Question about Maytag Neptune MAH5500B Front Load Washer
Washer was opened during beginning of cycle won't start up now.
My daughter opened the door in the beginning of the wash cycle after door locked light was on and now I cannot get it to start up. There are lights on but it won't run, water in the machine.....is there a reboot button???
  • 750 Answers
Peace Friend,
Huuum At your service!
Like with an error code ,
Unplug the washer and wait a 6 minutes then restart it like rebooting your computer when its acting strange!
It should reset the system and your problem should be solved!
Let me know.
Thank You,
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
Please remember to leave a rating when your done
Posted on Oct 04, 2008
Control lock light is on , toke door lock off once cleaned it put it back on and it worked now its on aagain and washer wont work
1 close washer door and dispenser drawer
2 select Clean washer cycle
3 Press start/ pause
The basket will rotate,then the door will unlock,lock again,then the cycle will continue
Water should come in and run a short sensing cycle about 3 minutes
4 This will determine item in the washer
a if no items are detected it will move to step 5
b if item are detected wash any control lock light will stay on door will unlock open and remove any garments
If b pessnpower to cancel f code then repeat 1,2,3
Once cycle begins allow it to finish
5 after cycle is complete leave the door a jar to allow for venting and drying of interior
Only use HE high efficiency detergent
Jul 05, 2015 | Whirlpool GHW9100L Front Load Washer
All cycles are working except the spin cycle. I have visually inspected the wiring connections and motor and dont see any obvious issues. There are no error codes and the LED lights seem to be functioning...
Because of the high spin speeds of front load washers, the doors are equipped with a latch and lock mechanism to prevent the door from being opened during the washers operation. These locks will often be actuated by a solenoid or wax motor to ensure they remain latched during the wash cycle. This model uses a two stage lock that latches the door when the load starts, and then when it is time to spin, the second lock engages to ensure the door is properly secured prior to beginning the spin. When this second lock engages, it also closes a set of switch contacts (the auxiliary door switch) telling the control board the door is closed and locked. If for some reason this switch is not closed, the washer will tumble during what would normally be the spin cycle until the entire cycle is complete.
Jul 02, 2011 | Frigidaire Affinity ATF7000E Front Load...
My lg door will not unlock
this kind of door lock is called PTC door lock.It is designed for protecing you from opening the dooe during the washing and spining cycles which may hurt you.So, if you want to open the dooe during cycles,pls press "stop",then ,wait 2 mins,you will be able to open it by then.the other situation is that,the power is cut off during working cycles,solution is:re-start the washer and directly open the door.Pls note that this kind of lock has to work under power
Mar 14, 2010 | LG WD-12126RD Front Load Washer / Dryer
Washer loader door is locked and i cant open it
this kind of door lock is called PTC door lock.It is designed for protecing you from opening the dooe during the washing and spining cycles which may hurt you.So, if you want to open the dooe during cycles,pls press "stop",then ,wait 2 mins,you will be able to open it by then.the other situation is that,the power is cut off during working cycles,solution is:re-start the washer and directly open the door.Pls note that this kind of lock has to work under power.
Mar 14, 2010 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
During the wash cycle on a maytag epic mfw9800tq0 my daughter opened the door and after water splashed on the floor she slammed the door shut. It will not drain and spin out now. the tub will agitate...
if she could open the door during wash cycle the door lock is broken and you may need a new one also inspect pumpn and tub to pump hose for foreign objects
Jul 07, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag Neptune Front Loader Washer
Sounds like the door lock unit isn't locking and may be bad. It is also a possiblity but not likely that there could be a problem with the computer board but start with the door lock unit first
Dec 29, 2008 | Maytag Neptune Washer
Washer door pops open during wash cycle
Start the washer in a cycle. When the door locked light comes on, before unit gets to full of water, see if you can pull door open. If so, you probably have a broken latch. The wax motor is activating the switch, but latch is not actually closing. There was a door latch upgrade for some of these models.
Oct 06, 2007 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptune MAH5500B Front Load Washer Logo
63 people viewed this question
Top Maytag Washing Machines Experts
Richard Roth
Richard Roth
Bill Long
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
