC, if it prints normal then the problem is on the PC, probably drivers or possibly the printer queue configuration. If it prints the same faded fashion then I would suspect defective or clogged inkjet nozzles. Warning, be very precise with the buttons you push, you are entering the printers diagnostic mode and you can cause problems if you push buttons out of sequence or if you push them too many times. - Start with the printer off. - Hold down the resume button and then hold down the power button - Release the resume button - Press the resume button twice, then release the power button. - Let green light blink while the printer enters the diagnostic mode. - When the printer is done press the function button once to enter the print diagnostic page mode, then the power button once to start the job. - When the page finishes press the power button once to exit the diagnostic mode. Let us know if you have any other questions and please don?t forget to rate the posting.
Posted on Jan 15, 2007
My pictures all seem to print with a yellowish / orange tint; they also seem brighter than on the screen.
Hy, this is a clasic case. you need to replace the printhead. I know this sounds drastic but this is the only way. BTW, I service and sell Canon products and have seen this many times.
May 25, 2012 | Canon PIXMA IP5200 InkJet Photo Printer
When I print a picture it is greenish. All the
You need to make sure you are not using the photo magenta, your printer doesn't use photo magenta and it leaves the prints green. You need also to run the nozzle check print by holding the resume button until the green light flashes twice, and see if all colors are printed. If not you need a new printhead, the part number is on the side.
Nov 11, 2009 | Canon I960 InkJet Photo Printer
All colours and black print faded. Black is a
ANSER #1
Assuming that you are using original Canon cartridges or a brand of Compatibles that you have used before.
If print results are blurred, colors are faded or not printed correctly, the pint head nozzles are probably clogged.
Follow the procedure below to print the nozzle check pattern, check the print head nozzle condition, then clean the Print Head. You may have to do this 2 or 3 times.
If printed ruled lines are misaligned or print results are otherwise unsatisfactory, aligning the Print Head may improve print quality.
Caution Do not rinse or wipe the Print Head and ink tanks. This can cause trouble with the Print Head and ink
tanks.
Note Before performing maintenance
Open the Top Cover and make sure that all lamps on the ink tanks are lit red.
If not, see Checking the Ink Status and take an appropriate action.
Increasing the print quality in the printer driver settings may improve the print result.
Sep 30, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
My printer makes lines through all the pictures i try to print
Make sure your quality options is set for best photo, also change paper to glossy photo paper. Under the maintenance button try to clean the print head and then try a print head alignment. I hope this helps you........Hutch
Dec 20, 2008 | Epson Stylus CX3810 All-In-One InkJet...
Pictures are faded out looking and yellowish
Dear you need to purchase a new print head for the printer as the head is exhausted and since its a good printer its worthy to purchase a print head.
Regards,
Manoj Joseph
+91 9352008418
Jun 18, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
MP780 vertical lines on photos
Hi. the problem is the print head, maybe is clogged or damage, try this remove the cartridges , and the print head and submerge the print head in hot water for 3 minutes, dry the print head and reinstall it, if problem persist replace the print head.
TCT How to remove and clean Canon Printhead
May 02, 2017 | Canon PIXMA MP780 All-In-One InkJet...
Photo printing problems
Try to manually clean the printer head. Take a cotton cloth and dab a little bit of alcohol (like whiskey) and then clean the printer head & the cartridges with it. Do remember it is a delicate process and if you messup, you might damage the printer/cartridges. So be careful & lemme know the result.
Aug 06, 2007 | Canon PIXMA MP760 All-In-One InkJet...
Jan 14, 2007 | Canon i850 InkJet Photo Printer
Canon BubbleJet i550 InkJet Printer Logo
211 people viewed this question
old marine
old marine
