Question about D-Link AirPlus G DWL-G122 802.11g/b Wireless Adapter
Connection The lap top is asking for the pass phrase or security key - not sure what this is. I have tried entering the network name and the encription key but it does not work
    Master:
  • 377 Answers
Go to 192.168.1.1 or 192.168.0.1 login as admin. there is no password, along the top you should see something like an administrator tab or something, play around inside there and set it up.
Posted on Oct 04, 2008
How do i find a key for my linksys router?
Try the following procedure on a computer that's directly connected to one of the router ports with an ethernet cable. This procedure will not work if you're connected wirelessly. Open a web browser, such as Internet Explorer, and type in http:192.168.1.1. A window should pop up asking for a user name and a password. Don't enter a user name and type admin for the password. Hit ok. The router setup screen should come up. Click on the Wireless tab and then the Wireless Security sub-tab. You should be able to see your present wireless network security key on this screen. You can also use this screen to change the key if you want.
If you want to make some changes first select the security mode you want to use.
I believe WPA gives better security but I've had some trouble using it on older computers. I use WEP. I've been able to get this encryption scheme to work with all of my computers. Next select the type of encryption. I like 128 bit 26 hex digits. Next enter a pass phrase and hit generate. The pass phrase is like a password. It should now generate four 26 character keys made up of various letters and numbers. Write down the first key and make sure you've checked the 1 box for default transmit key. Save your setting and exit. You wireless network is now secure. If you try to connect to it using a wireless device you will be prompted for a security key. Depending on the operating system you're running, you may just be able to enter the pass phrase or you may need to enter the 26 character key you wrote down. You should only have to do this once for each of your wireless devices. After the first time they connect to the secured network they should automatically remember the security code. I hope this advice helps you out.
Nov 26, 2011 | Linksys Computers & Internet
How do i find my network key for my router lynksys wirelass wrt54gs
Nov 03, 2011 | Linksys Wireless-G WRT54GS Router...
Need to secure my router
Try the following procedure on a computer that's directly connected to one of the router ports with an ethernet cable. This procedure will not work if you're connected wirelessly. Open a web browser, such as Internet Explorer, and type in http:192.168.1.1. A window should pop up asking for a user name and a password. Don't enter a user name and type admin for the password. Hit ok. The router setup screen should come up. Click on the Wireless tab and then the Wireless Security sub-tab. You can set up encryption on your wireless network using this screen. First select the security mode you want to use. I believe WPA gives better security but I've had some trouble using it on older computers. I use WEP. I've been able to get this encryption scheme to work with all of my computers. Next select the type of encryption. I like 128 bit 26 hex digits. Next enter a pass phrase and hit generate. The pass phrase is like a password. It should now generate four 26 character keys made up of various letters and numbers. Write down the first key and make sure you've checked the 1 box for default transmit key. Save your setting and exit. You wireless network is now secure. If you try to connect to it using a wireless device you will be prompted for a security key. Depending on the operating system you're running, you may just be able to enter the pass phrase or you may need to enter the 26 character key you wrote down. You should only have to do this once for each of your wireless computers. After the first time the computer connects to the secured network it should automatically remember the security code. I hope this advice helps you out.
Apr 19, 2011 | Linksys Wireless-G WRT54G Router
Want to set password so only computers with password can use it
If the router hasn't been accessed before it is simple. Just open your web browser and in the address bar type 192.168.1.1 a window will appear and ask for a user name and password. Leave the username bland and type ADMIN in the password. This should get you into the router configuration. Just look at the top navigation bar and look for wireless. Once there look for security. Once there you can "name" the network and choose a pass phrase. Make sure to SAVE CHANGES. Once done then any computers wishing to access your network (internet) will have to have the pass phrase. I use WPA personal and TKIP pass phrase. You can also disable the SSID broadcast, so that no one can search for your network.
Jan 23, 2011 | Linksys Wireless-G WRT54G Router
I believe my system is being hacked. How do I secure my router if I can't find my software.
Try the following procedure on a computer that's directly connected to one of the router ports with an ethernet cable. This procedure will not work if you're connected wirelessly. Open a web browser, such as Internet Explorer, and type in http:192.168.1.1. A window should pop up asking for a user name and a password. Don't enter a user name and type admin for the password. Hit ok. The router setup screen should come up. Click on the Wireless tab and then the Wireless Security sub-tab. You can set up encryption on your wireless network using this screen. First select the security mode you want to use. I believe WPA gives better security but I've had some trouble using it on older computers. I use WEP. I've been able to get this encryption scheme to work with all of my computers. Next select the type of encryption. I like 126 bit 26 hex digits. Next enter a pass phrase and hit generate. The pass phrase is like a password. It should now generate four 26 character keys made up of various letters and numbers. Write down the first key and make sure you've checked the 1 box for default transmit key. Save your setting and exit. You wireless network is now secure. If you try to connect to it using a wireless device you will be prompted for a security key. Depending on the operating system you're running, you may just be able to enter the pass phrase or you may need to enter the 26 character key you wrote down. You should only have to do this once for each of your wireless computers. After the first time the computer connects to the secured network it should automatically remember the security code after that. I hope this advice helps you out.
Jan 16, 2011 | Linksys Wireless-G WRT54G Router
I have the Linksy router set up fir my lap top. I just purchased a kindle and want to conect to the wirelss using the router. It appears on the wirelss set up on the kindle - when I enter the password and...
