Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Hitachi 50" Ultravision too much yellow, not much blue
Picture has yellow even where white should be. The blue really doesn't come through at all. Lots of red,green, and yellow. I replaced the lamp and it didn't fix the problem.
  • 11 more comments
  • toni1029 Oct 06, 2008
    on picture color, if a person's shirt is white it shows up yellow. The yellow makes all the blues look green.
    Model 50V500A
    serial # V4K047130
  • Keith Kitagawa Nov 04, 2008
    I HAVE THE SAME PROBLEM.WITH HITACHI 42V710 ULTRAVISION
    COLOR. LOTS OF YELOW BLOTCHES AND NOT MUCH BLUE.
    THE TV IS 3 YEARS OLD AND COST TWO THOUSAND DOLLARS.
    WOULD LIKE A SOLUTION AND HOW MUCH IT WOULD COST. THANKS
  • HABS FAN Nov 09, 2008
    I also have the same problem. There is a yellow tint to the picture. I have the model 50V500A. For example when I watch a game of hockey the ice is yellow instead of white. Basically anything that should be white is yellow. Also does not display the colour blue at all.
  • sastephenson Nov 15, 2008
    Same problem as others. We got a new bulb and now a small portion of the screen has true whites. (only about 1/6th of screen). Still the color is horrible; we are very disappointed with Hitachi.
  • goodgoofy5 Nov 19, 2008
    there is too much yellow and green.i have tried setting back to factory settings and adjusting from there without any improvement.i changed the lamp a year ago.this is for a hitachi 50v500a
  • Anonymous Dec 28, 2008
    50v500a yellow tint in center screen most noticeable when something is white
  • bg750ace Jan 02, 2009
    Patches of yellow on the screen.
  • Carrie Macdonald
    Carrie Macdonald Jan 12, 2009
    hi , i have the same problem. centre of screen is yellow. our is 50"lcd ultravision hdtv.
  • gzavernik Jan 14, 2009
    I have a 42V715- large circle that takes up most of the screen has yellow tint and changes most blue colors to greenish. You can see the normal colors just on the outside edges of the screen.
    Somone recomended changing the ysus board.
    Please help.
  • Anonymous Jan 16, 2009
    HAS A YELLOW TINT IN CENTER OF SCREEN, PROGRESSIVELY GETTING WORSE
  • Anonymous Mar 13, 2009
    I also have three yellow lines running across the screen. I've had my 50V500 since they first came out. Is there a fix?
  • Sunny Valiplackal May 11, 2010
    Pls give the model number of your unit.
    Thanks
  • Anonymous Mar 15, 2014
    the yellow light stays on for dvd and then it flashes red green blue then black then white. the buttons will not work
  • 61 Answers
First of all sorry for delay.
can you provide a image of yello shadow.I believe it seems to be technically say "ghost image"
If it is ghost image we can try by entering SERVICE Menu and adjust RGB level of the light engine.
Good luck
Dals123
Posted on Oct 09, 2008
I have an issue with a tv It is a Hitachi Ultravision Directors Series model #55HDV99. It has picture and sound, but the color is not correct. The reds and blues are missing.
Check the connection between your cable box and tv.
You should have five rca cables connected. Red, yellow, and blue. the other red and white is for audio.
Regardless of them passing the eye test. Push on each end to make sure contact.
If that doesn't do it you may have a bad crt, but you are missing red and blue that would be two bad ones at same time. Not impossible. Could just be bad solder connections as well.
Dec 03, 2015 | Hitachi Televison & Video
My Hitachi Ultravision LCD rear projection 62
Hi:
The only way to repair this is to replace the optics engine assembly, Light engines are rather cheap these days, try looking on www.tristatemodule.com for a new or refurbished one.
Apr 09, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi Plasma P50S601 no picture sound OK
probably needs new scan drive board along with upper and lower buffer boards. it wont be cheap and its best to have a tv shop do it.
Aug 30, 2009 | Hitachi Ultravision P50S601 50 in. Plasma...
50 inch Hitachi Ultravision LCD Rear Projection Television
Hitachi has had problems with their light engines. Very expensive. Contact Hitachi as they may give you consideration even if this is out of warranty.
Apr 15, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
50" Hitachi Ultravision with yellow picture
Good Day, steveb13;
It stills points to yhe Light Engine. Good Luck, big IRISH.
Jul 15, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi Ulatravision Digital TV....... have a yellow shadow around part of picture
it might be scorch mark starting from the bulbs heat or someone placed a magnet close to machine that gives the same impression
May 09, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi UltraVision has blue streak on right side of screen.
convergent systems.. I callled Hitachi....
it cost $600 to relpace the part... all 3 colors red yellow blue,.... tech took the part out and will replace it in about 3 or 4 days.
I was told by technician that it was a very very good tV in fact he said he would buy it from me for $300 and take it away.. I am considering that ... but a new one with Picture in picuture will be 2000 or more
Apr 06, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitatchi Ultravision LCD Widescreen acts like it doesn't want to power up
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 10, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Picture is yellow and green
Your missing the red drive on the set. Its most likly the picture tube. Its a possibility that the red drive circuit could be not working so the best thing to do is take off the gree picture tube socket and put the green board on the red tube. Of course do all this when the set is unplugged. if you have no tv experience. its not a good idea to be messing around inside of these sets.
Sep 02, 2006 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
1,201 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
