Question about HP Office Equipment & Supplies
Hp photo smart A440series printer model number VCVRA-0703 paper feeder at back of printer keeps jamming it is not guiding the paper through machine, slips teeth not catching or roller
    Master:
  • 377 Answers
Try to put more paper that the printer can hold..
let me know
Posted on Oct 04, 2008
Printer says paper jam on calibration
If you check closely, you may find there is a small piece of paper trapped between the rollers?
Feb 21, 2013 | HP PhotoSmart 7760 InkJet Printer
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
Paper jam
From the reference manual for your Photo Printer
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=60202&prodoid=58654761
"Epson Stylus Photo R220 Series Printers"
The Paper Jams
Press the font29.gif paper button to eject the jammed paper. If the error does not clear, turn the printer off, open the printer cover and the CD/DVD guide. Remove all of the paper inside, including any torn pieces, then close the CD/DVD guide. Reload the paper, then press the font29.gif paper button to resume printing.
r_note.gif Note: r_space.gif If you cannot remove a foreign object easily by yourself, do not use force and do not disassemble the printer. Call Epson for assistance.
If your paper jams frequently, check the following:
  • The paper is smooth, not curled or wrinkled.
  • The paper is of high quality.
  • The printable side of the paper is face up in the sheet feeder.
  • The paper stack was fanned before loading.
  • The paper is not loaded above the triangular load-limit mark on the left edge guide.
  • The paper stack fits under the tabs inside the edge guides.
  • The number of sheets in the paper stack does not exceed the limit specified for that media.
Feb 13, 2011 | Epson STYLUS R230 InkJet Photo Printer
The printer keeps telling me it's out of paper, which it isn't
1> Open the sheet feeder cover and pull out the paper support.
Set paper, aligning the right edge of the paper to the cover guide with the paper's print side facing up.
Pinch and slide the paper guide to the paper's left side.
Note: Make sure to set paper lengthwise. Setting Credit Card sized paper long-side down by mistake may cause a paper jam.
Pull down the paper output tray supporting with both hands.
Pull out the extension completely.
Ensure that the Power lamp and the Auto Sheet Feeder lamp light.
Note: If the Cassette lamp lights, press the Paper Feed switch to light the Auto Sheet Feeder lamp.
If the Auto Sheet Feeder lamp does not light even after pressing the Paper Feed switch, Paper Source in the printer driver may be set to the setting other than Paper Feed Switch.
Nov 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
WILL FEED PLAIN WHITE PAPER BUT WILL NOT FEED PHOTO PAPER
Follow the steps:
•1
Turn on the printer and press the Paper Feed switch until the Auto Sheet Feeder indicator light turns on.
•2
Pull up on the paper sheet feeder on the top and back of the printer and slide out the paper support.
•3
Take a stack of no more than 10 pieces of photo paper and flatten the corners, if they are curled. Curled corners may cause jams within the printer.
•4
Place the paper in the paper sheet feeder with the printable side of the paper facing up. The printable side of photo paper is the shiny or whiter side of the paper.
•5
Print your documents as needed.
Paper Cassette :
•1
Switch on the printer and press the Paper Feed switch until the Cassette indicator light turns on.
•2
Pull on the cassette on the bottom of the printer to slide it out of the printer.
•3
Flatten the corners of a stack of no more than 10 sheets of photo paper if the corners are curled. The paper may become jammed in the printer if the corners are curled.
•4
Place the stack of paper in the cassette so the paper is touching the right side and the printing side of the paper is facing down. Adjust the plastic paper guides so they touch the paper. The paper stack guides help facilitate the paper moving into the printer.
•5
Slide the cassette back into the bottom of the printer. The printer is ready for printing.
Oct 20, 2010 | HP PSC 2355 All-In-One InkJet Printer
Printing pictures photo paper gets jammed half way?
There are many reasons why your photo paper gets jammed, but here the most common ones:
- The photo paper is crumpled, or the edges are fold. Be sure that the paper is completely straightened out before putting it in the feeder.
- Your tray lock is larger than your paper. It is recommended that you keep your tray holder lock the size of your paper. The best way is still to keep a .5cm allowance.
- There is something blocking the feeder which causes the paper to go out of track. Are you sure there isn't a crumpled paper or torn paper left with the feeder?
HTH!
Dec 12, 2009 | HP LaserJet 5200 Printer
Documnet feeder jam
Check input paper feeder at top too - easy to miss. Top flips open with a firm (but not excessive) pull, so you can look there.
If you are sure you've opened and looked under every available panel on the printer (there are many!), turn it off and unplug for half a minute. Make sure all panels are back properly in place, but leave out the paper tray (and no paper either in the rear input paper feeder).
Plug in and turn on. Wait for it to finish its start-up sequence - it should complain about no paper.
Check the paper is flat and straight in the paper tray, and no excess room between paper and guides, and put it in again.
Print test page.
How is it now?
Sep 15, 2009 | HP LaserJet 3055 All-In-One Printer
Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Lexmark T644 Laser Printer
HP Deskjet 3550 keeps printing in pink
HP Deskjet 3550 MODEL NUMBER:VCVRA-0202
Feb 05, 2009 | HP DeskJet 3550 InkJet Printer
HP PSC 2355 won't feed photo paper
You can't use the photo papers in this kind of printers
Aug 01, 2008 | HP PSC 2355 All-In-One InkJet Printer
77 people viewed this question
Seeker5211
Seeker5211
