Question about Boating
Minn kota 80 can't get back together
Took of propellor to remove fishing line and also removed the 2 bolts behind and now can not get back together. what am i doing wriong. it has the transducer built in
I have a minn kota riptide 80 and here noise when i come to 25 or a bit more then it quiets down but at full it is really noisy. not metal clanky but like an eletric motor. it did not sound this load before. it is a used unit
Posted on Oct 27, 2008
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    How to align the prop and nose (bottom) with the handle (top)
    FISH307 com Fishing Tackle Superstore
    This is a link that will allow you to look at a schematic for you motor.
    Minn Kota hand control motors have a small nut/bolt thru the motor shift aligning the handle with the lower unit. If yours does not line up your either missino this bolt or a previous owner altered the motor.
    Hope this helps.
    Oct 18, 2014 | Minn Kota Riptide St Saltwater 80 Bow...
    Have Minnkota endouro 50 trolling motor...got fish line tangled around it and it stopped. took off propeller and removed all the line andout back together but will not work at all now. what is wrong? Ive...
    I have to say that this should be your first response to the problem.
    As for fixing, you need to make the decision if what the repair cost would be and shipping over a new unit, due to how much use and it's age. Warranty.
    Our customer service representatives are available Monday - Friday between 7:00am - 4:30pm CST
    at 800-227-6433. If you are calling to order parts, please have the 11-character serial number from your product, specific part numbers, and credit card information available. This will help expedite your call and allow us to provide you with the best customer service possible. You can reference the parts list located in your manual to identify the specific part numbers.
    Now if you just plan on getting a new one, you can remove the top cover, and if you have a Muli-Meter and know how to use it.
    You can check to see if power is going to the switch, you can check the switch, you can check to see if the throttle is sending power to the lower unit.
    If the problem lies in the lower unit it's likely it needs to be sent in.
    Apr 14, 2013 | Minn Kota Endura 55 42 In Trolling Motor...
    How to remove the prop
    there is a plastic nut that screws onto the prop shaft and needs to be unscrewed. there is also a metal pin that goes through the shaft that needs to be in place and in the right position when you replace the prop. make sure you clear out any fishing line etc that may have collected behind it when you change props.sually recommend you put a little clear silicone grease on the parts as you assemble them as well.ake sure you disconnect the power leads from the battery while your doing this to avoid injury.
    May 27, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    We have boat that came with trolling motor, boat not used in 5 years what should we do to service the motor/minn kota 40at before we put in water we hooked to battery it spun and quit?? not sure what to...
    My guess is the motor has leaked water into the lower motor assy (behind the prop). and needs to be cleaned up and the brushes replaced.
    here's a schematic:
    Edge 40
    You can try this to check for water leakage:-
    1) disconnect from power supply
    2) remove the prop
    3) you will see 2 bolt heads behind where the prop was. Remove ONLY ONE of them for now.
    4) if you see the bolt (it's about 8" long) is covered in what looks to be blask, oily/watery or rusty condition then you know that you'll need to overhaul it.
    5) if it IS the motor assy, remove the other bolt and disassemble everything noting their location.
    6) I would recommend replacing the brushes Part# 188-052 and the seal kit 2883460.
    Sep 23, 2009 | Minn Kota Edge 40 Freshwater Bow Mount...
    TOOK THE BOLTS OUT OF MINN KOTA AND CANT GET THEM IN. 2 SHORT.
    Hi!
    Here's a schematic:
    Max 74 Bowmount
    Make sure the end housing #7has a small mark in it pointed to the bottom (towards the skeg). The bolts can be a pain to line up!
    Also make sure the armature is all the way forward it can go....past the brushes is the toughest part to get through and lined up. Keep it up, you'll get it!
    Best of luck
    Mike
    Jul 05, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    I have a Minn Kota Endura 30, transom mount. Just wondering, is there a way to rotate the controls so that I could use the motor on or near the bow of my 15' Aluminum fishing boat?
    There is kind of a collar on the lower side of the head where the head connects to the shaft. There is a single bolt that runs right thru the shaft at this location, remove it. Rotate the head 180 degrees and re-install the bolt. 5 minute job.
    Mar 10, 2009 | Minn Kota Endura 30 Freshwater Transom...
    Minn Kota Model 35 24lb thrust transom trolling motor not getting power
    It might help to view drawings at http://secure.northlandmarine.com/MinnkotaTillerSteering.html.
    The spring loaded items are brushes. They carry current to the rotor/shaft/impeller causing them to spin. I have two Model 35s. One failed after a couple hours of use. The other was given to me because it did not work. Both suffer from water getting into the motor and causing corrosion and sticking brushes. Someone on another site commented that this was a common problem for Minn Kota.
    Jul 17, 2008 | Minn Kota Endura 30 Freshwater Transom...
    Minn kota turbo 35 27lb thrush trolling motor
    I have a minn kota turbo 35 27lb thrush trolling motor after 3 hours of running it the motor dies
    Mar 01, 2008 | Minn Kota GPS
    Boating Logo
    188 people viewed this question
    Top Boating Experts
    Steve
    Steve
    ray gallant
    Fabrice Wolters
    Are you a Boating Expert? Answer questions, earn points and help others
