Question about IBM ThinkVision L170 17" LCD Monitor
17 inch IBM Thinkvision
I got a 17 inch ibm and when i turn it on it shows the logo and then it goes black. i took it apart and everything seemed to be ok. I was thinking maybe the LF 4a fuse may be gone. But if thats not the case how would you go about this , like how would i test the capacitors or anything. I hope you can help me my grandfather is on my case right now.
thanks
  • 3 more comments
  • tylermt Oct 10, 2008
    ok so what is a good way to test like on what setting because i got a meter but have no idea on how to test the caps ....
    lol that sucks there like 100 bucks....
  • tylermt Oct 11, 2008
    OK thanks man so you think its caps if there is no power what so over on the monitor? it makes a low buzzing noise. i appreciate ur hep though man.
    um no i ordered new caps for my benq so i tried the cap on my benq and put it on this ibm and it was to many volts so the screen was really bright the inverter light actually came on for split second now i was wondering may it just be that type of capacitor or is something else may be blowing it out?. The capacitor i tried was a 1000uf 16v and the one i replaced was a 1000uf 10v.
  • tylermt Oct 19, 2008
    i just ordered all new capacitors for my ibm i will let you know on the outcome i apreciate ur help fix
My ibm 17" lcd light is on but it is working
Posted on Oct 19, 2008
    Champion:
  • 293 Answers
Well... a good way to tested the caps is to used a Blue ESR meter.
Posted on Oct 10, 2008
  • 2 more comments
  • Cj T
    Cj T Oct 10, 2008
    Well...meter with setting it not for testing capacitors and not giving a true read out. A good caps meter is made by Ana Tek Corp. called Blue ESR. It's design for one thing only...to testing caps.. and there no settings...just clips or points and will give you the read out... very useful piece of tool!
  • Cj T
    Cj T Oct 11, 2008
    Well...the regular meter you had is useless... So, don't bother... You've got more chances...just by guessing it. Hehehe... Here a simple ways to find out if your caps are bad. By looking at the top of each caps for bulged or fluids leaked. Find any of those, then replaced it...not sure, just replaced all of them...:) Couple of caps only cost you about $10 bucks! Much cheaper this way.....Hehehe...
  • Cj T
    Cj T Oct 11, 2008
    Hey...Dude,
    So, does your Grandfather monitor had a AC Adapter? It may be the caused too... if you've got one.
  • Cj T
    Cj T Oct 11, 2008
    Tyler,
    Well, it have to be the same volts as your old one... or it will blowing out...
I have a type 6734-LB1 17" Lenovo ThinkVision
where will i get to install the software/drivers of IBM 6734-L-B-1 for listening Music
Sep 30, 2011 | IBM L170M (Black) 17 in. Flat Panel LCD...
My IBM ThinkVision monitor flickers the correct display then blacks out. The light goes green a moment, then goes amber with the blackout. I think it may be stuck in the Energy Star/Power Saver mode. Is...
skeltonh, Have you connected your L170 to a different "known-good" PC that has ALL power-save and screen saver modes disabled? Have you connected an old monitor to your PC to see if it will act same way as the L170? 12fixlouie
Jul 31, 2010 | IBM ThinkVision L170 17" LCD Monitor
17 lcd l170 black screen power on but no display
When powered-on, and *NOT* connected to a computer, most ThinkVision LCD monitors will flash, for a few seconds, the IBM ThinkVision "logo", before going into "power-saving" mode. If you don't see that, then it's time to spend about $120, and buy a new 19" (not 17") LCD monitor.
Apr 08, 2010 | IBM ThinkVision L170 17" LCD Monitor
IBM ThinkVision 17" Monitor displays for 1 second then black
This seems to be a common problem with these monitors. Have a look very closely and see if you can still see something there. From there, either send it to get repaired, or, if you are handy with a soldering iron, open it up and replace the 4 main capacitors (at least one of them will be "popped", but it is handy to replace them all.
In order to open the monitor, you will need to remove the stand, and make sure you get all of the screws out before attacking it with a screwdriver.
I have 5 IBM monitors at work with the same problem, and opening them up has shown the popped capacitors.
Again, only recommended if you know what you are doing. Screwing it up will leave you with nothing.
Jan 25, 2009 | IBM ThinkVision L170 17" LCD Monitor
LCD flat panel monitor blinks logo over and over
Sounds like the LCD monitor is not getting a proper input signal. Check your cables between the computer and monitor. Replace them if need. Also check the pins and make sure that none are bent or disfigured.
Try a replacment monitor from a family member or friend. If their monitor works ok.....then your due for a replacment. The are very little user servicable parts inside.
Jan 23, 2009 | IBM ThinkVision L170 17" LCD Monitor
LCD (IBM) monitor power light is green but no display
Make sure the monitor lead which goes behind the computer is in correctly and has not come loose.
Unscrew it from the PC and put it back in again.
Jan 06, 2009 | IBM ThinkVision L170 17" LCD Monitor
IBM THINKPAD
Hi...there,
It's seems your Thinkpad need a new inverter, due to a backlight inverter burnt out. Get a new one or repaired it. Good lucks!
Sep 06, 2008 | IBM ThinkVision L170 17" LCD Monitor
Monitor wont turn on, green power light on
Hi you can inspect that what's wrong with your monitors. After you turned it on and the screen went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Mar 08, 2008 | IBM ThinkVision L170 17" LCD Monitor
IBM ThinkVision L170 17" LCD Monitor Logo
344 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
