Question about Amana Dryers
Dryer make very loud thumping noise when running
  • 943 Answers
HI THANKS FOR THE QUESTION. ON, DRYERS THEY USE DRUM ROLLER'S SO THAT THE DRUM TURNS EASY. THE NOISE YOU ARE HEARING IS THE WORN DRUM ROLLERS REPLACE THEM. THANKS THE APPLIANCE DOC.
Posted on Oct 04, 2008
LG electric dryer model DLEO332W or DLE0332W
Sounds like the belt broke..."loud thump"
Sep 21, 2013 | Dryers
The dryer suddenly started making a very loud scratching/clanging noise while running, it is NOT a thumping noise. can't figure out how to remove front
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
May 19, 2011 | LG Dryers
My Kenmore 80 Series gas dryer is making a loud thumping noise when running. It appears to still be drying, just making a very loud noise. What could this be? If it's the roller, approximately what is the...
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 04, 2011 | Dryers
Loud thumping noise
a roller under the drum has a flat spot
Dec 10, 2009 | Maytag PYE2300AY Electric Dryer
Makes loud noise when running
bad berring that the drum rides in
Sep 30, 2009 | GE Dryers
Loud rumbling noise with slight vibration
Normally the noise you hear is caused by the drum rollers having flat spots on them or needing lubricant.
If this is what is wrong It will make a kind of thumping noise.
When they need lubricant they will normally make a squealing noise also. You would lube the shaft and bearing area of the roller, using a good machine oil...something like "3 in One" oil.
Sep 26, 2009 | GE DBXR463ED Electric Dryer
Dryer has thumping noise.
Yes that is what most likely is the problem to begin with. The drum usually never goes out of round . Replace bearing best choice
Aug 28, 2009 | Dryers
Loud thumping noise in Frigidaire model # FDE336RES2
You have to remove the top lid. Then remove the front panel. Then remove the belt and drum.
Your problem is a bad rear drum support assembly.
Remember to unplug the dryer.
Mar 27, 2009 | Frigidaire FGR341AC Electric Dryer
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Dryers Logo
230 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
