Question about Dishwashers
Dishwasher error 1 - Dishwashers
    Guru:
  • 558 Answers
Let me know the exact model and make, So I can assist you further. Also the exact error code.
Reset the error message as follows: To cancel the error message, turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again. If the fault message reappears, please contact our Customer Service.
Regards
Ellin
Posted on Oct 04, 2008
How do i fix electrolux dishwasher when error code 1 is flashing
Hello friend, thanks for your post!
I see your Electrolux dishwasher is displaying an "E1" error code. "E1" stands for a leak detected which means your dishwasher base has detected a leak. If you can't see a leak you may want to perform a reset on your dishwasher you can do that by disconnecting the power from your appliance for roughly ten minutes.
If that does not correct the issue you may want to seek assistance from a technician. They would need to come out to diagnosis and repair your dishwasher. I hope this information has been helpful. -Matt
Oct 03, 2014 | Electrolux Dishwashers
Electrolux dishwasher giving error code 1?
Good Morning Brian,
I understand that you are receiving an error code 1 on your Electrolux dishwasher, model# EWDW6505GS. Error 1 is stating that water has been detected underneath the tub. Check underneath your dishwasher by taking off the kick plate below the door. If you do not notice any water underneath the tub or any types of leaking, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker for 20-30 minutes. When the time has passed, restore power, and run any cycle. If you are still receiving error code 1, I suggest you contact your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
May 07, 2014 | Electrolux EWDW6505GS Fully Integrated...
Error code E:14 Siemens Dishwasher - stops after 1 min of cycle
It might be helpful if you provide the full model number of the Siemens dishwasher. Most likely E14 error has something to do with water flow sensing. Check if your mains water pressure is ok (tap under sink is fully open). But can provide more details only if you can tell me the model number.
Apr 03, 2014 | Siemens Dishwashers
LG DWLD4080T dishwasher shows HE error message after 10 mins What is the problem?
"HE" is a "HEATER ERROR"
These are the possible causes for "HE" error:
1. The Circuit of Heater is troubled.
2. The Thermistor is troubled.
3. The Heater is shorted.
4. The Relay Circuit is troubled.
The Possible solutions are:
1. Repair the Circuit of Heater.
2.Replace the Thermistor.
3. Replace the Heater.
4. Repair the Relay Circuit..
Apr 01, 2010 | LG 24 in. LD-12BW5 Free-standing...
What is error 1 message mean?
What is error 1 When you start a dishwashing cycle, the dishwasher fills and then shows the error message when it should go into the wash mode
Dec 09, 2009 | EuroTech 24 in. EDW174E Built-in...
LG Dishwasher LD-2050WH with HE error code
This is a heater error. The cause is either a bad heating element or bad thermistor (the thermistor is part of the heater assembly). The heater assembly will need to be replaced.
Jan 14, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Error message on Smeg dishwasher
i have error 1 on our dishwasher any clues ?
Apr 23, 2007 | Smeg 18 in. DWF410SS Slim-Line...
Dishwashers Logo
95 people viewed this question
Top Dishwashers Experts
