My Palm Pilot has frozen THIS IS WHAT MY SCREEN SAYS: Real One Player Scanning for files... FATAL ALERT MemoryMgr.c,Line:3726 Non-word-aligned handle I cannot hot sync I cannot turn it off I cannot change the screen Any thoughts?
    Scholar:
  • 125 Answers
This particular variety of the Fatal Alert error usually results from a minor programming issue within a third-party application. For example, it could happen because the handle passed to a function like MemHandleUnlock or MemHandleFree is not zero. Our recommendation is to delete the application that is causing this particular variety of Fatal Alert. Then, write a quick email to the software's developer or vendor, notifying them of the bug in their software, so that future revisions can take the bug into account. Remove the battery from your pda replace it back again so your pda starts up. then take it from there and its usually an application that you just added to you pda. let me know if that helps Pam. Jaketasnake out.
Posted on Oct 04, 2008
  • 1,879 Answers
Application crashed
remove battery
Palm m515 frozed up when powered on.
Did you install something rare at your palm??? Is your palm Sayin "Fatal Exeption" when you Reset it??? If you install something rare and after that your palm is saying taht you can...
Do a soft reset:
Reset it normally... If after that your palm show again that message you can;
Do a warm Reset:
Pres de up scroll when resseting.. when you so the Palm logo you can stop press the reset botom... There you will see the configuration screen... If it is not more the "fatal exeption" message you can uninstall what is doing the problem... you can hot sync your palm now... after that... do a soft reset and-If you uninstall what is doing the problem- you are not going to saw any more that message... if it is not resulting...
Try to do a Hard Reset
Do a warm reset and copy all you important files or programs to your stick memory...
then when pressing reset botom pres the on-of screen botom.... when you see the palm logo you can stop presing on-of screen botom.
bye.
From paraguay... luis-c
(sorry for my english... im stilll learning)
Apr 14, 2009 | Audio Players & Recorders
Fatal alert
This is a common problem with the Tungsten line, You can try doing a hard reset. This worked for my E2. If that doesn't work, the battery must be removed for a few hours. Although it still may not work after the battery removal.
** To preform a hard reset, hold down the power button, and push the reset button on the back of the unit. The top of your stylus unscrews to expose a "plastic pin" for this purpose. Keep holding down the reset button while the unit reboots. You should see a palm screen displayed while it restarts, let go of the power button and follow the instructions. Pressing up on the pad ring should erase all data.
Feb 20, 2009 | Palm Tungsten T5 - Multilingual Handheld
Fatal alert memorymgr.c,Line:3732
Just happened to me after installing ThinkOffice. There is a reset button just below the labe "Made in China" on the back of the unit. Hold that button in with your stylus.
Nov 18, 2008 | Palm Tungsten E2 Handheld
Fatal Alert when doing hot sync on palm tungsten e2
you gotta do a hard reset. i had the same problem. go to the palmone website and look up how. make sure you back your stuff up in case you can't get things back. once you perform the hard reset the error should go away.
Nov 09, 2008 | Palm Tungsten E2 Handheld
Palm Tungsten E2 error
Everytime I got that error, press soft reset on back and it should reboot normal
Oct 12, 2008 | Palm Tungsten E2 Handheld
Getting a fatal alert
Make sure you have over 25% remaining space on your HandHeld and tryagain. Otherwise try a hard reset: Hold down the power button and clickthe reset button.
For more help:
admin@dec-help.co.cc
DEC Electronics Limited
www.dec-help.co.cc
Aug 14, 2008 | Palm Tungsten E2 (Multilingual) Handheld
Fatal alert
Do you have an MP3 installed on your Palm?
You might have to reinstall it.
Jun 13, 2008 | Palm Tungsten T5 - Multilingual Handheld
Note pad
Maybe some other program has modified the Notepad program. Back up all your files and do a hard reset. Still not work, call palm...
May 13, 2008 | Palm Zire 71 Handheld
Fatal Alert
Try breaking things up into multiple folders to limit the number of songs it has to display at a single time.
Feb 14, 2008 | Palm Tungsten E2 Handheld
Fatal Alert
Here is Epocrates answer: "... A fatal error when opening the Epocrates application typically indicates that one of our database files has become corrupt. HotSyncing again may restore functionality. If not, uninstalling and reinstalling our application should correct the problem. Other Fatal Error messages relate to not enough free memory on your mobile device for a complete installation or, your mobile device does not use the correct Palm OS version. Please verify you meet our minimum system requirements by returning to our web site, click Support, and then click System Requirements by your Epocrates application. Delete Epocrates Palm/Win from your mobild device. On your mobile device, tap the clock (located upper left corner of your screen), tap App then Delete. Select the following files (one at a time) then tap Delete. You may not see all of these files on your mobile device. It may take several minutes to delete a file. The file will disappear from the program list or your mobile device will turn off when complete. See Frequently Asked Questions 484 for instructions to preserve your notes * AutoUpdate or Libaupd * Cholesterol * Compendica * DocAlert * DocMemo * Drip Rate * Epocrates * Epocrates Dx * Epocrates ID * Epocrates Lab * Epocrates MedTools * Epocrates Rx * Epocrates MTH * Epocrates Startup * Epocrates Tables * EpoxLaunch * Fahr/Cels * HTN Ref * Insulin Calc * MedMath * MedToolsHack * MobileCME * Natrecor * OnBoardAU * Tutorial * UpdateEmail * Version-ep22 * Any file ending in NC-2 * Uncompressor * Any file starting with SMSH * Any file starting with ID and ending with NC43 Tap Done when finished. Disable the Epocrates conduit. On your computer, click on the HotSync Manager icon in the lower right hand corner of your system tray then click Custom. Double click Epocrates , select Do Nothing and check Set As Default. Click OK. Double click System, select Handheld Overwrites Desktop and check Set As Default. Click OK then Done. HotSync your mobile device to your computer. Locate and double click Epocrates2PalmW.exe to reinstall Epocrates. If you cannot locate this file, return to our web site, click My Account, login, click Epocrates Download then follow the remaining on-screen instructions. ..."
Nov 08, 2005 | Palm Tungsten T5 - Multilingual Handheld
Computers & Internet Logo
137 people viewed this question
David Payne
David Payne
