Question about Maytag Atlantis MDE7400AY Electric Dryer
Drum Turns, but dryer won't heat up.
This happened before and when I took it to be repaired, they told me the connector for the heatig unit had come unplugged.
Where is this connector, and how do I access it?
Thanks
  • Maytag Master
  • 19,396 Answers
If the dryer does not heat at all then is either a problem with the heating elemet , or with the thermal fuse.
See the following suggestions from Repairclinic:
There's no heat If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Oct 04, 2008
Why won't it start?
check for the operation of a small micro switch at the door hinge
if that is out of adjustment then the unit will not start
Jan 05, 2016 | Bosch Dryers
There's a slight burning smell coming from the dryer drum.
Some item may have gotten between the drum that rotates and the housing and during the rolling of the drum this item may be heating up from the friction. Check closely to see if you can find anything rubbing on the drum.
Jan 22, 2013 | Maytag PYE2300AY Electric Dryer
My dryer won't heat up. where is fuse box for kenmore stackable 41794813301
Behind this drum on the upper left hand corner is the fuse
If it was tripped however the dryer would not operate as it is tied into the door switch.
You can get a restring kit for less than 20 bucks for these
Get top off then the controls off there then remove the front like this:
The heater is on the back side of the drum so it has to come on out
I did a repair on a similar dryer last year and took some photos
Nov 02, 2011 | Kenmore 98702 Stacked Washer/Dryer
My dryer turns on and heats, but the drum won't turn. I checked the belt and it is fine. No motor noise or anything. What next?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 25, 2011 | Whirlpool GEW9250 Electric Dryer
The dryer drum does not rotate at all. The dryer itself will "click" on when I push the start button and you can hear the dryer and feel the heat but the drum won't move. We took the entire...
heatman101
Aug 08, 2011 | Dryers
Dryer spins and drum turns, but only cold air c...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | Kenmore 800 7982 Dryer
Drum still turns but no heat where do i find the heater
heatman101
May 12, 2010 | Maytag PYE2300AY Electric Dryer
Dryer drum turns, no heat, replaced thermal limiter
Your model which we call the 417, is not usually easy to work on. The heating element is located behind the dryer drum. The drum has to be removed to change the element. There is a lot involved but given the cost of a stack unit the element and labor may be worth it.
Feb 17, 2010 | Dryers
Kenmore Dryer Mod.76990100...shreiking noise when drum turns??
hi,
Dryer Is Noisy
1) Some noises are caused by objects bouncing around inside the drum. Scour the interior of the drum for loose objects.
2) If you cannot find any loose objects inside the drum, the noise may be caused by a defective part, such as a worn or defective drum belt, idler pulley, support rollers, glides, or worn motor bearings. It’s best to call an appliance repair service to replace these parts.
Thanks for using FixYa
Jan 03, 2009 | Kenmore 63942 Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
213 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
