Question about GE Refrigerators
My freezer accumulates ice to the point I have to empty the freezer, use a knife to scrape all the ice away, and then repack the freezer. This is a weekly occurance.
    Guru:
  • 558 Answers
Keep the regulator on Low. Check up by the Service engineer needed for Condenser and excessive cooling gas
Posted on Oct 04, 2008
I recently poked a hole into my freezer with a knife
That was not a good idea. I assume you were scraping ice in the freezer. Did it hiss or spit when you did this and quit getting cold. If so you damaged a refrigeration tube. These are normally expensive to repair.
Oct 30, 2015 | Refrigerators
Ice is collecting on the fan in the freezer causing whirring sound.
Reduce thermostat setting point by point till no ice accumulation on fan.
Oct 01, 2017 | General Electric GSH25JFX Side by Side...
Heaps of frost/ice in freezer: Whirlpool wro34uw
You probably need to fully defrost the freezer. Switch it off for at least 24 hours and collect the water as it defrosts. Do not try to scrape it as it can damage the product. The cracking and poping noises are most likely the product trying to auto defrost. It is probably too iced up for Auto defrost to work which is why you need to fully defrost. Good luck.
Feb 20, 2012 | Refrigerators
Heavy ice accumulation on back of the bottom freezer. need to be turned off and chipped & scraped. Effecting the refrigerator sectionas well
My amana bottom freezer was doing that. The fix is to replace the defroster coil and thermostat. Relatively easy just be careful defrosting you can melt the plastic with a hair dryer.
Aug 04, 2011 | Amana ARB9059CS Bottom Freezer...
Deepfreeze not working after defrosting
I think the problem happened during defrosting. i will tell the important steps that should be done while defrosting. Check whether you done the same steps or not.. If you done the wrong steps kindly contact the Shop where you buyed and tell them to replace with your guaranty(if available).
Here are the steps. Shut off the power to or unplug your freezer. It can't defrost if it's still running. Find the drain hole near the bottom of the freezer and put a plate or towel underneath it to prevent water from getting on the floor. Open the freezer door and remove all the food. Remove any baskets or other removable items from the freezer as well.Take the spatula and scrape away as much ice as you can from the walls of the freezer. This is cold work; I recommend gloves if you have any. After you scrape away as much as you can, use the dust pan and bowl and take out as much of the ice that has accumulated on the bottom of the freezer as possible. Replace the baskets or shelves in the freezer and shut the door. Turn the freezer back on. Put the food back in the freezer in an orderly manner where things can be found when you want them. Put items you hope to use soon in the freezer above your fridge or in a place inside your deep freeze where they will not be forgotten and used soon.Remove all of the excess water from the bottom of the freezer. You may use a kitchen towel for that; squeeze it into the bowl so you don't get water all over the floor. The water will be extremely cold. Once all of the water is gone, wipe down all interior surfaces of the freezer with paper towels. You don't need to use spray cleaner in the freezer unless there is some type of mess that was caused by food spilling.
  • Fill up the large container with warm water. Pour it along areas that still have a lot of ice buildup. Let it sit for a minute or two. Then take the spatula and scrape off any loose ice. The ice is likely to come off in big sheets Once again, remove the ice and water from the bottom of the freezer. Repeat this process until all of the ice is removed from the sides of the freezer.
  • If you liked my solutions, kindly do rate me ..
    Thanks..
    May 20, 2011 | Refrigerators
    Ice is building up on the back wall of my freezer
    the freezer heater needs replacing, it's inside the freezer after removing all the racks remove the back panel, the heater is on the lower part of the condenser it's about $50.00.
    Dec 09, 2008 | GE Refrigerators
    Need to know how to work defrost cycle on OLD GE 'fridge.
    i am assuming that at 30 yrs old, this is not a frostfree type
    i defrost by taking all food out, wrap in a blanket and defrost with a hairdryer. don't point too close at plastics and don't let water drip on it. on no account use a knife to scrape ice away - use a plastic spatula
    Nov 29, 2008 | GE Refrigerators
    Hotpoint FFA071fridgefreezer
    defrost carefully with a hairdryer taking care not to blow hot air on thermostats mounted on the pipework. this can take some time and don't use a knife to scrape ice off - use a plastic or wood spatula. appliance will still work for some time - week or two
    to identify the fault is more difficult and you will need a multimeter. check continuity thro the defrost heater and the thermal fuse in series with the heater. check continuity thro any thermostats mounted on the pipework.. if these are all ok, then it points to a fault with the timer or main module
    Aug 28, 2008 | Freezers
    Ice on the back wall of the side-by-side freezer and no ice
    Possible circulation fan has quit, or defrost element is not working, call service.
    Apr 20, 2008 | Haier HTE18WAA Top Freezer Refrigerator
    Refrigerators Logo
    63 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    RepairNinja
    RepairNinja
