Question about Cameras
Taking pictures I have a pink Sanyo VPC-S770 7.1 megapixel camera. When I hit the picture button, everything goes black. The lens does not retract, but the LCD goes black, and the camera seems like it turns off. I have not dropped it or put it anywhere dangerous for the camera. I don't know how to fix the problem, but I definitely would like it fixed. I bought the camera in July, if that helps.
    President:
  • 2,712 Answers
Try a hard reset first - Remove batteries and SD card, wait 5 minutes and reinsert everything and try. If the issue still recurrs, then best take it to the shop and check it out. You should still have the warranty on it. If they cannot fix it, ask them for a replacement.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 04, 2008
I push the button but it wont take a picture
Did you try it like it is said in the manual? press the button half till the camera is focused and then press the button completely down?
Don't expect the camera to shoot with the same speed as a camera with film did. Give it some time to focus and everything will be fine (I hope)
If not let me know.
Jan 02, 2014 | Sanyo vpc-s1415 - Vpc-s1415 14.0...
My sanyo vpc-s670r digital camera has a blurred shot. how can i fix this problem? i also clean the lens still blurred especially when shotting outdoor.
You must take pictures gently. Blur picture may occur if you move during capturing a picture. Or your hand move too fast after taking a picture. Try to stay still for two or three second after push the capture button.
Blur picture when shooting outdoor can be caused by too much light. Don't forget to set your camera in outdoor or panorama mode, and turn of the flash light if you think its too bright.
Hope this help and RATE please !
Jan 16, 2011 | Sanyo VPC-S670 Digital Camera
I have a sanyo camera 7.1 mega pink and everytime i try and take a picture my screen goes black and shuts off without the camera piece going back in! I have almost the same problem except when I take a...
In the first case, if the camera turns off by itself with lens not retracting, try fresh alkaline battery. If that does not work, then the ribbon cable from battery charger to mainboard inside the camera is probably causing the problem.
An internal contact can also cause same problem.
If instead pictures are completely black, then there are several possible reasons:
1 There is a setting problem, remove and put back batteries to fix the problem.
2 The camera curtain is stuck and it is not opening.
3 The CCD sensor is faulty, more likely the ccd sensor contacts are broken.
4 The lens assembly has an internal problem.
Apart situation 1 , in all the remaining cases the camera will need repair.
Regards.
Jun 01, 2009 | Sanyo VPC-S880 Digital Camera
Lens Error: 0x12110000 when previewing pictures in camera.
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 22, 2009 | Sanyo Vpc-s1070w Digital Camera
My camera wont take pictures
Is your battery fully charged? can you take pics with it pluged in? Is your memory full?
Jan 09, 2009 | Sanyo VPC-S500 Digital Camera
Zoom will not retract
I took the camera apart, painstakingly removing all the screws. Within the zoom area were two small loose pieces, one appeared to be a lens, the other a thin metal cover. I placed the parts back into their place, and put all the screws back, except for the case. When I did a test to see if everything would work..... Eureka !!! No, sorry, Darn!
The camera appears to be at the same status, turns on long enough to see the "For Service...." message pop on the screen, then the camera powers off.
I will be taking the camera apart again, and will use a meter to check connections.
Will report back if there is further progress on this situation.
Dec 09, 2008 | Sanyo Xacti VPC-T700 Digital Camera
Wont take pictures when i press the button
Ours is doing the same thing except we aren't in warranty. Had the camera 6 months and Sanyo wants $85 to fix it. I'll never buy Sanyo again. Take it back while you still can.
Jun 26, 2008 | Sanyo VPC-S7 Digital Camera
Cameras Logo
101 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