Recheckyour password at the router. start your browser on the laptop and type 192.168.1.1 into the address bar. A pop up window should appear for you to "log into" your router. IF you have never done this then leave the user name blank and type "admin" in the password. Once your connected to the router, choose "wireless" from the top menu and go to wireless security. Make sure your security settings are set and what the "pass phrase" is. maybe reset a pass phrase and choose WPA for the settings.
Dec 31, 2010 | Linksys Wireless-G WRT54G Router
Set security pass code
After connecting modem(1) to router (2) connect your computer (3).
(4) Power on your modem, wait for modem to cycle(approx 2 minutes)
(5) Power on your router.
(6) Insert your CD - Click Router Setup & follow steps to setup secure wireless network...
NO CD DRIVE INSTALLATION
IN YOUR BROWSER ADDRESS FIELD:
http://www.routerlogin.net & click ENTER
1. Enter the router User Name admin & default password password to open your router's main settings page.
2. Main settings page, you'll be asked if you want to "Check for Update". Click Cancel. ( you can always check for new firmware after you're connected to internet)
3 Choose first menu item on left; Setup Wizard & make sure YES is selected
click NEXT, follow prompts complete setup.
SET UP WIRELESS SECURITY
  • 1. From main page choose Wireless settings
  • 2. Name your network- something easy to remember (Hint* People see it when you are up & running, write it down as well!) {The default name is NETGEAR}
  • 3. Select your security method. NETGEAR recommends: WPA-PSK(TKIP +WPA2-PSK (AES).
  • THEN, enter a Pass-phrase {Write down also, you will get e-mail confirming registration etc... But, BSTS.
  • NOTE: Both your Network Name (SSID) & Pass phrase are case sensitive. Network name, Security method & Pass phrase must all be the same on all the wireless devices connected to your router.
  • 4. Click APPLY & close your browser.
Depending on your cable/internet provider- if these instructions don't do it,
one of their agents should be kind enough to assist?
I was lucky enough to have them do it with me over the phone, after I had surgery & got sick of looking of the thing in the box in my floor!
Good Luck!
Dec 02, 2010 | NetGear Computers & Internet
What is wpa pass phrase while setting wireless printer
WPA with a Pre-Shared Key (PSK), also known as personal. PSK is entered as a pass phrase between 8 to 63 alphanumeric characters in the ASCII format at both ends of the wireless connection. Although PSK accepts a minimum of eight characters, for proper security, it is a good idea to use ample length and should not use a commonly known phrase. This phrase is used to generate session keys that are unique for each wireless client.
WPA pass phrase is a password for the wireless network to make it secured. You can obtain the WPA pass phrase when you access your router. Check the manual of your router for the address, username and password of your router. Go to wireless settings, you will see ther the SSID or Network Name, Network Key or the Pass Phrase and Authentication (WPA/WPA2/WEP). You can personalize the SSID,Network Key and Authentication. Remeber that for you to connect wirelessly the Authentication and Network Key on the router should match the Network Key and Authentication of the Printer or Computer.
Thanks for using Fixya,
Aug 06, 2010 | Computers & Internet
I have a wpn824-2 and I am trying to set up a connection from my lap top. It is asking me for a network key or wep key. Where do I find it?
You can get the WEP or Network Security Key from the Router.
Login to the Router as follows (make sure that it is connected to the Computer using LAN-Wired connection):
1. Start the Web Browser like Internet Explorer or Firefor or Safari.
2. Type 192.168.1.1 as the URL.
3. Type "admin" as user name and as "password" as password.
4. Go to the "Wireless Settings" option.
5. Set the Wireless Network Password (either WEP or WPA key) will be listed next to Security Encryption.
You may also use any third party utility to get the Wireless Security key save in the Computer (in which wireless connection is working and key is saved).
Good Luck!!!!!!!!!!!!!!!
Nov 19, 2009 | NetGear RangeMax WPN824 Wireless Router...
"security key/pass phrase"
Yes, it will set it all back to factory defaults
to set the security again on the router Support site for D-Link is here http://www.dlink.com/corporate/worldwideoffices/?redirect=/default.aspx In principle: Connect your PC to the router with a cable to one of the LAN connections - Now you need to Log into the setup of the router - to do that open a web browser, use Internet explorer (some routers setup pages do not work correctly with other browsers) In the browser address bar - http://192.168.0.1 Enter (admin) for the user name and also for the password. Now you can goto the wireless section or secruity section and set the type of encyption to WEP, WPA, WPA-PSK etc and then make up your own password
On the PC Double click on the wireless connection in the system tray (bottom right hand side of screen) and then connect manually to your wireless signal - you will be asked for the password you set in the router.
Now you are connected.
You may need to remove any old wireless profiles you have on the PC/Laptops
Wireless Profiles - Vista/Windows 7: http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm http://www.tp-link.com/support/showfaq.asp?id=214 - delete the wireless profiles Start> control Panel> classic view> network and sharing center> manage wireless networks Delete the profiles you will then have to enter the wireless security key for any networks you connect to --------------- Wireless Profiles - XP http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm http://www.tp-link.com/support/showfaq.asp?id=186 - delete the preferred networks start> control panel> network connections> right click on the wireless connection listed wireless networks tab in the preferred network list click on each one and - remove button
Dec 19, 2008 | D-Link Wireless
D-Link AirPlus G DWL-G122 802.11g/b Wireless Adapter Logo
71 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
