MITSUBISHI VS4502R I need 4 digit code to unlock ?
  • frank642 Oct 05, 2008
    Someone told me press QV then 9 and that did not work.
  • Anonymous Oct 18, 2008
    same problem, cant find an answer
3 Suggested Answers
SOURCE: mitsubishi vs5003r troubleshoot
I found this in another website... i hope this can help you. I'll try too...
Found this on the web, hope it helps.
Thank you for contacting Mitsubishi Digital Electronics America, Inc. We
are pleased to be able to assist our customers via our website. Here is the
information that you have requested:
TV Lock #8
Models:
Color Televisions
CS-20EX1, CS-20301, CS-26EX1, CS-26201, CS-26301, CS-2725R, CS-27EX1,
CS-27MX1, CS-27TX1, CS-27200, CS-27201, CS-27301, CK-27304, CK-27306,
CS-27401, CS-27403, CS-3135R, CK-3136R, CS-31AX1, CS-31FX1, CS-31MX1,
CK-31MX2, CS-31301, CK-31302, CS-3525R, CK-3526R, CK-3527R, CS-3535R,
CK-3536R, CS-35X7, CS-35AX1, CS-35FX1, CK-35FX2, CS-35MX1, CK-35MX2,
CK-35MX3, CS-35201, CS-35201A, CS-35203, CS-35205A, CS-35301, CS-35401,
CK-35402, CS-40FX1
Projection Televisions
VS-40VA2, VS-4517S, VS-45VA1, VS-45VA2, VS-4561, VS-4562, VS-5016R,
VS-5017S, VS-50VA1, VS-50VA2, VS-50VF1, VS-50VF2, VS-50VX2, VS-50VX3,
VS-5061, VS-5062, VS-6017R, VS-6026R, VS-60VA2, VS-60VF1, VS-60VF2,
VS-60VX2, VS-60VX3, VS-6061, VS-7017R
This system locks only the entire TV. The TV will display a screen that
will indicate "Parental Lock ... Now the lock is on" and request the
personal four digit code when the TV is powered on.
IMPORTANT> You must use the original remote control that came with the
TV to release the Parental Lock, you cannot use a remote
that came with a VCR, Audio System or from any other
manufacturer.
1. Depending on which remote came with your TV, press the button at
the top labeled TV,OR set the TV/VCR switch in the upper left
corner of the remote to the TV position. .
2. Press the button on the remote labeled POWER.
The TV will turn on and display an information
screen that indicates "Parental Lock ... Now the
lock is on" and ask for the four digit personal code.
3. Press the #9 and the QV buttons at the same time.
The TV will turn on.
4. Press the button labeled MENU.
The "TV Main Menu" will be displayed.
5. Press the ADJUST UP or DOWN button to move the arrow next to the
"Advanced Features" selection and then press ENTER.
The "Advanced Features" menu will appear and
indicate that the lock is ON.
6. Press the ADJUST button to move the arrow next to the "Parental
Lock" option, and then press ENTER.
The screen will change to indicate "Parental Lock
... Now the lock is on" and ask for the four digit
personal code.
7. Press the #9 and QV buttons at the same time.
The screen will return to the "Advanced Features"
menu and indicate that the lock is off.
8. Press the MENU button twice to return to normal viewing.
The original lock code has now been erased and the lock canceled.
Posted on Dec 06, 2008
tvguy171
  • 106 Answers
SOURCE: Lost 4 digit code for v-chip
Press "QV" and then the "9" buttons on the remote. This will let you change then password. Please take time to rate the solution and let me know if you have any further questions
Posted on Dec 12, 2008
asnowman
  • 788 Answers
SOURCE: I need 4 digit ''input''code a 1990 VS-4501R big screen mitsubishi.
If you have the original remote or at least one with a QV button on your remote it is easy.
When prompted for the code, Just hold down the "QV" and the number 9 together for a bit.
That will unlock the set.
I would then go the the main menu and unlock the set from the menu. Use the "QV" and 9 to get in and turn off the password.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Aug 07, 2009
Used car with a locked out bluetooth system. Dont have the code and have tried all the normal 4 digit codes. Need to reset but dont have the instruction to do so.
There should be a small white sticker in the glove box with a 4 digit code and another series of numbers. This should be your universal entertainment unlock code.
May 31, 2010 | 2007 Mitsubishi Outlander XLS
I need a raidio code for a 2001 mitsubishi galant- Model # MR472958 Serial # 99E55715 Ref # CQ-JB1911LA
Your code is 3053
Use preset 1 to set digit 1, preset 2 to set digit 2, etc
Once the code displayed is correct, push your unlock button to unlock the radio.
The unlock button varies by model, but is always either AM/FM, CD, or TAPE.
There is no penalty for pushing the wrong unlock button as long as your code is correct.
If you have locked out the radio from failed code attempts (radio reads "OFF", you will need to leave the key in the ACCESSORY position with the radio displaying OFF for approximately 1 hour. After which time the radio will revert to CODE and you can enter your code then.
Oct 30, 2009 | 2000 Mitsubishi Galant
MITSUBISHI VS4003R ANY CHANCE YOU CN TELL ME HOW
get to where it asks your code then on the mitubishi remote press QVand 9 at the same time
Oct 04, 2009 | Televison & Video
I need a code to unlock my car radio for a 2000 Mitsubishi Galant, please...\r\nI have the information needed to do so... Serial number : 99224138A MR472958 Thank you so much!
Your code should be 2101.
Use the preset buttons to input the code. Preset 1 scrolls through digit 1, preset 2 for digit 2, etc.
Once the code is set, push the unlock button; depending on model the unlock button will be either CD, TAPE, or AM/FM.
Sep 22, 2009 | Mitsubishi Cars & Trucks
I need a radio reset code for a 2001 Mitsubishi Eclipse. Radi model MR337276 serial #06179043B for Title 4A3AC54H31E016106. Thank you for your assistance
Your Code is 0642
Input the code by pressing preset 1 to scroll through the first digit, preset 2 for the second digit, preset 3 for the third digit, and preset 4 for the fourth digit.
When you have the correct code displayed, press the CD button to unlock the radio. If your radio does not have a CD button, some use the AM/FM or TAPE button to unlock as well.
Please be sure to rate me if I have been of assistance!
Sep 19, 2009 | 2001 Mitsubishi Eclipse
Aug 07, 2009 | Televison & Video
Need radio code
Need code for radio
Model# MR490090
Serial# 99D22887
May 19, 2009 | 2001 Mitsubishi Diamante
Mitsubishi montero radio unlock
I had the same problem after replacing the battery on my Montero. I bought mine used but luckly the pervious owner had written the 4 digit number down in the owners manual. After finding the number, I had to enter it into the radio by using the station preset buttons. If you can't find or don't have it in the owners manual. You will have to get the model and serial numbers off the radio and contact Mitsubishi or another source to obtain the correct code to reset the radio.
Oct 11, 2008 | 1995 Mitsubishi Montero
Car radio and cd player locked
The 4 digit code is entered using station preset buttons "1" through "4". Each time you press one of these presets the appropriate code digit increments from 0 to nine. As an example, say the code is 5193, press the "1" preset 6 times (zero is displayed on the first press, 1 on the second, etc.), press the "2" button twice, the "3" button 10 times and the "4" button 4 times. The code 5193 will be displayed on the unit.
To accept the code, press the CD button and if the code is correct the unit will come back to life.
Jul 28, 2008 | 2002 Mitsubishi Galant
Mitsubishi parental control reset for tv model vs-5061
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Jul 20, 2008 | Mitsubishi VS-50611 50" Rear Projection...
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
Electro Med Services...
