Question about Nemox Caffe NEM 205 Espresso Machine
Pod filter basket
What's the replacement part for the single pod filter basket for the Nemox Caffe NEM 205 pod espresso machine. So that I'll know what to oder.
Thanks
  • 515 Answers
I can not this machine, sorry
I do service on Saeco, Kenwood, LaPavoni, Spidem, Cuisinart, Breville.
Have a nice day
/Mirran
Posted on Oct 26, 2008
I cant get my Gaggia Classic to work with pods
You need to use the single-serving size one-hole basket, not the double, with the diffuser valve seated beneath the basket. Then the Illy ese pod should be inserted with the decal facing up. Finally, and most importantly, when you lock the filter assembly into the machine, you need to close it firmly. Brown water can mean that the basket assembly is not sealed in tight enough.
Sep 07, 2014 | Gaggia Classic Espresso Machine
I have a Baby Gaggia, several years old. I buy IZZO ESE pods, which I understand should fit the holder. They do not in that a pod sits loose in the holder, with a margin round the edge between it and the...
Please try the following:
  • Remove the portafilter and activate the brew switch. Water should stream out of the shower screen. If not you need to clean the group components, or the machine is broken.
    To clean the group components, remove the center screw. The screen should drop down, the dispersion disk may be stuck, you can pry it loose with a flat head screw driver. Soak both of these in a descaling solution.
  • With the group components removed (as above) try brewing, water should stream out of a single hole. If not, you may have a faulty pump, or seals.
  • If water streams out normally, be sure that you are using the single espresso basket. This is the smaller basket that snaps into the portafilter, and has sort of a tulip shape.
  • Your group head gasket may be worn, and will need to be replaced. These need replacement ever 6 months to 12 months, and need to replaced even if the machine is rarely used, because they are made from natural rubber that dries out.
    Replacements can be found at many retailers online, a few are:
    espressocare.com, espressoparts.com, and seattlecoffeegear.com
Mar 02, 2011 | Gaggia Baby Espresso Machine
I have an Ascaso Dream - pod only version. I would like to know if the portafilter is replaceable. I want to exchange it with the model that does both ground and pod coffee. Thx, Rasmus from Denmark
Hi Rasmus,
If your model is pod only - fixed version - then it is not possible to replace the group.
If you have a pod portafilter then it is possible.
You will need: . a new portafilter and ground converter kit Ground coffee converter Kit ASCASO porta filter complete
Sep 04, 2010 | Ascaso Dream Espresso Machine
I recentlty bought a Francis X1 (2000 model). I
There are two different handles made for this unit (I own an X1 and have both). Both of these handles have baskets.
First - The pod handle has a basket area that is very shallow, about 1/3 of an inch deep and the basket has very small holes.
Second - The handle for loose grounds came with two baskets, one for a single dose, and one for a double dose. Both removable baskets have the very small holes for the espresso to drip through.
You must have a basket in the handle in order to use the machine. If you try to make espresso without a basket, you'll just make a mess. Besides, the machine will never be able build enough pressure to extract espresso from the grounds.
Search the net (ebay?) for francis francis x1 handle.
Good luck
Feb 24, 2009 | FrancisFrancis! X1 - Stainless Steel...
We just got a Via Venezia espresso maker. When I
put the rubber gasket in, then the pod basket, then the pod
Feb 22, 2009 | Saeco VIA Venezia
Regarding the single shot pod and filter
the machine might or might not have had the pod filter based on manufacturing date. If you did not have one it can be purchased on Breville USA web site for $10.
Jan 22, 2009 | Breville Die Cast 800ESXL Espresso Machine
Cuisinart EM 200
I was about to abndon pods on this machine, and then I actually used the Pod filter basket - it worked like a charm. Decalcifying is not a bad idea.
Jan 22, 2009 | Cuisinart EM-200 Espresso Machine
Parts needed
contact Shriro located in NSW
Dec 15, 2008 | Gaggia Classic Espresso Machine
Lost Used Coffee Pod Basket
My husband threw ours away. So I inquired next time I ordered pods, and you can buy one online when you order. Just put it in the comments box on your order form (although it may be better to call and order it, as the first time I tried this they missed it). Anyway. It was like $3.50. Then my husband threw that one away too, so I gave up. ;)
Sep 29, 2008 | Nespresso C100B Essenza Single-Serve...
Nemox Caffe NEM 205 Espresso Machine Logo
125 people viewed this question
Top Nemox Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Nemox Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
