Question about Garmin Rino 120 2-Way Radio
Rino 120 - Disabled WAAS
Had the problem of a Rino 120 shutting down and showing the straight line. Searched problem and found possible solution by shutting off WAAS. What are the ramifications of running without WAAS?
  • burt birkhoff Oct 14, 2008
    my 120 shuts off quite often for no reason
  • mastrand9 Nov 07, 2008
    We have experienced the same Rino shut-down and horizontal line on both our Rino 120 and Rino 110. Both units are fully functional while initially powered up, but die after a couple minutes, whether powered by battery (fresh or not) or powered by the Garmin 12V auto power adapter. This behavior was present in the following setups:
    batteries in (fresh)
    batteries in (fresh) and connected to 12V adapter
    batteries (out) connected to adapter
    During a recent motorcycle trip, the only correlation to Rino shut-down behavior seemed to be Rino unit temperature, though this is wild speculation.
  • 258 Answers
I had a 120 that kept locking up with a gray screen. I did a factory reset and it stopped. I didn't check WAAS.
The Reset is Hold the page and navigation stick while powering up. A dialog will ask you to delete all data. Hope you have a backup first.
Posted on Apr 22, 2009
  • 3 Answers
Have you upgraded from Software version 3.2? Version 3.3 addresses a memory overflow problem when receiving two or more WAAS satellites.
Posted on Nov 28, 2008
How come the garmin 120 radio isn't compatible with standard Motorola walkie talkies
When programmed to the same frequency and code settings the Garin Rino 120 should match the Motorola TalkAbout line of radios. They are all using the same UHF FRS/GMRS frequencies. Here is a link to the Garmin user guide where you will find the frequency charts on pgs. 100-102:
Motorola TalkAbout user guides can be found at:
Best regards.
Nov 20, 2014 | Garmin Rino 120 2-Way Radio
Screen goes blank except a thin line
There is a firmware upgrade from Garmin that appears to address this problem for units still running Version 3.2 or earlier. If your problem only occurs when WAAS is enabled, you might try upgrading. To find what firmware version you have, from the main menu: Setup, System, then select the (options) icon on the top row, to the left of the 'X'.
Nov 24, 2008 | Garmin Rino 120 2-Way Radio
Garmin Rino 530 battery wont charge
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Nov 15, 2008 | Garmin Rino 530
Garmin V
I think I may have found the solution.
A reply for a post on another site:
I visited the Garmin Corp office to seek help with that problem. If the shut down occurs right after satellite acquisition and the screen may show just a narrow black line going across it, it is likely due to some program changes the sattelite folks did without telling the software programmers. Garmin web site has a free download fix for the problem. Another option is to go into your settings and turn off the WAAS. Hope this helps. Go to the web site, check downloads, find your model gps and there you go. Good luck.
I disabled WAAS and so far so good.
I couldn't find the fix on the Garmin site.
Oct 12, 2008 | Garmin GPS III
RINO 120 :: screen blanks out with just a single horizontal line
Had to wait 24 hours to be able to post my own answer
By reading a number of forums, I've found that there was a WAAS satelitte update (bug), that causes this foul up.
The only solution I've been able to arrive at is DISABLE the WAAS feature, as no Garmin Update/patch (for Rino120) has been made available.
To shutoff the WAAS feature press your [Page] button until you arrive at the "Main Menu"
go down until your on the "Setup"(hammer)
go in (by pressing in, on the directional button)
go down until your on the "System"(gears)
go down until your on WAAS, go in and select the Disabled
go up to the "X" (top right) press it, then you can [Page] button anywhere you want from there.
Wonder what WAAS is?
Take care.
PS- Garmin if you read this....I would like to have my WAAS back, and since I registered for updates, back in 2005, why didn't I get an email from you telling me about this issue (when it happened and provide a solution - at the same time :: even a work around as I've posted here)
Oct 02, 2008 | Garmin Rino 120 2-Way Radio
Garmin gpsmap 162 turns on, works for about two minutes, then a thin black vertical line comes across screen and screen goes blank with the line remaining. I have to unplug and start over. Same things...
Possible Solution found on google....
My old Garmin 162 chartplotter was mounted on the binnacle guard and served me
well for many years. Lately, it started getting very slow to refresh screens.
At times, it would shut down with only a black vertical line on the screen. On
our last cruise, the screen froze at a very critical moment. Too old to
repair, I bought a new Garmin 440, which I am very disappointed with, but
that's another story.
I read an article in the GoodOldBoat newsletter about the Department of Defense
making changes to the WAAS satellites that have caused problems in Garmin 72
and 76. Garmin's tech support recommended to turn the WAAS function off on
affected units. So I got out my old 162 and turned the WAAS off and it works
fine. To make sure it wasn't a fluke, I turned it off and on several times,
and it always slowed down with WAAS turned on. With it turned off, the
position error or accuracy, increases 1-2ft, not a big deal. I hooked the unit
up on my truck and drove around. Not a problem. Further reading indicates
that other brands of GPS are also having problems with the new WAAS
So if you are having problems with your GPS and it is new enough to have WAAS,
try to turn it off
Sep 28, 2008 | Garmin GPS
Unit shut down
I have run into the same problem and it may be related to the WAAS (Wide Area Augmentation System) feature. Try disabling this feature (under MAIN MENU / Setup). I used this receiver overseas (Asia and Europe) last year for 35 days straight with no problems. During this time WAAS was disabled as none of these satellites are visible overseas. The problem occurred intermittently prior to the overseas trip, and has reoccurred after returning. I was running into the same problem this past weekend and noticed the screen blanking out (with the vertical line) shortly after differential corrections were applied to the GPS signals. I disabled the WAAS and let the receiver run for over an hour. The problem did not return. Hope this helps.
Sep 25, 2008 | Garmin GPSMAP 76 GPS Receiver
Broke rino
I had a similar problem with my account.
I pushed the one batteripolen down as it started up again.
Mar 12, 2008 | Garmin Rino 120 2-Way Radio
Garmin 120 just dies
have you put fresh batteries in
are they the right way around
are the 2 metal spring clips tight up against the batteries
try bending them (al little) to make better contact
has the unit had any water in/on it
is the mic button pushed down and draining the batteries too quickly
Nov 21, 2007 | Garmin Rino 120 2-Way Radio
Garmin Rino 120 2-Way Radio Logo
431 people viewed this question
Top Garmin Radio Communications Experts
TO Lady
Are you a Garmin Radio Communication Expert? Answer questions, earn points and help others
