My computer will turn on but it will not show up on the monitor.
    Master:
  • 377 Answers
If you have access inside the cpu. try to remove the memory strip for a while. then put it back again.
let me knw.
Posted on Oct 04, 2008
Monitor goes black seconds after showing desktop
Does your monitor go black because it went to sleep, does it turn off? Do you have any lights on the monitor to indicate what it is doing?
Also I would boot into safe made by rebooting the computer & tapping F8 when the bios appears. You should be prompted with several options, one of which is "Safe Mode". Choose this & report how the monitor behaves.
Jul 24, 2012 | Acer X193W LCD Monitor
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
Monitor turns on and computer runs monitor is plain
look like ur RAM is crrupted...if u can see some alpha numeric char while starting then screen is OK
or Windows may be corrupt...
May 08, 2010 | HP Vs17 17" LCD Flat Panel Monitor
No picture, monitor won't show anything black screen. Monitor was working fine put it on another computer and it won't show images. Could it be part of the power saving system? Is there a reset button?
Does the monitor show absolutely nothing, not even when first turned on? In that case maybe the cable could be defective or connected improperly, or the new computer might not be compatible (or set to output to, say, digital port, while you've got a SVGA monitor). In that case you'll need to connect a working monitor for the time required to reconfigure the computer.
If the image does appears at boot, or resetting the computer, and then disappears, it could be that the new computer is set to a resolution which is too high for the monitor, which goes in protection mode and effectively turns off. Again you'll have to gain access to the computer (maybe booting in Safe Mode) and lower its video resolution to something the monitor can handle.
Hope this helps, have a nice day
Jan 12, 2010 | Sharp LL T17A3-B 17" LCD Monitor
Nothing is showing on the monitor
just your monitor back panel open next monitor neck board put dry solder
Sep 26, 2009 | Compaq Computers & Internet
LCD shows only Gray when turned on.
You should try VGA and/or Digital Video output.
Aug 08, 2009 | ViewSonic VG2030wm LCD Monitor
Cpu no up, monitor shows
could be the whole pc is fried :(
Jul 10, 2009 | Computers & Internet
Monitor shows ''NO SIGNAL''
This is normal. The monitor is telling you it is not getting a signal from the computer, which is true because you've turned off the computer. The monitor power is still on, however. The monitor power is not controlled by the computer power switch. Just turn it off with its power switch after you shut off the computer.
Nov 23, 2008 | Computers & Internet
Monitor problem
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
The monitor turns off and on repeatedly.
There is a loose connector on the cable or the cable attachment on the PC board. Jiggle the connector as its connected and see if this causes the LCD to fire up.
Sep 01, 2008 | Dell 1503FP 15" LCD Monitor
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
