Sensor on pc keeps flickering on and off - Computers & Internet
  • 661 Answers
That is your HDD activity light.. it is supposed to do that..
Posted on Oct 04, 2008
OIL LIGHT KEEPS FLICKERING WHILE IDLE
Most likely your sensor is too sensitive and detects the low oil pressure that exists in idle .... you oil pump is not functioning fully and at idle fails to produce the right pressure. Lastly,your idle could be set too low. try increasing the idle slightly (you don't want it too high) and see if that solves the flickering light problem
May 30, 2014 | 2004 Ford Escape
My flatscreen Mitsubishi Keeps flickering with tiny stars on the screen
changing the screen migth be expensive you can add money and get a new one
Mar 25, 2014 | HEWLETT-PACKARD Computers & Internet
Oil light flicker on and off on 2006 pt cruiser
There is a possibility that the oil pressure sensor wire located on the engine block is either incorrectly fitted or the wire is off completely and touches an earth (negative) source, causing your warning light to occasionally flicker
Jul 10, 2013 | Cars & Trucks
My laptop keeps flickering
maybe you have a loose connection and maybe this is causing the flickering. i suggest you look at the cable connection behind your screen and make sure it is locked. (clip lock cable)
Jan 21, 2013 | Lenovo G550-29583AU Notebook
Door ajar keeps showing up while lights flicker. car alarm goes off.
You have a bad door latch sensor. This will flicker the dome light and trigger your alarm. It is either built into the latch or if you see a small button in the door jamb the switch is there just remove the nut and replace it.
Nov 16, 2010 | 2002 Ford Explorer
The oil light keeps on flickering even though I checked the level and it's at the correct level. I even checked all other levels for all other fluids and they are all correct. What can be the reason that...
There are a number of reason that could cause this: bad sensor, low oil pressure, wire rubbed and grounding out.
You need to screw out the oil pressure sensor and screw in a pressure guage then crank the car and observe the guage. It should stay above 20 psi at all times.
Does it flicker when idling or driving or both?
Nov 05, 2010 | 2000 Plymouth Voyager
Flickering and has a white display
restart and keep tapping f8 and then select "safe mode" from advanced boot options menu
Jul 30, 2010 | Gateway Profile 4MXb PC Desktop
Hi my ho nx9005 laptop screen keeps flickering
you have a problem with your flat it is a cable connecting the monitor to the notebook itself and may be damaged or not fixed in it's place
Oct 26, 2009 | HP Computers & Internet
Taskbar keeps flickering in windows vista
Possible vga driver fault, update graphics driver.
May 27, 2009 | HP Pavilion a705w PC Desktop
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
