Question about Electric Lawn Mower
Craftsman Electric Mulching Mower 37051
The one touch height adjustment no longer holds at anything other than the heighest height. Do you know how I can repair it?
I have a craftsman 12 amp. 18" cut side discharge mower. I recently hit a rock and now the blade is loose. how can I tighten it. I have tried tightening the bolt that holds it underneath but can't. any ideas?
Posted on Aug 24, 2010
  • 84 Answers
I had the same problem i tried to bend the lift arm to the left put that didnt last /then try drilling 1/4 holes at diferent heights and put a 1/4 screw to hold it
Posted on Oct 19, 2008
How do I engage back the height adjust on my black and decker lawn hog
if there are no adjustments at the rear wheels install new wheels to accommodate mowing hieght
Dec 05, 2014 | Black & Decker Black and Decker Mm575 18"...
How to adjust the height of the mower
If you mower does not have adjusters on the wheels then there should be three holes where the wheels are bolted onto the base. to adjust these you have to take each wheel off and bolt them in the same hole for each wheel. The top holes are the lowest the mower can be set the middle ones bring it up part way and the bottom hole is the highest setting. You should set the mower to cut at least two and a half inches above the ground. The center holes should be good.
May 12, 2014 | Black & Decker 19" Electric Lawnhog...
My 18" 12 amp B&D mower has become loud and vibrates so much that the wheel height adjustment pops out. Any suggestions?
Most likely bent shaft or blade. Worst case motor is on the way out maybe bad bearing or something along those lines.
Sep 18, 2010 | Black & Decker Lawn Hog 18-Inch 12 Amp...
I need to know how to set the mowing height and do not have a manual
Almost all mowers' cutting height is adjusted by little "tabs" at each wheel. The tabs need to be pushed in to adjust.
May 03, 2010 | Black & Decker 19" Electric Lawnhog...
I have a 19 inch electric mower and the front mechanism that adjusts the height of the front has broken. How do I get this repaired? It's on the right front. As a result of this break, the front of the...
it should be held on by a long bolt & take the bolt out & got to any small engine store & buy another one or maybe a welder can weld it back on either way
Jun 06, 2009 | Black & Decker 19" Electric Lawnhog...
Electric mower won't cut well
change a new blade. when was the last time the blade gotten changed?
May 22, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Adjusting the wheel height
its in the left side at the back end. a plastic orange color lever that you have to press up while pushing the mower up or down
May 25, 2008 | Black & Decker 19" Electric Lawnhog...
Craftsman 6.5 lawnmower
The bag return on the 6.5 sits on two hooks. Standing to the left of the mower you should be able to grab the back handle with your left hand and then left the metal protective flap with your left hand so you can raise the bag assembly still in your right hand up and out of the two hooks. You'll then need to put back into the mower the mulching kit which blocks the rear discharge and makes the underside of the mower a complete circle so the mulching effect works. Obviously the mower will physically work without the mulching kit because the metal protective flap will cover the rear eject but it will NOT effectively mulch the clippings and you will get longer pieces that clump.
Hope this listing isn't too late to help.
Apr 28, 2008 | Craftsman Computers & Internet
Electric Lawn Mower Logo
369 people viewed this question
Top Electric Garden Experts
Steve Oakes
JohnPaul Robertson
Are you an Electric Garden Expert? Answer questions, earn points and help others
