HOW DO I FIND THE SERIAL NUMBER AND DECODE A PIONEER CAR RADIO MODEL DEH-M6106ZH
  • 11 more comments
  • CENPUGH Oct 05, 2008
    I NEED TO KNOW HOW TO GET THE SERIAL NUMBER OF THE SET .
    NOT WHAT I ASKED FOR.
    HAVE ALREADY VISITED THESE WEBSITES, I NEED ANSWERS TO MY QUESTIONS.
    NUMBERS SHOWN ON RADIO ARE NOT THE SERIAL NUMBER REQUIRED. I AM TOLD THERE IS A WAY TO READ IT FROM THE RADIO BY USE OF THE BUTTONS ANYBODY KNOW HOW TO DO THIS?.
    NO COMMENT
    WILL TRY THIS TOMORROW CAR NOT AVAILABLE AT MOMENT. THANKS CEN.
    THANK YOU FOR YOUR COMMENTS BUT SEEING I HAVE PAID FOR ADVICE I,M HARDLY GOING TO GET SOMETHING FOR NOTHING.. YOU FIRST MENTIONED RUBBISH.
    THANKS
    THANK YOU.
    I REFER YOU TO HONDA MAIN AGENTS. THATS ENOUGH ADVICE FROM YOU .THIS IS THE FIRST TIME I HAVE USED THIS SYSTEM AND DONT FULLY UNDERSTAND IT WHEN I ENTERED NO COMMENT IT WAS SO I COULD MOVE ON TO OTHER REPLIES HOWEVER IT WOULD APPEAR YOU TOOK UMBRIDGE SUIT YOURSELF.
    THANK YOU.I HAVE TAKEN THE RADIO OUT OF THE CAR AND NOTED ALL THE NUMBERS AND REFITTED THE RADIO ONLY TO FIND NONE OF THEM IS THE SERIAL NO THE AGENTS NEED TO SUPPLY THE CODE. THE CAR IS OFF THE ROAD AT THE MOMENT SO I CANT TAKE IT TO THEM AND DREAD HAVING TO TAKE THE RADIO OUT AGAIN TO SEND IT AWAY,. HENCE MY ASKING FOR ADVICE
    THANK YOU VERY MUCH .WILL LET YOU KNOW.
  • CENPUGH Oct 06, 2008
    I followed your instructions but it just gave the word code, still it was worth a try.thank you
    Brigadier General:
  • 3,614 Answers
Try this steps:
With key in off position:
  • Press and hold the "M" button on radio.
  • While holding "M" button turn key on and turn on radio.
  • Radio serial# should show on display.
  • Write this number down.
  • You should double check your radio serial number for accuracy, as incorrect number will delay your radio code retrieval process!
let us know...
regards,
micro
Posted on Oct 05, 2008
    Master:
  • 763 Answers
Serial should be on the item and located sticker near the item name. an example for this like my camcorder, the serial number was on the bottom of it. in your case, the serial number should be on the back of the stereo player.
CHARCOIS
    President:
  • 1,952 Answers
Pioneer 9000RDS, DEH2006, DEH2016, DEH66, DEH-M6017ZH, HONDA DEH-M6067ZH, DEH-M6106ZH, DEH-M6117ZH, DEH-M6356ZH, DEH-M7127ZH, DEX-77, KE-91ZBM, KE-92ZBM, KEH5080, KEH6080, KEH8080, KEH9080, KEH-M1066, KEH-M8246ZT, KEH-M9741ZT, KEX500, KEX900, KEX-M700, KEX8176ZT, KEXM9136ZT, KEXP8256ZT
the repairs forum knowledge base - Service Manual free download ...','fileshare.eshop.bg');">http://fileshare.eshop.bg/forum_search_wrap.php?start=2400&searchtext=b...
PIONEER DEH-2096 CODE PIONEER DEH-66SDK CODE 0000-9999 PI66XX PIONEER DEH-86 CD PIONEER DEX-66 CODE 4 dig PIONEER DEX-77 PIONEER KEH-5080SDK CODE 0000-9999
  • 13,433 Answers
The serial number, reads in a sticker on your hardware, it may be on the top, bottom, sides or back.
For example, this is not your device, but just a example, computer cd drive
    Master:
  • 479 Answers
The exact serial number of your device is
Serial NO. AH009062
  • tech gurus Oct 05, 2008
    Code Entry as Follows:
    Switch Radio On - Display Shows
    " CODE "
    Enter CODE in the order it is read -
    Enter Code 12345
    Press Preset 1 then 2 then 3 then 4 then 5
    The Code will Enter Itself Automatically
    or
    press five 00000instead of 12345.
    you can also try.only 1234 or0000 instead of five numbers.
    some of them should click .
    keep updated for more help.
    we will be waiting.
    Please note that code entry is only possible if the display shows "CODE". If the unit is Codelocked, then leave the unit switched on for two hours to reset. it will automatically start working.mostly it happens.
    try and tell.
  • 1,031 Answers
All you have to do is take a flathead screw driver(preferably rapped in a thin rag to prevent scratching) and pry off the garnish that surrounds the radio (and sometimes heater control). There will be anywhere between 6 and 8 clips that hold on this garnish, don't be afraid to pry, the clips are designed to withstand multiple removals, and if they do break, they are very inexpensive (but possibly hard to locate depending on model and year). When the garnish is removed, the screws will be visible(4 in all, one in each corner, sometimes 6) Once those are removed, you will be able to pull the radio out enough to flip it over and get the serial #. This number should consist of about 10 characters (Mix of #'s and letters) its usually by the side or bottom It's just that simple. There should be no reason that the process of removing the radio, getting the radio code, and getting your radio up and running should take more than 10 minutes. So once again, once you've obtained your serial # CALL YOUR LOCAL DEALERSHIP!!! .
