Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Panasonic PT53WX53G flashing red light
Our Panasonic rear projection tv won't turn on and when we press the power button the red light flashes five times, pauses, then flashes five times again; it goes through this process a few times. Do you know what is wrong and how we can fix it?
Thank you!
techman
  • 3130 Answers
SOURCE: Panasonic PT53wx53g Rear Projection TV screen cracked
You can try it, but through my experience, it just does not look good. You may not have a problem with it. Give it a shot. Good Luck.
Posted on Oct 16, 2007
DOCTOR VIDEO
  • 131 Answers
SOURCE: tv turns on for 1
Hi 3 blinks on panasonic is the conversion ics. very common repair for projectors. you need to replace two ics on mother board. The cost of the repair from a tv shop is 250,00.
At least now you Dont have to pay a service center to come out and diagnose
Just give them your model number and they can look up the parts. The job take 1 hour to do or so.
I hope this help thanks doctor video leadingedgeelectronics 1987
Posted on May 04, 2008
SOURCE: Panasonic rear projection model #- PT53WX53G will not turn on.
Happened to me, relays, either 1 of 2 so I had both replaced, about $300.00 to fix.
Posted on Nov 24, 2008
jhinsincity
  • 616 Answers
SOURCE: Panasonic rear-projection tv with no picture
sounds like a high voltage problem (flyback transformer) best thing to do is have a tech look into it, can be dangerous. Julio milleniumtvsvc@gmail.com
Posted on Jul 23, 2009
Slinteriors
  • 8617 Answers
SOURCE: my panasonic pt53wx53g tv wont turn on. the power light blinks 3
thats the error for the convergence failure. You can get the repair kit for your model at www.tvrepairworld.com the kit contains the parts and the CD with detailed instructions
Posted on Sep 11, 2009
Red light flashing, tv wont turn on
need the model number of the panasonic and also how many times it is blinking. The blinking is an error code.
Aug 03, 2012 | Panasonic Televison & Video
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
Hello. My Panasonic PT-50LC13 is not turn on. First flashing green light for one minute on the power button then starts to blink red and at the same time it starts blinking red LED lights every five...
Check ur tv fan,if ur cooling fan are runnig,before all these LED lights are flashing.If not that ur tv problems.All these LED lights are flashing the tv making alots of clinking noises too like it trying turn itself on?Yes,than the tv board that called the Ballast board it is dead too,must be replace also.This tv Ballast board only job are to help to ignite the tv projection lamp only and keeping it on and running.
Aug 29, 2011 | Panasonic PT-50LC13 50" Rear Projection...
I have a panasonic projection TV, PT-60C13 that will not turn on. Upon pressing the power on button, the button flashes green many times, then flashes red five time then one orange flash. This red/orange...
The most common cause of Panasonic Rear Projection LCD TVs not starting is bulb failure. The PT-60LC13 users manual gives some help in translating the LEDs on the front of the TV.
If the TV worked normally for a period of time (months or years) and won't start, the most likely cause is bulb failure. There is no way to measure the bulb, sometimes the bulb is visibly damaged when it fails. Remove the Lamp Assembly and look at the bulb.
If there was an On-Screen Lamp Replace warning and TV won't start, bulb has failed.
The first step with all Panasonic Rear Projection TV "No Picture" problems is bulb replacement. If that does not remedy the problem, get a technician, there are no user serviceable parts. Guessing if the ballast, power supply, controller board or optical engine is faulty is not practical.
The Panasonic Lamp Gallery shows all Panasonic models and Lamp Numbers. There is also a link to Panasonic DIY bulb and lamp replacement.
easyab
May 05, 2011 | Panasonic PT-60LC13 60" Rear Projection...
Tv won't turn on.
  • Try resetting the lamp timer
  • Hold the Vol down button on the TV and the Split button on the REMOTE for five seconds, -or- Press the Volume button on the TV while pressing hte SPLIT button on the Remote Control for five seconds
  • It will NOT work if you try to do it both from your remote!
May 06, 2010 | Panasonic PT-60LC14 60" Rear Projection...
Won't turn on, flashing red light
It seems you ballast is going out, i recommend you replaced, don't waste money buying lamps with this issue, get the ballast, they run around 60dll so it's a good deal, go to discountdashmerchantdotcom i've been getting parts from them and they offer great service, it's worth giving them a shot :)
Oct 09, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-51HX43G no power, red light flashes
I have a Panasonic PT53TW53G projection tv that had the same problem for power .A terrific person gave us wonderful advice and it fixed our tv! We were told to replace the IC conversion amplifiers. On our model they are STK392-110 (your's may be different). We ordered the parts from www.electronix.com and they were only $12. for the two parts. We also had to purchase a soldering iron and de-soldering vac for removal/replacement of parts. Good Luck!
Feb 04, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
664 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
