Question about Kenwood DNX7100 Car Video Player
Kca-bt200 I cannot pair a bluetooth device. It keeps saying the pin code ("0000") is incorrect. Its been working for about 6 months now, the only difference is I upgraded the firmware for the dnx7100. Any thoughts
Ai rezolvat problema?
Posted on Sep 05, 2016
    Guru:
  • 395 Answers
Charge the headset for at least 24 hours to reset it and that should delete the link key, then try re-pairing.
Posted on Jun 04, 2010
I cant conect mi huawei p8 on kenwood kca bt200 i forgot pairing code ...help me please help help help
Delete the registration and then check out pages 12 and 13 of the user manual, below.
http://kasc4.s8.novenaweb.info/files/prod/1028/5/KCA-BT200(EN).pdf
Sep 05, 2016 | Kenwood Radio Communications
How do I enter the pin code for my bluetoothit says pincode incorrect for my Samsung Galaxy II
The pin code is likely to be one of the following unless otherwise noted in the manual.
1234, 0000, 1111.
I would be able to help more if you note the model of bluetooth device you are trying to setup. Model number should be on the bottom or back the device.
Jan 25, 2015 | Samsung Cell Phones
How do I make my kdc-mp242 bluetooth discoverable?
In order to use bluetooth with your receiver, you need to purchase the Kenwood KCA-BT200 Bootooth Interface. These are readily available online and can be had for $100-$150: Kenwood KDCMP635 KDC MP635 KDC MP635 50W 4 MP3 WMA AAC CD Receiver cheers
Mar 15, 2011 | Kenwood KDC-MP242
Trying to pair it and it keeps comming up passcode incorrect re enter it
What bluetooth is this, did you put the device into pair mode first? The pin code for most NEW bluetooths is 0000 if not 1234.
Rylan
Dec 16, 2010 | Radio Communications
People can't hear me clearly on my KCA-BT200.
Bluetooth originally had a limitation of about 30 feet +/-, however that doesn't mean great clarity until it reaches its peak distance range. With that said, I would suggest trying to move your phone around in the vehicle to get the shortest distance possible to the receiving Bluetooth device (KCA-BT200).
May 30, 2009 | Kenwood KCA-BT100 Wireless Headset
Have a new KCA-BT200 and when I try to connect the bluetooth it keeps disconnecting. If it helps, the Navigation system is KNA-G510
ok first u have reset the KCA-BT200,to do that remove your car battery cables for 3mins and reconnect your battery cables,
by lil_ti2002@yahoo.com
Jan 20, 2009 | Kenwood KCA-BT100 Wireless Headset
Connecting Bluetooth to Kenwood KDC X590
you need a kenwood kca-bt200 which is a bluetooth plugin for your head unit. when you have installed this here is a check to see if its recognised.
1 Select the STANDBY
Press the [SRC] button.
Select the "STANDBY" display.   2 Enter Menu mode
D-1:Press the [MENU] button for at least 1 second.
D-2:Press the [MENU] button.
D-3:Press the [FNC] button.Turn the Control knob to select "MENU", and then press the Control knob.
"MENU" is displayed.   3 Select Bluetooth device selection mode
Push the Control knob towards up or down.
Select the "Phone Selection"/"PHONE SEL"/"PHN-SEL" display.   4 Enter the selected Bluetooth device selection mode
Press the Control knob for at least 1 second.   5 Select the KCA-BT200 Firmware
Select the "BT200 FW ***" display.   6 Exit the Bluetooth device selection mode
D-1/D-2:Press the [MENU] button.
after this you should be able to pair from the headunits menu
Nov 27, 2008 | Car Audio & Video
Jabra vbt185z, light stays on, won't connect to phone
My head set had another pin code other than 0000 when I recieved the unit which made it dificult to connect. I learned how to reset it to the default pin of 0000 which allowed me to sync it with my phone. After using it for a month or so my phone requested the pin again.I entered 0000 and once again would not accept the pin. I had to retore the default pin again and it works just fine. Here are the instructions. Plug your vbt185z into the wall charger and while connected press down and hold the center blue button untill the light comes on.(about 30 seconds)Unplug the the ear piece and turn the unit on.Now enter pin 0000 and your phone should accept the pin.
Dec 29, 2007 | Nokia 1600 Cellular Phone
Blue tooth device pairing code
open bluetooth and search for new device,when you find new device you can configure it so as no code is required and pair auto
Oct 18, 2007 | Magellan RoadMate 6000T Bluetooth GPS...
Kenwood DNX7100 Car Video Player Logo
490 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
