Question about Seagate 300GB USB 2.0/FireWire Hard Drive (ST3300801CBRK) 300 GB
Seagate 300GB USB 2.0, read write error
I have 300 GB USB2.0 external hardrive, i am unable to see any data, it is giving i/o read write error.
It shows up that the drive is connected. When i try to explore data nothing shows up and gives an error message. "I/O read/write error".
Can you please let me know how to recover the data.
  • uldisi Feb 06, 2009
    I have Seagate 300gb external hard drive and I cant open it enymore because of I/O error. It was working great. I decided to clean up my computer and trasfered all data to HD. After I cleaned up my computer I conected after few days my hard drive back to computer to get back all data and Im not able to open it because of this error. I also tryed on my neighbors computer and same thing I/O error. Can enybody can help me out or give some advise what can I possibly do. I tryed Seatool but softwear coud not faind my hard drive, however when I conect to computer it recognizes that hard drive have been conected. I hope sombody can help me out. Thank you very much...
    Joe
  • levismoak
    levismoak Jan 22, 2013
    I too have to same problem, everytime i connect it i can see the folders i created but they are empty. I need serious help with this bc i deleted everything off my MAC after i transfered it to the drive. ANY HELP IS APPRECIATED
    Problem Solver:
  • 10 Answers
Hook it to another computer do see if the drive is the issue.
Posted on Oct 04, 2008
Itunes messed up my external hardrive
I doubt that iTunes really moved/reorganized files on your computer.
iTunest may have created its own "Table Of Contents", presenting a "view" of all your files.
Open "My Computer" and open your external hard-drive.
The files should be in "your" order.
Open "My Documents". Open "My Music".
If iTunes really did "reorganize" your files, there's no way to "go back", because "Windows System Restore" does not automatically created time-stamped backups of your 'My Documents' folder (nor of any external disk-drive -- where would it put that much data???).
Jan 02, 2010 | Seagate Free Agent Go Small 12 GB USB...
I recently added a Seagate 500 GB external desktop drive to my Dell PC. It had only 18 GB on the C: drive, and I had gotten msgs that I was running out of disk storage. I installed the new drive thru...
Hi!
I think I would run the setup application and see if it helps. You're relying on the Windows drivers for the drive and who knows how well they work.
1. Turn the computer off completely.
2. Disconnect the USB drive and any other USB devices (for the time being).
3. Turn the computer back on, put the installation disk in and follow the instructions. Don't connect the USB drive until you are asked! Having it connected before asked may not allow the installation process to work as it should.
4. When everything is installed, hook your other USB devices back up and see what happens.
If this doesn't work, go to the Seagate site and try out their external HD troubleshooter.
Hope that helps! Remember to rate the solutions!
Aug 10, 2009 | Seagate USB 2.0 External Enclosure + 300GB...
Reduced Hard Drive Capacity with Internal to External Kit
Problem can be tricky.. though i offer my two cents.
1. some BIOS have upper limit of hard disk capacity. check that out. try connecting IDE device to IDE connector in same comp and see if it is being detected properly.
2. seagate guys are true .. IDE to usb conversion can be tricky ... a lot depends on card convertor.
my advice would be if you have precious data on it ... first take a backup of it, if possible connecting the disk to nomal ide connector.
Aug 06, 2009 | Sabrent 1 Bay USB 2.0 External Drive Case
My segate 300Gb HDD keeps asking to format it when i recently pluged it into a new computer to transfer data to and it said that the driver didnt install correctly. since then it keeps asking to forma
I'm assuming that this was functioning at one point. If you are using Windows, Right click on my computer and click "Manage" Then go to disk management? Does it see the drive at all. If so, has a letter been assigned? It is possible that the operating system will show the drive even if it can't read the data. Look to see what file system and how it sees the disk having been partitioned. It is possible that your partition table has been corrupted. This can possibly be fixed using a tool like disk doctor or fdisk.
If, on the other hand, the drive is also making funny noises, you may have a mechanical failure on the drive.
May 29, 2009 | Seagate 300GB USB 2.0/FireWire Hard Drive...
How to retrieve data from external drive
I had similar problem. See FAQs on this site. My 300 GB One Touch II drive was not found in the XP machine either as USB or IEEE. When I remounted the drive in an external cabinet from Deltaco ( MAP-KC) is is running since. The Maxtor chassi was the trouble not the 3,5 " drive. All data is recovered. // Regards AH2FOTO
Sep 24, 2008 | Maxtor OneTouch II external hard drive...
About my seagate 160 gb hard drive (external)
i hav usb seagate 160 gb hard disk.nw it is nt getting open message is the file or directory is corrupted or unreadable........CHKDSK is also not working for it.error is "unable to determine volume version and start"....plz help fast
Jul 26, 2008 | Seagate 160GB 3.5" External USB Drive 160...
External hard disk unreadable
Your hard-drive is crashed and unreadable by win32.dll what you can do is try kick starting by using your friend computer it just might do it. I had same problem and I asked my son to using my hard-drive on his PC. It worked and still working. good luck
Can't backup
you need to sepecify which files in your system it can backup ;) this is found in the tools bar. good luck
Oct 08, 2007 | Maxtor OneTouch III 300GB 7200RPM...
Seagate 300GB USB 2.0/FireWire Hard Drive (ST3300801CBRK) 300 GB Logo
276 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
