Question about Frigidaire Affinity ATF7000ES Front Load Washer
Frigidaire Affinity E20 error code - Frigidaire Affinity ATF7000ES Front Load Washer
  • 6 more comments
  • Laurie Nov 28, 2008
    I have the same problem & am curious to what you posted as an answer :)
    I have a Frigidaire Affinity washing machine ( 18 months old ) Error E20
  • keukg995 Dec 05, 2008
    Same problem- who can help?
  • drhmx69 Dec 10, 2008
    washer wont spin error code e20
  • loreyc Dec 18, 2008
    I have the same E 20 error code and the machine won't spin the water out of the clothes - help!!
  • freethem Dec 31, 2008
    That link doesn't work.
  • garygb Apr 07, 2009
    no code won't spin
  • cmg4 May 11, 2010
    Tried to access the link shown on the page that "solves" this problem(Check this answer: http://www.fixya.com/support/t615626-err... but it's bad...does anyone know what you're supposed to do?
  • 11 Answers
This issue is a clogged drain. It usually requires cleaning out the Drain filter underneath the drum assembly in your washer. If you are not handy, don't try this yourself, it will require some skill.
Joe the Plumber
Mid-Hudson Heating & Plumbing
Woodstock, NY
845 679-9158
Posted on Jan 30, 2009
    President:
  • 2,712 Answers
Check this answer:
http://www.fixya.com/support/t615626-error_code_e20
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 04, 2008
What do i do when my washer affinity frigidaire displays E20
Hello friend, thank you for your post!
I see your question is labeled under Frigidaire washer, ATF6000ES, and your washer is receiving an error code of "E20". "E20" stands for the water is not pumping out fast enough which means it could be an issue with your control panel or drain pump. I would recommend having a professional come out and properly repair your appliance. I hope this is helpful. -Matt
Sep 27, 2014 | Frigidaire ATF6000ES Front Load Washer
I thank you so much for your guidance on repairing my Affinity with the E20 code.I went through the process - It was totally clogged. I put everything back and the washer does not drain still. What do I...
The E20 code is a general pump failure code. This is usually the pump being clogged.
Try using a wet/dry vacuum on the end of the drain hose to see if there is a blockage that you don't see. If you still get the error you will need to replace the drain pump.
Here is the new drain pump to order.
Nov 25, 2012 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Error code 20 on an affinity frigidaire
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Oct 23, 2012 | Frigidaire Affinity ATF6000F Front Load...
When washer turns on there is a horrible buzzing sound, e 20 error message was on before
This is a blocked drain error code (E20) which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums, buzzes or whirs.
Error Code E20 on Frigidaire Front Load Washing Machines
Aug 25, 2011 | Frigidaire Affinity ATF7000E Front Load...
Error code e20
error code means that the coin trap/drain pump hose underneath the machine needs cleaned out due to being blocked.
Jan 11, 2010 | Frigidaire Affinity ATF7000E Front Load...
Error code E20
Hello there
the Dreaded E20 fault is a drain problem
washer will show the E20 code and may not spin.
So i would first look for a clog in the hose right before the water pump there is a little cup in the black hose that could be full of suff if so empty the cup and it should work good after this
hope this will help you out
Best regards Michael
Dec 26, 2009 | Frigidaire Affinity ATF7000E Front Load...
E20 code on washer : will not empty water on spin cycle?
something is stopping the water from drainning...check for kinked hose,,,check waste pipe,,,check units sump...onthejob
Dec 18, 2008 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
1,011 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
