Question about iLO (2 GB) MP3 Player
Powering on my player wont power on.... It turns on and off right away. lights up and thats it, lasts half second. it has a brand new battery in it. Can anyone tell me what I should do?
  • Anonymous Oct 29, 2008
    mine won't power on with brand new battery
It is a piece of ****.
Posted on Oct 13, 2008
My mp3 wont turn on unless its connected to charger, i charged it all night last night and this morning i took it to school and it wouldnt turn on. it only turns on when i plug it into charger right when i...
Reset the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Mar 17, 2010 | SanDisk Sansa Clip MP3 Player
I have a Sansa c200 that will not turn on, although the light ring is on. When I plug it into the usb port on my computer it does not recognize it either. Thanks!
First try and reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Here is how to get to the battery, 1. Press the battery compartment in while sliding to the right. 2. Remove old battery. 3. Insert new battery or reset the old battery. 4. Close the battery compartment. Then try and see if it will come on with out the battery hooked to your computer. 1. Remove the battery. 2. Connect the player to the PC to verify if it turns on. 3. Re-seat the battery to ensure proper connection. 4. Verify if the player turns on.
Jan 30, 2010 | SanDisk Sansa c200 MP3 Player
My sandisk sansa clip 1gb wont turn on
Make sure the player is fully charged. 1. Connect the player to the PC. 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary.
To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
Jan 29, 2010 | SanDisk Sansa Clip MP3 Player
I dont know how to turn it on
Put a battery in it and hold down the play/power button like it says in the manual.  If this doesn't work (mine didn't do this right away) plug it into the computer and see if it's able to communicate with your computer.  If not, it's probably busted.  I'd advise you to begin trying to get your money back: I'm on my second one of this brand (accidentally). The first lasted a month.  This one never played a single song.
Dec 25, 2009 | Nextar MA933A MP3 Player
My mp3 player won't turn on.
may be its ur power key problem.
Jul 18, 2009 | Audio Players & Recorders
BATTERY LOW, POWERING DOWN! SANSA M240
Hey,
Try these steps, if they aren't of any help, you may have to have the vendor replace your mp3 player.
SOLUTION 1 - Reset the device.
SOLUTION 2 - Power cycle the device.
STEP 1 - Remove the battery
STEP 2 - Power cycle the player
1. Connect the device to the PC.
2. Leave the device connected for about 2 minutes.
STEP 3 - Turn on the device
1. Disconnect the player from the PC.
2. Insert a fresh AAA battery into the player.
3. Turn on the player.
Jan 16, 2009 | SanDisk Sansa m240 MP3 Player
IFP-395T (AA Batteries)
Probably a hardware issue, but the issue could also be with your USB port - make sure that there are no yellow exclamations next to the usb port in the PC device manager.
The battery indicator might not be stable during the following activities because they use large amounts of power:
1. The backlight of the LCD
2. Volume change
3. Pressing function keys and buttons
4. Reading the CD or files (Loading data to the memory)
The battery indicator shows the life expectancy of the battery based on current power usage. During these high power usage activities, that may only last a few seconds, the indicator will obviously show a lower level on the battery indicator. Once the high power activity has ended it will show a more accurate battery level.
Sep 26, 2007 | iRiver iFP-380T MP3 Player
New SanDisk Sansa m240 MP3 Player
Hey regan have u fixed it yet?? Mine is doing the same thing and it wont turn on at all well write back!! ~sam~
Dec 24, 2006 | SanDisk Sansa m240 MP3 Player
Help needed
Here is a fix I got from Sandisk support: Let's try this: take the battery out of the player and wait for a full 5 minutes. While the battery is out, please hold the power-on button for 10 seconds. After that, connect it to your computer (without the battery). Does it work when it's connected to the computer? Regardless of that result, disconnect it from the computer, then put a brand new alkaline battery back in, and see if it will turn on. Now, another thing I found that worked once, was to remove the battery, hold the power button for 5 seconds, then replace battery. The unit powered up after that.
Aug 14, 2006 | SanDisk Sansa e140 MP3 Player
Its dead with no special reason
Here is information I used from another user of this product who had this issue
Let's try this: take the battery out of the player and wait for a full 5 minutes. While the battery is out, please hold the power-on button for 10 seconds. After that, connect it to your computer1.gif (without the battery). Does it work when it's connected to the computer?
Jan 04, 2006 | SanDisk Sansa e140 MP3 Player
iLO (2 GB) MP3 Player Logo
26 people viewed this question
Top iLO Audio Players & Recorders Experts
laikexpert
laikexpert
Sanath Kumar V
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
