Question about Legacy Audio LA1030 Car Audio Amplifier
Amp no longer turning on
My Legacy LA1030 amp has stopped working. The power light nolonger comes on however there is a constant DC voltage on the speaker outputs even with no input signal. What do you think has blown?
  • philmarsden Oct 05, 2008
    Yes the speakers do move ( cant remember which way) when the amp is powered up. I have also checked it with a volt meter think there was about 3v DC across the speaker outputs
  • 631 Answers
Do the speakers push out or pull in when power is applied?
If not, how did you determine that is has DC on the speaker outputs?
Posted on Oct 05, 2008
How much is a LA 1030 LEGACY amplifier?
It is old, so cheap secondhand. I found one for 40 GBP.
http://retrorides.proboards.com/thread/54783/legacy-la1030-1000w-price-blackpool
There are a number of better Legacy amps on eBay.
Legacy Car Audio Amplifier
Jan 17, 2016 | Legacy Car Audio & Video
Amp turns on but puts out no sound except for faint noise which dies out after a few seconds.
It sounds like a defective/incorrect AC-to-DC adapter may have caused your problem. These adapter come with different output voltages, AC or DC output and different amperage ratings. AC-to-DC adapters list the polarity of the DC voltage as it relates to the DC power plug and you must match both the devices voltage and power requirements. As for the amp...not working on batteries either, I would suspect output transistors or IC.
May 23, 2014 | Marshall Amplification Marshall MG2FX...
Photocopy canon not working ido why irc2380i
The problem with using a generator with a copier is that you are not using a constant wave length & a constant voltage. It is not a constant and level voltage as compared to a outlet. Also, there may not be enough watts. Copies today need a constant watts & voltage to work correctly. The PCB are very sensitive to any voltage drop at all.... Mostly 5 & 12 & 24 volts DC. A generator dos not produce a clean AC voltage. It's OK for a light bulb or a frig or micro wave...... Good Luck
Dec 19, 2012 | Office Equipment & Supplies
Protect Mode
Your probably not pusing enough wattage to the amp. Look into buying a capacitor for your set up. and you may need to run a thicker guage wire to your amp.
Jun 01, 2009 | Legacy Audio LA1030 Car Audio Amplifier
It does not turn on
Find and check the internal fuse....make sure you have a constant 12v+ (big red wire) when the ign. is OFF,and a switched 12v+, and a GOOD ground. It should make a clicking noise as it powers up.....if not, it's a boat anchor......sorry.
May 28, 2009 | Legacy LA938 Car Audio Amplifier
Amp problem
Have you checked the fuses on the amp?
Have you confirmed that you have both B+ and remote voltage at the amp?'
When measuring the voltage, place the black meter probe on the ground terminal of the amp.
Sep 17, 2008 | Legacy Audio American Legacy II LA690 Car...
Distorted Bass
Check the specs on the required ohms for the speakers. If it calls for 8 ohms and your speaker is 4, then you are pulling twice the normal current and this has blown an output transistor.
Mar 02, 2008 | Legacy Audio LA1030 Car Audio Amplifier
Protection Mode? amp wont start
With your multimeter set to DC volts and the black meter lead on the ground terminal of the amp, touch the red lead alternately to the B+ and remote terminals as the amp shuts down. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is dropping too low.
If the voltage remains near or above 12v, disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Nov 29, 2007 | Power Acoustik LT960 Car Audio Amplifier
No Power
Hello jasper100, Have you opened the unit to take a look inside? Since you dont have a blown fuse we cans assue the a short has not occured. Now I would chect to see if the voltage regulator in the amp has voltage coming from it. It may not in that case you may have to remover the old regulator and put in a new one just to get to the point of properly troubleshooting this amp. I would suggest that you get a schematic for this unit and use a multimeter to look at the voltages in the power supply section and see which sections have no rail voltage (12v supply voltage). I would also advise checking the remote to for regulator failure.
Sep 10, 2007 | Legacy Audio Blue Diamond LA580 Car Audio...
Legacy Audio LA1030 Car Audio Amplifier Logo
83 people viewed this question
Top Legacy Audio Car Audio & Video Experts
Mark Skinner
Richard Lukszys
Richard Lukszys
Are you a Legacy Audio Car Audio and Video Expert? Answer questions, earn points and help others
