Question about Maytag UMV1152BAS Microwave Oven
Maytagh microwave continouusly runs unless you open the door then stops. I have tried unpluging and doesnt help.
  • gary0514 Oct 04, 2008
    Maytag microwave continously runs. I tried unplugging to reset but still runs once plugged back in. It quits if you open the door but light stays on.
  • Maytag Master
  • 8,968 Answers
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order one from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Oct 04, 2008
Turns on when door is open; turns off when door is shut.
when mine did that it was the door switch had failed
Jan 21, 2016 | In Microwave Ovens
Why does my Kenmore microwave keep running with door open?
there are little fingers on the door that latch it to the microwave when you close it. there is a switch in the microwave that those fingers touch. something must have gotten in there and now the button is stuck. unplug microwave locate switch and try to clean around it to dislodge it. good luck hope this helped.
Apr 02, 2015 | Kenmore Microwave Ovens
When I open microwave oven door . close the door again light comes on an plate spins an wont stop unless I unplug it
Inside the door latch, is a safety feature, that prevents the microwave from operating unless the door is closed. This feature can easily become faulty, or even come with the fault already causing the microwave to constantly operate whenever the door is closed.
Microwaves can be very dangerous in regard to holding HEAPS of voltage within the unit. I recommend getting yourself a new microwave, as attempting repairs on any of the modern units can, more often than not, be far more costly then the price of a new one.
Hope this helps.
Apr 14, 2014 | Hamilton Beach Beach 87108 Microwave Oven
Microwave won't stop running
my microwave door wont shut
Jun 26, 2013 | Microwave Ovens
My ge microwave just runs. It will not stop unless I unplug it.
First you should determine whether it's cooking when it should not be, in this case anytime it is plugged in and the door is closed or open.
Do that by putting a cup of water in a microwave-safe container into the unplugged microwave, shutting the door, then plugging it for about a minute.
Then unplug the oven and check to see if the water is warmer.
If so, you have a shorted secondary relay on your microwave''s control circuit board, and we regularly repair such control units for customers nationwide by mail for $39.95 with a one-year guarantee.
Do that test again by putting the water in, leaving the door open, and plugging the oven in for about 30 seconds or so. If you get any arcing or buzzing or flashing, unplug it.
If it is not cooking, then you need to test further.
If it just seems to be "running" with the door shut, but it is not cooking (as shown in the above tests) then note whether the oven lamp, internal cooling fan and turntable are running when the door is shut, but when you open the door, the turntable and colling fan go off.
This should mean you have a shorted main relay on the board. We can fix that, too.
Differing symptoms would indicate a bad door switch or door switch mount.
Our info file on door switches is here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Also at our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Sep 30, 2010 | GE HVM1750SMSS Microwave Oven
Jvm1870sk04 GE profile microwave will not shut off unless the door is open. Unplugged , pushed off/cancel continues to run with door closed. Any solutions?
Hi, Main control board bad...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave will not stop cooking unless I open door
you have a bad door switch call a tech these things can kill you even if they are unplugged.
Jan 07, 2010 | Amana MVH210W Microwave Oven
Microwave will not turn off. it runs and runs when door is shut stops when door opens but if you shut the door again it just runs unless i unplug it. It will not heat light is on clock works .will not...
This is usually caused by either a bad door switch or a loose door switch mount, or sometimes a problem on the control panel.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
May 12, 2008 | Microwave Ovens
EMERSON MW8773SL
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk If it's NOT a bad door switch, it may be a stuck relay or other problem on the control panel / circuit board. We repair these control panels nationwide for $39.95. For details on the repair service, see our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Mar 23, 2007 | Emerson MW8775W Microwave Oven
Maytag UMV1152BAS Microwave Oven Logo
73 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
sonic boom...
sonic boom...
SHARCNET-USA
SHARCNET-USA
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
