Question about Motorola Mobility L6 Cellular Phone
L6 phone phone fell into water took apart dry off working but not totally,keypads nnot working right when turn on/off seem to be the only button working also falshes on/off when in charging stage.Any advice will be appreciate.
  • japoy Oct 16, 2008
    need motorola l6 security code
Need security code for my motorola l6
Posted on Oct 16, 2008
  • 435 Answers
Hi!
My phone also fell into a bucket full of water. I just gave the phone to the service center for repair and it's now absolutely fine.
I would suggest you to do the same. Also, don't try to switch on the phone as it may lead to short circuit in your phone.
Thank You
Posted on Oct 09, 2008
My phone fell out of my pocket while running and i didn't find it until about 45 minutes. The prblem was that it was misting outside and it fell apart. I got it, its all dried out, and now it only will...
Take out the battery and put everything in a ziplock bag filled with dry, uncooked rice overnight, if it still doesn't work after, there is a short in e circuitry,
Oct 29, 2013 | Pantech Cell Phones
Fell my xperia s in salt water
This happened to my phone once, I just took it apart (the bits I could, sim card, battery, cover etc) then dried it for quite some time with a hairdrier (on a cool setting) then left it over night apart. Put it back together in the morning and it worked. I'm guessing there was still water/ moisture inside of it to stop it working..
Mar 04, 2013 | Sony Ericsson Sony Xperia S Lt 26i 32gb...
My phone screen went blank after dropping in the toilet
You should have left it dry instead of turning it on, you probably have corrosion now, find a local place that works on phones to see if they'd work on it.
If you want to try to completely dry it, put it in rice for 24 hours minimum to draw out all moisture.
Aug 03, 2017 | Motorola Mobility RAZR V3
Dropped phone in water
SIM is probably bad or a little wet. but wait and let everything dry out and see if it works. Mine was soaked and the next morning worked fine. at least you probably won't have to buy a new phone.
Apr 28, 2009 | Samsung SGH-t229 Cellular Phone
I spilled sprite on my g1!!
I dropped my motorola sliver in the bathtub full of water and it quit working totally. I called ATT where I got the phone and they told me to look under the battery. I lifted out the battery and they asked me if there was a white dot under it. I told them no but there was a red one. They said "gone". Meaning that the dot was usually white but if it turns red, the circuits are water/liquid damaged and to throw it away and get another phone. Look under your battery.
Apr 17, 2009 | HTC G1 Smartphone
Hi my k850i fell into water. The phone seems to be ok except the keypad or touchscreen doesn't work and so am unable to unlock the phone. Will it eventually dry out? I've used the hairdryer and dried out...
turn the phone off, remove the battery, replace the battery cover. Place the phone in the center of a bag of dry (uncooked) rice. Close the bag and place in a warm area overnight. check the phone in the morning for proper working. The rice will help "pull" the moisture out of the unit. If after the first attempt does not correct the problem, attempt it once more. If this does not correct the problem, the unit will require servicing.
Hope this gets ya fixed with out the cost of servicing.
Please take the time to give this solution a fix ya rating.
clarkco
Apr 12, 2009 | Sony Ericsson K850i Mobile Phone
What to do with a pone full oif coffee?
its too late to do anything youh should have took it apart and dried it out with a hair dryer let it sit over night than turned it on in the morning thats what i did when mine fell in mop water and it worked after the next day
Jan 01, 2009 | Sanyo MM-8300
Left colum of buttons wont' work
There may still be some water or moisture under the keypad. The water may leave some conductive residue. The phone should be taken apart and properly cleaned and dried. It is also possible there there may be water damage and parts will have to be changed.
Jerry G.
Jun 11, 2008 | Samsung SCH-u340 Cellular Phone
Water damaged Moto razor
I know you don't want to here this, so be kind with your rating, but the best solution is a new phone. The reason is this: no matter what you do, water is a conductor and the dried residue it leaves behind will also short things out. And water will get to places that you can't.
Sorry, hope that helped save you some time...
Geno
Apr 03, 2008 | Motorola Mobility RAZR V3
Motorola Mobility L6 Cellular Phone Logo
132 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