-hope this helps
    Genius:
  • 1,011 Answers
Dear Sir/madam, Try to find the serial at manual?. Thanks Good luck
    Genius:
  • 1,550 Answers
I think this link will help you
Online code
    Genius:
  • 1,913 Answers
  • 10,594 Answers
Serial number of unit usually written on bottom or sides.
This website might help you to reset code in your unit.
  • Shahid Electronics
    Shahid Electronics Oct 05, 2008
    Pioneer code release is tech job and tech persons do charge as It is mentioned on above web link.
  • 19,396 Answers
The serial number is something like " BP5556T4782355 1996 7645556310 T" You can find the serial number, either within car stereo documentation, or printed on a sticker positioned at the top or at the side of the car stereo. On pioneer is usually at the top.
To read the sticker with the serial number you will need to remove the car stereo from car. See for example here.
Here is some example of car radio serial number stickers, pull out your system and read tthe serial number:
  • 5 more comments
  • Ginko
    Ginko Oct 05, 2008
    No comment what?
    I posted clearly the only two ways to find a car stereo serial number, if you are just looking for a free service, do not waste our time and use the free forum questions, so that we can use our time to help somebody else.
    Many thanks.
  • Ginko
    Ginko Oct 05, 2008
    Note there is no way to get the serial number on the display, that is rubbish!
    The serial number is on a sticker, you get one with original radio documentation, the other is on top of the radio itself.
    That is the answer.
  • Ginko
    Ginko Oct 05, 2008
    On GPS and similar devices, you have an onscreen option that is calles system information, on those devices you get serial number on screen, on your car stereo you need to remove the radio and there you find the serial number, that is usually the only way and does not take long.
    I think this should satisfy your query.
    Regards.
  • Ginko
    Ginko Oct 05, 2008
    More:
    To estract the radio from the dashboard you need a pair of extractor keys like the one below:
    If you do not have the extractor keys, you can buy them for a small fee or use four thin and log screwdrivers, 4 long pieces of rigid wire, or 4 small allen keys. This must be pushed into the 4 small holes aty the front at the same time, wile another person is pulling gently the radio out of the dashboard.
    All the 4 retaining clips must be released at the same time
    This job requires patience and some time, but is not too difficult, and unless you have all the original documentation, it is the only way to get the serial number.
    Let me know if you need more help.
  • Ginko
    Ginko Oct 05, 2008
    Ok, keep us updated,
    thanks
  • Ginko
    Ginko Oct 05, 2008
    Do as you want, the question "HOW DO I FIND THE SERIAL NUMBER AND DECODE A PIONEER CAR RADIO MODEL DEH-M6106ZH" had been answered, and you also got support on how to remove the car radio.
    Rubbish was referred to your statement that on a Pioneer car stereo you can have the model number popping up on the screen.
    We gave the answer to your question, that is all, you cannot ask us to give you instructions on something that does not exist.
    Now you have had the instructions needed to get to the serial, you do not need any pretest to get a refund, that is your choice.
    Next time please use the free forum.
    Many thanks
  • Ginko
    Ginko Oct 05, 2008
    Well, one of the number on service tab IS the serial nuimber, this unless the sticker had been removed before.
    Serial is preceeded from SN or serial number or serial n. sometimes there is only the number.
    The serial number is always printed on the service tag on the car radio.
    If you want post the copy, or a snapshot of the sticker here, we tell you which one is the service number.
Am trying to re install my radio in another commercial truck
try pioneer.com. have model number handy, you should be able to find manual there.
Nov 29, 2009 | Pioneer DEH-P7900BT CD Player
I have the Pioneer DEH-P5100UB. How do i stop the display from changing colors from blue to black?
I have the same radio, it doesn't have preset buttons...to get it off u turn the key to on/acc and turn the radio off. then press the "band/esc" button.
Nov 11, 2009 | Pioneer DEH-P5100UB Car CD/ MP3 Player
Find car code
If the code is not written on the radio casing  or inside the glove compartment (or similar place inside your car  ) then the majority of HONDA codes are only available from here
https://radio-navicode.honda.com
You will require the car VIN number and Radio serial Number
If they cannot provide your code then you will have to try your HONDA Main Dealer .....or a Decode Service who will plug in a laptop to read/recode the memory chip (EEPROM).
Sep 04, 2009 | Pioneer Car Audio & Video
I need to find the esn # for a pioneer eeq mosfet
It's on the Tuner pack and if you switch to Sirius Tuner you can pull it up in the main menu. Hope this helps
Mar 26, 2009 | Pioneer DEH-2800MP CD Player
DE-ACTIVATION CODE FOR A PIONEER RADIO
there is no code for a pioneer radio expecially for the deh p720. what is wrong or what does it do
Jan 25, 2009 | Pioneer DEH-P7200 CD Player
No sound from a pioneer deh p5200
due to being an older model radio the output (ic) which is behind the rear of the radio is probably unsoldered or faulty the part number is pal 005a or pal 007a which is replaceable with a tda 7386 which is the same part but cheaper.
Aug 31, 2008 | Pioneer DEH-P5200 CD Player
Setting radio stations
The solution for setting the radio station on a Pioneer DEH P2000, is to tune the station you want programmed and hold down the desided channel number until the program number appears on the display.
BC
May 23, 2008 | Pioneer DEH-P2000 CD Player
Having trouble settimg clock on cd car stereo
how to set clock for a pioneer deh-27mp
Mar 24, 2008 | Car Audio & Video
Car radio decode
hi i can if you can supply the serial number.
Mark
Blue ICE
Feb 27, 2008 | Car Audio & Video
1,450 people viewed this question
 Grubhead
Grubhead
