Question about Sherwood RX-4103 Receiver
Sherwood stereo receiver-left channel gives no sound except occassional rumble
Have checked speakers and they are OK. right channel is fine
techman
  • 3130 Answers
SOURCE: Left channel out
probably I would say no. Unless you know how to read a schematic or know how to do certain small static checks on the output devices and the drivers as well as the power suppy feeding these devices.
Posted on Apr 05, 2006
SOURCE: no voice audio
Have you selected coax mode with the input button?. If so you may need to play around with the setup buttons. Can't give anymore advice as I've lost my manual. Good luck
Posted on Mar 16, 2009
SOURCE: Sherwood RD-7502 Hdmi Audio Problem
if you have a tv with outputs you can connect audio wires from your tv output to your audio receiver input and you will have surround sound for everything connected to your tv
Posted on Aug 28, 2009
Testimonial: "That's a good idea. I hope that my TV will output the hdmi audio through the optical output on it. Thanks"
  • 4234 Answers
SOURCE: I have a Fisher RS-717 stereo receiver, amplifier.
Yes you can use either A or B without a problem. The restriction is when you have both A & B connected. In that case, the speakers MUST be a minimum of 8 Ohm impedence. Using either A or B, you can use speakers of 4 Ohms impedence.
Dan
Posted on Nov 24, 2009
Testimonial: "Prompt answering, appreciate it very much."
SOURCE: Yamaha RX-550 receiver. Presently, no sound on
This solution helps! I got this unit from a friend and there was no sound from the left channel, and after playing with the input knob, there was sound.
I sprayed alot of electronic cleaner and it worked like magic.
the unit is now in full working mode.
Posted on Mar 22, 2010
What does left and right channel mean for a receiver
The left channel goes to the speaker on your left, and the right channel goes to the speaker on the right. The two are slightly different in order to give stereo sound.
Dec 23, 2016 | Audio Players & Recorders
Surround sound
there are 2 channel modes on your reciever, as well as surround modes, and it sounds like you have changed modes by accident. just open the little door on the front, and take it out of 2 channel mode
Mar 05, 2013 | Denon AVR 2808Ci Receiver
No sorround sound coming out of speakers out both left and right
I just repaired one for slow start .recapped the whole power supply board and now starts first go.I will check it out next week and post what I found
May 14, 2010 | Sherwood Audio Players & Recorders
Concerning my Sherwood RD-7500 6.1 Channels Receiver
That still doesn't make much sense. Please slow down and say what you mean with detail and accuracy. We're not mind readers. You are our eyes and ears.
Is the following true?
"Video 1" video output goes to the TV and works ok. Though it is irrelevant since you don't have a video problem. That you mention it at all is distracting. Do you feel it is important?
Tower speakers are the main or only speakers. Do they work ok for other sources?
So, to be clearer, you have a problem with a particular sound source (the game console) being less loud than usual. Is it unusable or drastically different in level than other sound sources?
Where and how is the game console connected for audio? Can you move it to another input?
Have you considered that the game console or its settings may be the reason volume is lower than usual?
Jan 19, 2010 | Sherwood RD-7500 Receiver
Sherwood Rx4050r and right speaker has crackling noises.
Ahh, that channel is blown. Its not 100% blown. This has happened to my freind before, and from my long knowlage in audio, the channel is blown, and is not fixable. If you REALLY are attached to it, you could probably bring it to a shop that fixes receivers, but best bet is to let it go
Oct 12, 2009 | Sherwood Audio Players & Recorders
No left channel sound
check wiring. if ok, swap speaker channels if ok, swap rca plugs, if ok. Bad channel on amp.
Jun 29, 2009 | Technics SA-DA10N 5.1 Channels Receiver
Sherwood RVD-9090R Left Rear Channel Failure
its due to your player there is nothing wrong with fuse... don't crack the case...try this just connect M1 & M2 to the aux input of your home theater
May 23, 2009 | Sherwood RVD-9090R
STG DR510 no sound on left front channel
Can I assume the calibration procedure also didn't work for the Front left channel? (It's not a "surround" if it's in the front). Switch the receiver to Stereo mode to eliminate any DSP actions. Tune an FM station to eliminate any external device or cable issues. What do you hear from the two Front speakers?
OK? Select a DSP surround mode. Check all modes. What happens?
If the channel goes dead using some or all DSP modes there's probably something wrong with the processor. If they all work...
Isolate the source that exhibits the problem.
It was a bad left channel cable somewhere, wasn't it?
Dec 24, 2008 | Sony STR-DG510 Receiver
Left channel not working
The first thing I would check has already been done, the only other thing would be fuses. I am preety sure there is a protection fuse at ever channels output to protect against a dead short. I am sure you have already fixed this problem but I thought I would give it a try. Let me know what you found.
Jul 13, 2008 | Denon AVR-3802 Receiver
Sherwood RX-4103 Receiver Logo
41 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Josh Whitehead
Josh Whitehead
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
