Question about Hotpoint Washing Machines
Out of balance spin
Why does my Hotpoint Aquarius 800 WM 10 try to shake itself to pieces when it starts to spin even when loaded with a light load?
    New Friend:
  • 38 Answers
Next time its empty open the door take the metal drum and test for any movement if you hear/feel a knocking the drum bairings need replaced, makes it spin if centre
Posted on Oct 05, 2008
I have a hotpoint washing machine (wm 62)and it jumps whils starting to spin. this is a recent problem and i find i have to move it back into position following every wash.
Hi.
You have a balancing problem.
The first thing to do is checking floor level and putting the machine at balance as explained in the user manual (see
Installation and User Instructions for the Aquarius Range). If that does not work there are internal faults that may result in heavy shaking during spin part of the cycle. Such problems are mostly mechanical (eg. struts, bearings, rollers, springs), the machine must be disassembled to locate the problem.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 09, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hi, My hotpoint wm 25 wont spin? Brushes are fine. Help!
Why no spin?..Is the water fully pumped out, is it out of load balance? This happens when too few items are in the drum the machine senses this and will not spin.......Hope this of some help
Jan 08, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Electronic 800 WM 12 Aquarius won't rinse
If it won't rinse because it won't fill, it's most probably because the cold water inlet valve is faulty. Many machines will only rinse with cold water....No cold water.....No rinse!! Not a big job.....Nomess
Apr 13, 2010 | Washing Machines
Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
Feb 23, 2009 | Hotpoint Ultima WD72 Front Load...
WM 22 will not spin
yes.dose it drain,see it must drain before it can spinso if water is standing in it it wont spin and that would mean your pump is ither blocked or reciving power but not working.
Jan 01, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washing machine not draining therefore not spinning
You will find the filter located inside the large black hose at the lower right rear of the m/c.
Remove lower panel and you will see the hose there.
Undo the large clip and remove hose and clean filter.
Plz rate this solution
Thanks
Dec 19, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WF250 Loud banging when spinning
The hardest amount to balance is a load with just one item.Because you have nothing to counter balance the other side.So,first off,put in a normal load ,make sure your washer is level by using a level to assure it is, other wise if its not all the clothes will group in one spot where its not level ,than when time to spin you have a un balanced load.
May 21, 2008 | Washing Machines
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Beko
probably a balancing spring broken the load will go to one side of the drum when spinning.Needs to be taken care of before it rattles itself to death
Oct 21, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Washing Machines Logo
146 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
