Roxio 2009 installation problem
After starting the installation program received this message :emc 11 content you must install roxio easy media creator 10 before installing the content
the only options were: yes or x both will remove whats been installed
Bob
  • 1 more comment
  • Anonymous Nov 16, 2008
    I keep receiving the same message that I need to install Roxio Media
    Creator 10 before I can continue to install Creator 2009. I have asked Tech
    Support on two seperate occasions if I need this program and why is it
    now listed on the box as a system requirement and they have ignored me
    thus far. I bought the program back on Oct 2nd and as of today (Nov
    16th) have not gotten an adequate solution and do not have the program
    installed.
  • efg_egg13 Feb 02, 2009
    I just purchased roxio creator 2009 to use for tivo to burn dvds and get the same error "  Must install roxio easy media creator 10 installing the content"  EMC 11.  Anybody have a solution??
    Everett
  • Anonymous Apr 13, 2009
    Same problem here.
5 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: Roxio 6 install issues
this might fix your seeing your drives
Posted on Feb 11, 2008
whitetiger93
  • 141 Answers
SOURCE: CANNOT INITIALIZE API - REINSTALL THE SOFTWARE
When you installed the 5.0 in, did you put the update in also?
ecdc_v53.5.10 basic_enu
You will need this or 5.0 will not run.
Posted on Mar 30, 2008
BNUTZBCRAZY
  • 130 Answers
SOURCE: disc copier
try re-installing the roxio program, sometimes programs get corrupted and need to be re-installed
Posted on Apr 02, 2008
rockitman187
  • 2559 Answers
SOURCE: I have a Roxio 10.1 download and need breakdown of serial #
You need the 25 digit product activation number,Not the serial number.
Posted on Jan 12, 2009
SOURCE: lost key code of Roxio Easy CD & DVD Creator 6 basic vcd
You would be better off to simply upgrade to a newer version.
Posted on Mar 19, 2009
My problem is exactly like the one chrisn569 on Dec 21, 2009 related to you. I bought Roxio Creator 2010 and it installed fine the first time but now I can't uninstall. I tried to repair it with the disc...
Running the RegCure won't help. Use RevoUninstaller to remove the entire program (Roxio) as Revouninstaller will show you all the registry entries which you can delete it very easily.
Apr 26, 2010 | Roxio Creator 2010 Full Version for PC...
Printing Direct to CD using Roxio EMC10 and HP All in One C5280
Solved by trial and error.
I went through every type of paper and printer combination listed in the Printer Preferences and eventually found a system compatible with Roxio EMC 10.
This by setting "Commercial Paper" and Neato 3-Disc Paper.
Whilst this is probably the incorrect way to do it, it has solved the problem and I can now print directly onto CD via my HP C5280 All in One Printer.
Tip. If you set Print preview before printing you can determine what the finished article will look like without having to wast numerous Discs trying.
Aug 28, 2009 | Roxio Easy CD & DVD Creator 6...
I was just told that using Windows Media 11 would be a better choice than Roxio for creating mp3 files from a cd...because Roxio isn't working for making mp3 files from the cd. I just installed Windows...
I do not think there is a problem with the cd, it is a configuration of the windows media player 11, get into the options or preferences (whatever it says) and then go to the "Ripper" tab(or (CD Rip tab), and by default the output file is wma (windows media audio) you must change it to mp3 (or sometimes it says mpeg3), and that's it, if there is no option for mp3 let me know.
Mar 20, 2009 | Roxio Easy CD & DVD Creator 6...
Creator suite 8 lockup before burning
I have Easy Media Creator 8. When I try to make a Slide Show everything
works till I reach the " Burn". Then it freezes on me.
Any suggestions what is causing this problem.
Thanks.
Josie
Mar 19, 2009 | Roxio Easy Media Creator 8 Deluxe Suite...
Installation of Roxio 2009
This aint a solution but theres a forum out there with guys having same problem as that of yours. Also there is a suggestion given there that you first copy the disc contents and then uninstall the previous files, clean the registry using any free cleaner and reinstall from the copied setup. Try this.It may work. http://forums.support.roxio.com/index.php?showtopic=42410
Nov 02, 2008 | Computers & Internet
Disc copier
Apr 01, 2008 | Computers & Internet
Mar 30, 2008 | Roxio Easy CD & DVD Creator 6...
Roxio Creator LE Dell Edition - Purchased and installed on February 17, 2008
Your program is making conflict to operating system, its trying to read some thing with invalid memory address. This may be due to curreption of your application.
If thats the case with you, reinstallation of the application will fix the problem.
Uninstall the Roxio from your system, then reboot to clear completely the components of the application. Then install.
Thanks
Iqbal
Mar 19, 2008 | Computers & Internet
Can't open Roxio
Maybe your activation your your software is illegal. or maybe your installer doesn't really have all the requirements or the needed components to have full the instalation process. try to reinstall your software, but if it doesn't work, maybe you can call your software dealer.
Feb 24, 2008 | Roxio Easy CD & DVD Creator 6...
Computers & Internet Logo
1,046 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
