Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool Ultimate Care II washer won't spin clothes more dry than soggy
My washer spins, but it's not spinning at a high enough speed that gets the clothes any less than soggy. I've tried to turn it to different agitation/spin speeds, but the fastest speed still does the same. Would a motor be the problem or could it be something else? Thank you! I have a Whirlpool Ultimate Care II, LSQ9564J - Thanks, Dougm@kw.com
  • country100 Oct 05, 2008
    I saw oil and wondered where it had come from - you are right on - too much for me to fix myself - time for the junk yard... Thanks!
  • 413 Answers
Tip the washer backward, inspect the bottom of the gearcase for oil. If oil is present, the oil has migrated to the clutch causing it to slip during spin. The gearcase and clutch will have to be replaced if oil is present. Check the owners manual for limited warranty on the gearcase. If oil is not present, the clutch is just worn and should be replaced.
Posted on Oct 05, 2008
WASHER MOD.#LSQ9549LWO NOT SPINNING CLOTHS COMPLETELY DRY,ESPECIALLY LARGER LOADS
sounds like your clutch could be slipping not giving you full speed spin, i've heard you can install a #10 washer into the clutch spring cap and it would work fine , keeping you from replacing the clutch!
Feb 17, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a whirlpool ultimate care 2 top load washer no spin
Sounds as if the drive hub which the tub is attached to maybe free spinning. Not an expensive part but does require a special tool called a spanner wrench to remove and replace.
Jan 31, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ8243HQ0 weak spin, wet clothes
if it has a belt, it may be slipping, but you would smell a bit of burning rubber.in high use times(4 to 8 pm), the current of electric supply is low, thus less power. third, motor may need to be replaced. plz rate-bozcro
Sep 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a whirlpool gold ultimate care II electric dryer and have to dry everything on high twice to get it dried. any suggestions?
first how is the clothes out of the washer? That might not be spinning fast enough in final spin. When was the last time the dryer vents was cleaned. Do you have a flow out the vent? If so then something might be going on with sensors.
May 18, 2009 | Whirlpool GGQ8831L Gas Dryer
Loud noise
similar thing happened to me. Check to see if a screw (in my case) or other item fell through one of the holes in the bottom of the basket. Feel really well because in my case it was hard to tell there was anything in there.
Oct 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool ultimate care 2 washer wont spin
Are you in the Delicate Cycle? Do you have spin speed control set for slow?If both answers are no,than what is the model & serial number??
Apr 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Will not high spin
The brake assembly is failing ,try this if you can,loosen the 3 transmission bolts about a quarter inch and try it in spin.If it picks up speed than you are going to be due to have the break assembly replaced.High cost repair. :(
Apr 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
653 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
