Question about Hitachi Computers & Internet
Is my Hitachi HDP725032GLAT80 3.5" 320GB PATA compatable with XP
  • 661 Answers
Don't see any reason why not... it is only a hard disk.
it is only how it is partitioned and formatted that causes problems.
if it is formatted by windows then it is ok
Posted on Oct 04, 2008
Installing a new larger hard drive, and it will not accept it?
Wait a minute! Hold the phone!
HOW, are you trying to install this 320GB harddrive?
You cannot just grab a fresh, new harddrive, and put it in. There's no Operating System on it. It's on the 160GB harddrive.
(Windows XP?)
Not trying to 'sound' condescending, but I do not see anything to support that you know what you are doing.
If you are using a Western Digital 160GB IDE harddrive, you have a motherboard, and BIOS, that is past the size limitation for an IDE harddrive.
The size limitation was 137GB for motherboards, (BIOS program, actually), that had this limitation.
Size limitation isn't your problem.
Plus, LEAVE BIOS ALONE, as far as upgrading.
A) Power goes out while you are upgrading, and when asked, you do not save a copy of the original BIOS program, you can take your motherboard out, and use it for a Frisbee.
B) IF, there was a BIOS upgrade, AND it is NOT compatible, AND when asked you do not save a copy of the original BIOS program, you can take your motherboard out, and use it for a Frisbee.
Also, if it IS an IDE harddrive, and the old 160GB is an IDE harddrive, you cannot put both harddrives on that flat ribbon cable, AND use the 320GB as a Primary harddrive.
Want to use the 320GB as a Primary harddrive, (Master), and the 160GB as a Secondary harddrive? (Slave) There is a proper procedure.
No, I'm wrong? You have a fresh, new GENUINE copy of Windows, and are going to install it on this 320GB?
[Microsoft makes one Master disk. From it all GENUINE copies are made, and sold to the consumer ]
I hope it is Windows XP, (Home or Pro)
Because drivers are not be available for Windows Vista (Yecch!), or Windows 7.
What are drivers?
Small pieces of software that allow the Operating System to communicate with a device.
Windows XP and Windows 7, are just two examples of an O/S.
Harddrive, motherboard chipset, optical drive, (CD/DVD drive), audio (Sound), etc., are Devices.
Winfast is no longer in operation. No help from them.
(The motherboard manufacturer that made the motherboard for eMachines/Gateway. Confusing? Yes, I know.
eMachines sold out to Gateway. Guess what? Gateway SOLD OUT to Acer. Isn't this fun(?)
The motherboard is a Gateway MCP61SM2MA. Part number Gateway 4006232R.
1) Has one Parallel ATA connector on the motherboard.
[PATA. Term is also known as IDE. Just to be more confusing, it is also known as EIDE. Enhanced IDE brought out by Western Digital, back in the day. The reason PATA is used, is to help distinguish it from SATA.
Serial ATA. This will help you understand, ]
On the main Gateway support page I linked above, click on ->
Product Views.
In the list click on the blue -> Parallel ATA IDE connector.
2) The motherboard also has two SATA connectors,
On the Hardware Details list, click on the blue -> U - SATA connectors
Do not know if it is a PATA harddrive, (320GB), or a SATA harddrive?
Look at the label. Example on WD 160GB might be WD1600BEVT.
What is it on the 320GB?
Blank, new 320GB WD harddrive? BIOS isn't going to recognize it.
It hasn't been formatted.
WD does have a software tool to do this. Do I recommend this for a beginner? NO.
Better to install the 320GB in an economical external enclosure, and plug the USB cable from the enclosure into any available USB port on your computer.
Now you have a 160GB harddrive with WinXP on it, and 320GB's of extra storage.
Example (IMHO) of an economical external enclosure,
If you have no clue of what I have posted above, it is going to look like so much gibberish. Not my intent.
Not after 'Points'. Could give 2 cents.
{With this website you can rate ANY solution you see, and ALL solutions you see}
My intent is to teach. I have been at this for 8 years. (3 here, 5 elsewhere)
I want you to understand. Post back in a Comment, with the answers I need, from the questions I stated above.
We together WILL find a solution.
Jun 20, 2012 | E-Machines Computers & Internet
Is Hitachi 320GB SATA 2,5"
you perches ata to sata connector or sata to ata connector
Sep 07, 2011 | Hitachi 320GB SATA 2,5" HTS543232L9A300...
I have a Acer laptop 5000 series, Model.ZL5. It has a 80GB hard drive fitted. Is there a limit to how big a hard drive i can upgrade to?
This laptop supports Parallel connection for hard drive. Most PATA or Parallel ATA hard drives can only support up to 320Gb. There are some PATA hard drives up to 500gb. To answer your question, there is no problem on how huge the size of the hard drive. Just make sure you get a PATA hard drive. :)
Sep 02, 2011 | Acer Aspire 5100 Notebook
Hello, My my motherborad is ASUS p5rd1-vm;RAM1GB and hard disk is PATA 80 GB but the HDD is having some kind of problem and the windows have shown a warning about it several times. Now i want to buy a...
Yes, it's compatible with the motherboard, no, it's not compatible with the XP install disk because it doesn't have SATA support. And since Asus doesn't provides it special driver needed (one that must be put on a floppy) it means that you simply cannot install XP on this disk.
All you can do is to obtain another PATA hdd what ever its size and install XP in it. Then put the new SATA disk in and use it to store all the installed programs and all your files on it. As a bonus you won't lose them if the new PATA disk fails or XP gets corrupted.
Or install Vista or 7 instead of XP, the have support for SATA disks
Jul 28, 2011 | ASUS P5RD1-VM Motherboard
Have an HP Pavilion ze4935wm laptop. Want to upgrade to higher GB and RPM. What is the highest I can go with this type of laptop?
This is an older laptop that uses a PATA (sometime called EIDE or ATA-100) drive.
The largest drives commonly available in PATA type for laptops are 320GB, at 5400 RPM.
There are bigger and faster laptop drives, but they will not work with that laptop since the bigger drives require a SATA interface.
PATA drives are more expensive than their SATA equivalents, it might be better to invest your upgrade dollars into a newer laptop.
Apr 17, 2011 | HP Pavilion ze4935wm PC Notebook
I have a Toshiba Satellite A75-s2762 laptop. I am looking for a compatible hard drive to replace the original one that has failed. I would like the largest hard drive that will successfully work with my...
With that model you need a PATA hard drive. You can go as high as 320gb hd in that laptop. Now the higher the GB the more it costs and well that is up to you. I personally would stick with a 160gb 5400rpm drive for decent size and decent speed.
Sep 21, 2010 | Toshiba Satellite A75-S2762 Notebook
Can you let me know what is the maximum installable HDD capacity 0f Lenovo laptop 3000 C100.Can i upgrade present capcity of 40GB to 320GB ?
If you have windows xp with service pack 3, there is no limit. There is no limit if you run Vistaor Windows 7. If you don't have service pack 3, you are limited to 137 gb.
Dec 20, 2009 | Lenovo 3000 C100 Notebook
Hitachi SimgpleTOUGH 320GB portable HDD - Not recognized
Make sure you are using the right USB cable. Also try on a different USB port (preferred one on the back of the PC)
Can you see the HDD on "Disk Management?"
Also if you hear any clicking sound then the HDD has become faulty.
All the best!
Aug 10, 2009 | Computers & Internet
Computers & Internet Logo
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
